Scalar Fields with the Same Mass
In summary, the conversation discusses an exercise in Peskin&Schröder's QFT book about a pair of scalar fields and their equations of motion. A "rotation" is introduced which mixes the two fields and has properties of angular momentum. This symmetry can also be maintained with the addition of a four-point interaction in the Lagrangian density. This concept extends to more than two scalar fields and can also be applied to vector, tensor, and spinor fields. The mass difference between fields can be treated as a perturbation in some cases. Additionally, this theory can also be applied to nonabelian gauge theories and spinor fields.
hilbert2
Insights Author
605
In the Peskin&Schröder's QFT book there's an exercise that's about a pair of scalar fields, ##\phi_1## and ##\phi_2##, having the field equations
##\left(\partial^{\mu}\partial_{\mu}+m^2 \right)\phi_1 = 0##
##\left(\partial^{\mu}\partial_{\mu}+m^2 \right)\phi_2 = 0##
where the mass parameter is the same for both fields. Now I can make a "rotation",
##\phi_{1}^{'} = \cos \alpha \phi_1 - \sin \alpha \phi_2##
##\phi_{2}^{'} = \cos \alpha \phi_2 + \sin \alpha \phi_1##
which mixes the two fields. The generator of this rotation apparently has properties of angular momentum, but has nothing to do with spacetime. The symmetry can also remain if a four-point interaction is added in the form of terms proportional to ##(\phi_1)^4##, ##(\phi_2)^4## and ##\phi_1^2 \phi_2^2## in the Lagrangian density.
From other sources I got the impression that this has something to do with the Higgs mechanism... How does this extend to more than 2 scalar fields, and can a pair of vector, tensor or spinor fields have a similar property? If the fields have almost the same mass, is there some useful way to treat the mass difference as some kind of a perturbation?
This is just a scalar field theory with an SU(N) internal symmetry. The field can be represented as a vector. If the symmetry is promoted to a local symmetry it will become a nonabelian gauge theory coupled to a scalar field.
You can also have this for spinor fields
Likes hilbert2
Thanks. I'll still need to read more about this to understand the case where the symmetry is only approximate.
Related to Scalar Fields with the Same Mass
1. What is a scalar field?
A scalar field is a physical quantity that has a numerical value at every point in space and time. It does not have a direction associated with it, unlike vector fields.
2. How is the mass of a scalar field determined?
The mass of a scalar field is determined by the energy associated with it. According to Einstein's famous equation E=mc^2, energy and mass are interchangeable, so the mass of a scalar field can be calculated from its energy.
3. Can scalar fields have the same mass?
Yes, scalar fields can have the same mass. Just like any other physical quantity, scalar fields can have equal values at different points in space and time.
4. What is the significance of scalar fields with the same mass?
Scalar fields with the same mass can have important implications in physics, particularly in theories involving symmetry and the fundamental forces of nature. They can also help explain the behavior of particles and their interactions with each other.
5. How are scalar fields with the same mass studied and observed?
Scalar fields with the same mass are studied and observed through experiments using particle accelerators and other high-energy physics equipment. By analyzing the collisions of particles, scientists can gather data and make predictions about the behavior of scalar fields with the same mass.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
