I Scaling Dimension of a Field in CFT
shinobi20
TL;DR Summary
I'm quite unsure about how the scaling dimension of a field is devised. I need clarifications on small details in order to make sure that my concepts are clear.
I'm studying CFT, and I find the lecture notes and books really confusing and devoid of explanations (more details).
In a scale transformation ##x' = \lambda x##, the field ##\phi(x)## should also be affected by the scale transformation, i.e., ##\phi'(x') = \phi'(\lambda x) = \lambda^{-\Delta} \phi(x)##. I think this should mean that we assume that the field should scale but we do not know by how much, and ##\Delta## quantifies this unknown, which is called the scaling dimension. We put a minus sign because when we plug it in the action, this will avoid a negative dimension (see below)?
If the scale transformation is a symmetry of the theory, then the action must be invariant under this. Particularly, in a free theory,
\begin{align*}
S' & = \int d^d x' \partial'_\mu \phi'(x') \partial'^\mu \phi'(x')\\
& = \int d^d x' g^{\mu \nu} \partial'_\mu \phi'(x') \partial'_\nu \phi'(x')\\
& = \int d^d x \Bigg| \frac{\partial x'}{\partial x} \Bigg| \lambda^{-2} g^{\mu \nu} \partial_\mu \phi'(x') \partial_\nu \phi'(x')\\
& = \int d^d x \lambda^d \lambda^{-2} \partial_\mu \phi'(x') \partial^\mu \phi'(x')\\
\end{align*}
Comparing this with ##S = \int d^d x \partial_\mu \phi(x) \partial^\mu \phi(x)##,
\begin{equation*}
\int d^d x \lambda^d \lambda^{-2} \partial_\mu \phi'(x') \partial^\mu \phi'(x') = \int d^d x \partial_\mu \phi(x) \partial^\mu \phi(x)
\end{equation*}
We can infer that,
\begin{equation*}
\lambda^{\frac{d-2}{2}} \phi'(x') = \phi(x), \quad \text{OR} \quad \phi'(x') = \lambda^{\frac{-(d-2)}{2}} \phi(x)
\end{equation*}
So the scaling dimension is ##\Delta = \frac{(d-2)}{2}##. If we were to not put a minus sign from the start, i.e., ##\phi'(\lambda x) = \lambda^{\Delta} \phi(x)##, then ##\Delta = \frac{-(d-2)}{2}##.
Questions:
1. Can anyone verify if what I'm saying (my statements) above are correct?
2. Can anyone explain more about the minus sign?
3. I'm not sure if what I wrote in the second line of the action is correct, i.e., ##\partial'_\mu \phi'(x') \partial'^\mu \phi'(x') = g^{\mu \nu} \partial'_\mu \phi'(x') \partial'_\nu \phi'(x')##. Is this correct or should it be ##\partial'_\mu \phi'(x') \partial'^\mu \phi'(x') = g'^{\mu \nu} \partial'_\mu \phi'(x') \partial'_\nu \phi'(x')##? If this is the case then ##g'^{\mu \nu}## should also transform, but then I would not get the correct scaling dimension.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
