Scalar product of biharmonic friction with velocity components
In summary: Laplacian of the velocity field. In summary, we can expand the biharmonic version of the friction term using the identity that relates the biharmonic operator to the Laplacian operator. This expansion involves an additional term compared to the harmonic version, which makes it more challenging to work with.
twilder
TL;DR Summary
Find ##\underline u \cdot [(A\nabla^4 \underline u)]##
I know that taking the scalar product of the harmonic (Laplacian) friction term with ##\underline u## is
$$\underline u \cdot [\nabla \cdot(A\nabla \underline u)] = \nabla \cdot (\underline u A \nabla \underline u) - A (\nabla \underline u )^2 $$
where ##\underline u = (u,v)## and ##A## is a constant.
I am unsure how to expand the biharmonic version,
$$\underline u \cdot [(A\nabla^4 \underline u)] = \cdots $$
I have got to this stage so far,
$$\underline u \cdot [\nabla \cdot (A^{1/2}\nabla(\nabla \cdot (A^{1/2} \nabla \underline u)))] = \nabla \cdot [\underline u A^{1/2}\nabla(\nabla \cdot (A^{1/2}\nabla \underline u))]- A^{1/2}\nabla(\nabla \cdot (A^{1/2}\nabla \underline u))\cdot \nabla \underline u$$
There doesn't appear to be any clear references for this type of expansion in textbooks or online (that I have come across). Does anyone have any ideas how I could go further with this?
I can understand your confusion with expanding the biharmonic version of the friction term. The biharmonic operator is a fourth-order differential operator and can be written as the product of two second-order operators, which can make it more challenging to work with.
One approach to expanding this term is to first rewrite it in terms of the Laplacian operator, using the identity that relates the biharmonic operator to the Laplacian operator:
$$\nabla^4 \underline u = \nabla^2 (\nabla^2 \underline u) = \nabla \cdot (\nabla \cdot (\nabla \cdot (\nabla \underline u)))$$
Substituting this into the original equation, we get:
$$\underline u \cdot [(A\nabla^4 \underline u)] = \underline u \cdot [A \nabla \cdot (\nabla \cdot (\nabla \cdot (\nabla \underline u)))]$$
Using the product rule for the scalar product, we can expand this further:
$$\underline u \cdot [A \nabla \cdot (\nabla \cdot (\nabla \cdot (\nabla \underline u)))] = A (\nabla \cdot (\nabla \cdot (\nabla \cdot (\nabla \underline u)))) \cdot \underline u + \underline u \cdot [A \nabla \cdot (\nabla \cdot (\nabla \cdot (\nabla \underline u)))]$$
Now, we can use the identity you provided in the original post, to expand the second term on the right-hand side:
$$\underline u \cdot [A \nabla \cdot (\nabla \cdot (\nabla \cdot (\nabla \underline u)))] = A (\nabla \cdot (\nabla \cdot (\nabla \cdot (\nabla \underline u)))) \cdot \underline u + \nabla \cdot (\underline u A \nabla (\nabla \cdot (\nabla \underline u))) - A (\nabla \underline u)^2$$
This is the final expansion of the biharmonic version of the friction term. It is similar to the expansion of the harmonic version, but with an
Related to Scalar product of biharmonic friction with velocity components
1. What is the scalar product of biharmonic friction with velocity components?
The scalar product of biharmonic friction with velocity components is a mathematical operation that calculates the magnitude of the force acting on an object due to biharmonic friction, taking into account the direction of the object's velocity.
2. How is the scalar product of biharmonic friction with velocity components calculated?
The scalar product is calculated by multiplying the magnitude of the biharmonic friction force with the cosine of the angle between the force vector and the velocity vector. This results in a scalar value, or a single number, that represents the magnitude of the force acting on the object.
3. What is the significance of the scalar product of biharmonic friction with velocity components?
The scalar product is important because it allows us to determine the work done by the biharmonic friction force on an object, which is a measure of the energy transferred to the object. It also helps us understand the relationship between the direction of the force and the direction of the object's motion.
4. How does the scalar product of biharmonic friction with velocity components relate to other physical concepts?
The scalar product is closely related to the dot product, a mathematical operation commonly used in physics to calculate work and energy. It is also related to the concept of work done by a force, as it represents the component of the force that is parallel to the object's displacement.
5. Can the scalar product of biharmonic friction with velocity components be negative?
Yes, the scalar product can be negative if the angle between the force and velocity vectors is greater than 90 degrees. This indicates that the force is acting in the opposite direction of the object's motion, resulting in negative work being done on the object.
