Scattering and non-imaging optics
In summary: I wouldn't lose sleep about the terminology used. Different words are often used for a particular process/object in different contexts. In this case, "scattering lens" may be referring to a lens that relies on diffraction rather than refraction. However, it may also be used in a more general sense to describe any lens that scatters light, which would include both refractive and diffraction-based lenses. Ultimately, the specific meaning would depend on the context in which it is used.As for non-imaging lenses, they do not exist in the traditional sense of a lens that produces an image. However, there are techniques such as ptychography that can produce images without the use of a traditional lens. These techniques are often referred to
ZeroFunGame
93
I have seen the term "conventional scattering lens" being used (see https://arxiv.org/pdf/2112.08144) and I was wondering whether the term scattering lens is accurate? I always envisioned a lens as a refractive element, and wondering if the reference means refracting rather than scattering?
Separately, and this is due to my lack of understanding of the nomenclature, would a non-imaging lenses be also considered a refractive optical element? For example a Fresnel lens?
I am confused because https://en.wikipedia.org/wiki/Nonimaging_optics states radiative transfer as the technical term used to describe non-imaging optics, which linked to https://en.wikipedia.org/wiki/Radiative_transfer but did not include refraction (only, absorption, emission, and scattering)
Science news on Phys.org
There are lenses that are based on diffraction rather than refraction. That's especially useful if there is no material with a refractive index that is sufficiently different from 1. This is the case for X-rays, for example.
A Fresnel lens is a refractive lens that's simply split into zones in order to keep it thinner. It uses the same principles as a normal refractive lens.
In the first paper, however, they talk about lens-less imaging, using diffraction patterns from overlapping areas (ptychography). That's a non-imaging technique.
And: There are no non-imaging lenses.
Likes vanhees71
A lens with a focal length greater than the Rayleigh Distance cannot bring rays to a focus and hence cannot form an image.
Likes vanhees71, DaveE and Philip Koeck
Could you explain a bit?
I just looked up Rayleigh distance on Wikipedia: https://en.wikipedia.org/wiki/Rayleigh_distance
If D is much larger than λ in the expression they give then Z is quite a large distance compared to λ.
Did you mean "a focal length smaller than the Rayleigh distance"?
Looking at the way it's used in that preprint, I think they may mean an optical diffuser.
I have to correct my terminology.
Ptychography is of course an imaging technique, but it doesn't use images produced optically.
It uses multiple diffraction patterns. The image is then calculated from these.
This means that you don't need a lens.
The same is possible if you have a single diffraction pattern of a periodic or aperiodic object.
You "just" need to find the phases of the Fourier transform and you can get an image by inverse FT.
Usually this requires some additional information about the object, though.
This is the field of "lens less imaging" and I'm sure there's more to it than I know about.
I would say a conventional lens for visible light is refractive.
The term you quote sounds rather odd.
I remember (many years ago) being introduced to The Zone Plate, which involves a diffraction pattern (in this case, Newton's Rings) on a photographic film. This can be used to form an image, like that from a convex lens. That's a trivial example but could be useful when, as mentioned above, there is no material with suitable refractive index available for the wavelength involved.
I wouldn't lose sleep about the terminology used. Different words are often used for a particular process / object in different disciplines.
Likes vanhees71 and Philip Koeck
The terminology is slightly confusing, I've realized after googling a bit.
A (Fresnel) zone plate is a diffraction lens, just as you say, whereas a Fresnel lens is really a refractive lens split up into concentric rings (zones?) in order to make it flatter and lighter.
Both are named after Fresnel just to make life difficult.
Here are two Wikipedia entries:
https://en.wikipedia.org/wiki/Zone_plate
https://en.wikipedia.org/wiki/Fresnel_lens
Is there any other way to focus photons other than reflection, refraction and diffraction?
For charged particles there are electric and magnetic fields and also standing light waves
(see for example: https://www.researchgate.net/publication/363866622_Transverse_Electron-Beam_Shaping_with_Light).
Would the opposite work: Standing electron waves that focus x-rays for example?
I think there would be an Energy problem here. The density of a standing wave of electrons would be limited by the Coulomb force so could you produce conditions with electrons contained in enough quantity. But that would still constitute a Diffraction device.
Gravitation?
Likes sophiecentaur, vanhees71 and Philip Koeck
The lenses, however, are a bit unhandy. It's good to have an entire galaxy or at least a supermassive black hole for that ;-).
Likes sophiecentaur and hutchphd
It's just a matter of intergalactic collaboration.
  • Haha
Likes sophiecentaur, hutchphd and vanhees71
hutchphd said:
Gravitation?
Of course! I was thinking in terms of 'in the lab' but galaxies and black holes do it measurably. But, in that case you have to take what you're given.
Likes vanhees71
FAQ: Scattering and non-imaging optics
What is scattering in optics?
Scattering in optics refers to the phenomenon of light being redirected in different directions when it interacts with matter. This can occur due to various factors such as the size, shape, and composition of the particles in the material.
How does scattering affect the appearance of objects?
Scattering can affect the appearance of objects by altering the intensity, color, and direction of the light that is reflected or transmitted from the object. This can make the object appear brighter, darker, or have a different color than it would under direct illumination.
What is the difference between scattering and absorption?
Scattering and absorption are both ways in which light interacts with matter. However, scattering involves the redirection of light, while absorption involves the conversion of light energy into other forms of energy, such as heat. Scattering can occur without any change in the wavelength of light, while absorption typically results in a decrease in the intensity of light.
How are non-imaging optics used in practical applications?
Non-imaging optics is a branch of optics that focuses on designing optical systems that do not produce images, but rather manipulate light for specific purposes such as illumination or concentration. This can be applied in various fields such as solar energy, lighting, and telecommunications.
Can scattering and non-imaging optics be used to improve solar energy efficiency?
Yes, scattering and non-imaging optics can be used to improve solar energy efficiency. By using materials that scatter and redirect light towards the solar cells, the amount of light absorbed and converted into electricity can be increased. Non-imaging optics can also be used to concentrate light onto smaller, more efficient solar cells, increasing their efficiency.
