Scalar and vector potentials and magnetic monopoles
In summary, the expressions for the E and B fields in terms of \varphi and \bar{A} can be written as B = \nabla \times \bar{A} and E = \nabla\varphi - \frac{\partial{A}}{\partial t}. This definition of B is consistent with the non-existence of magnetic monopoles because the Maxwell equation, div B = 0, shows that there are no magnetic monopoles, and the definition of the vector potential, which includes the curl of A, also results in a divergence of 0. This means that there are no source terms for the magnetic field, unlike for the electric field, which has a source term in the Maxwell
peterjaybee
62
Write down expressions oer E and B fields in terms of [tex]\varphi[/tex] and [tex]\bar{A}[/tex]. Demonstrate that this definition of B is consistent with the non-existence of magnetic monopoles.
The first part of the question is easy. i.e. bookwork
[tex]B = \nabla \times \bar{A}[/tex]
[tex]E = \nabla\varphi - \frac{\partial{A}}{\partial t}\[/tex]
I don't know how to approach the second part of the question though
Hi peterjaybee! :smile:
Hint: there is electric charge, but (if there are no magnetic monopoles) there's no magnetic charge (ie, you can't have a particle or an object with overall magnetic charge) … so how does electric charge come out of the equations in a way that magnetic charge can't? :wink:
I believe you're missing a minus sign for the E-field. Grab your book and go to the page where the Maxwell equations are listed. Can you identify the equation that has electric charge as a source term?
thanks, yes you are right the minus sign should be there.
With regards to the second part, i think I have it thanks to your hints. Div B = 0 is the maxwell eqn that shows there are no magnetic monopoles (as there are no source terms - unlike for div E). The definition of the vector potential is consistent with this because the divergence of a curl is always zero.
Yes that is correct.
Related to Scalar and vector potentials and magnetic monopoles
Question 1: What are scalar and vector potentials?
Scalar and vector potentials are mathematical functions used in physics to describe electric and magnetic fields. Scalar potentials are used to describe electric fields, while vector potentials are used to describe magnetic fields.
Question 2: What is the difference between scalar and vector potentials?
The main difference between scalar and vector potentials is that scalar potentials are used to describe electric fields, which are created by stationary charges, while vector potentials are used to describe magnetic fields, which are created by moving charges.
Question 3: What are magnetic monopoles?
Magnetic monopoles are hypothetical particles that have a single magnetic pole, either north or south, similar to how electric charges have positive and negative poles. However, unlike electric charges, which exist as isolated particles, magnetic monopoles have not been observed in nature.
Question 4: Can magnetic monopoles exist?
While magnetic monopoles have not been observed in nature, they are predicted to exist in certain theories of physics, such as grand unified theories. There have been some experimental attempts to find magnetic monopoles, but so far, none have been successful.
Question 5: How are scalar and vector potentials related to magnetic monopoles?
In certain theories, magnetic monopoles are connected to the existence of both scalar and vector potentials. Scalar potentials are used to describe the electric field produced by a magnetic monopole, while vector potentials are used to describe the magnetic field produced by a magnetic monopole.
