Scatter radiation and film fogging
In summary, during the process of radiography, scatter radiation can occur due to the difference in densities of the object being radiographed. This can cause fogging of the film, resulting in a decrease in contrast. It is challenging to understand how scattered photons can increase the density of the radiographic image, but it is due to the uniform additional exposure across the whole film. This can lead to a decrease in contrast as there is a smaller range of optical densities registered on the film.
Asmaa Mohammad
182
Hello,
During the procedure of radiography using x-rays, scatter radiation occurs, due to the difference in densities of the object being radiographed.
That scatter radiation causes fogging (noise) of the film, i.e. the contrast of the film is reduced due to extra darkening of some areas of the film (increase in the overall density of the image).
What I have difficulty to imagine is how could these scattered photons increase the density of the radiographic image. Do they hit the object again or do they hit the film in a way that causes fogging (so what is that way?).
All in all, hope someone will clarify it for me!
thanks!
The same way as any x-ray. The problem with scatter is that the source of scatter is extended resulting in the more or less uniform additional exposure across the whole film. The contrast you observe on the film is due both to the characteristics of the film and the variation of the exposure of the film due to the variation of the transmitted radiation through the object. The film produces an optical density depending on the exposure; the larger the ranging of exposures the more optical densities that will be registered. With no scatter you may have a large range variation of exposure from the object. This may result in the visualization of the who range of optical densities that can be appreciated by the eye. As the scatter is increase the range of exposures across the whole film decreases. This leaves a smaller range in optical densities to be registered on the film. Thus the contrast is reduced.
Related to Scatter radiation and film fogging
1. What is scatter radiation?
Scatter radiation is a type of secondary radiation that occurs when primary radiation (x-rays) passes through matter, causing some of the photons to change direction. This can lead to unwanted exposure on the film, known as film fogging.
2. How does scatter radiation affect film images?
Scatter radiation can cause film fogging, which appears as a general overall grayness on the image. This can decrease image contrast and make it difficult to see subtle details.
3. What factors contribute to scatter radiation and film fogging?
Scatter radiation and film fogging can be caused by various factors such as the type of x-ray machine, the thickness and density of the patient's body part being imaged, and the distance between the x-ray source and the film.
4. How can scatter radiation and film fogging be reduced?
To reduce scatter radiation and film fogging, collimation should be used to limit the x-ray beam to only the area of interest. Additionally, using a grid between the patient and the film can help absorb scattered radiation and improve image quality.
5. Are there any safety concerns related to scatter radiation?
Exposure to scatter radiation can be harmful, especially for healthcare professionals who are regularly exposed. Proper use of protective equipment, such as lead aprons and thyroid shields, can help minimize the risk of exposure to scatter radiation.
  • Thermodynamics
  • Thermodynamics
