Scattering of Neutrons from 2d Crystal Lattice
In summary, the crystal can reflect waves with wavelengths up to 5 Å. The reflections can be found if the incoming wave has a wavevector that is a multiple of 2##\pi##.
1Kris
A two-dimensional rectangular crystal has a unit cell with sides a 6.28Å and
b 3.14Å. A beam of monochromatic neutrons of wavelength 5.0 Å is used to
examine the crystal.
Using either the Laue condition for diffraction or Bragg's Law, determine
whether it would be possible to observe the following reflections: (11), (20)
and (02).
Laue conditions: K[itex]\cdot[/itex]a=2πh
K[itex]\cdot[/itex]b=2πk
K[itex]\cdot[/itex]c=2πl
for wavevector K, lattice vectors a,b,c and integers h,k,l.
Bragg's law: 2dsinθ=nλ
for lattice plane spacing d, Bragg angle θ, scattering order n and wavelength λ.
Reciprocal space lattice is rectangular with lengths a* = 2π/a, b*=2π/b. Incoming wavevector k has magnitude 2π/5 = 1.26Å-1.
Laue conditions:
Direction (11) → K=a*+b*
K[itex]\cdot[/itex]a=a*[itex]\cdot[/itex]a=2π
K[itex]\cdot[/itex]b=b*[itex]\cdot[/itex]b=2π
both are integer multiples of 2π and so (11) reflections are allowed.
Direction (20) → K=2a*
K[itex]\cdot[/itex]a=4π
K[itex]\cdot[/itex]b=0
allowed again for same reasons.
Direction (02) → K=2b*
K[itex]\cdot[/itex]a=0
K[itex]\cdot[/itex]b=4π
allowed.
Bragg's law:
(11) → d = ((h/a)2+(k/b)2)-1/2
= ((1/6.28)2+(1/3.14)2)-1/2
≈ 2π/√5 (assuming a = 2π and b = π)
(11) reflection has highest common factor 1 so it is an n=1 reflection:
Bragg's law gives
1*5=2*(2π/√5)sinθ
rearrangement gives sinθ = 0.88970... which is certainly an allowed value for sinθ so I conclude that it is an allowed reflection.
(20) is an n=2 reflection, d = a/h = a/2 ≈ π
Bragg's law gives sinθ = 5/π > 1 which is not valid so the reflection cannot happen.
(02) is also n=2, d = b/k ≈ π/2
Bragg's law gives sinθ=3.18 and so it is not an allowed reflection.
I'm not too confident in the way I've gone about solving this problem by either method and the contradictory conclusions definitely show that at least one of them is wrong. Could anyone give some hints as to where I'm going wrong? Thanks!
If k is the wave-vector of the incoming wave and k’ for the diffracted wave, then the Laue condition is that k’- k = K where K is a reciprocal lattice vector.
The dot product of a reciprocal lattice vector K with a direct lattice vector (a or b) will always yield an integer multiple of 2##\pi##. So, all you did was verify that fact for the particular reciprocal lattice vectors corresponding to (1,1), (2, 0) and (0,2).
Since |k| = |k’|, see if you can use the condition k’- k = K to find the minimum possible value of |k| for a given |K|. That will tell you the maximum wavelength that the incident waves can have and still satisfy the Laue condition.
Thanks for the reply.
The vectors k, k' and K make a triangle because of the vector addition relating them. To minimise k, surely the triangle would be flattened such that k and k' run parallel to K.
This gives k=k'=K/2.
and we know
λ=2[itex]\pi[/itex]/k
(11): K=(([itex]\frac{2\pi}{a}[/itex])2+([itex]\frac{2\pi}{b}[/itex])2)[itex]\frac{1}{2}[/itex]
= [itex]\sqrt{5}[/itex]Å-1
corresponding to a maximum λ of 4[itex]\pi[/itex]/[itex]\sqrt{5}[/itex]Å
Similarly I get
(20): λ = 2[itex]\pi[/itex]Å (maximum)
(02): λ = [itex]\pi[/itex]Å (maximum)
As it is given that the incoming beam has wavelength 5Å then (11), (20) are allowed and (02) is excluded.
Is this reasoning correct? Is it generally true that all wavelengths below a maximum are reflected by a crystal?
1Kris said:
As it is given that the incoming beam has wavelength 5Å then (11), (20) are allowed and (02) is excluded. Is this reasoning correct?
Yes, that all looks right to me.
If λ is below the maximum for a set of lattice planes, then you will get reflection if the crystal is oriented such that the lattice planes make the proper angle with respect to the direction of the the incident wavevector. If you change λ then you would need to adjust the orientation. If you use a powder of little crystals oriented in all directions, then there will always be some crystals oriented to give reflection as long as λ is below the maximum.
Thanks very much. You've pulled me out of that horrible mess of confusion! I had briefly thought of the condition you gave but I dismissed them before I figured out the consequences because I didn't think it was either the Laue condition or Bragg's law. Thanks again.
Related to Scattering of Neutrons from 2d Crystal Lattice
1. What is scattering of neutrons from 2d crystal lattice?
Scattering of neutrons from 2d crystal lattice is a phenomenon in which neutrons interact with a two-dimensional crystal lattice, causing them to change direction and possibly lose energy. This scattering can provide valuable information about the structure and properties of the crystal lattice.
2. How does scattering of neutrons from 2d crystal lattice occur?
Scattering of neutrons from 2d crystal lattice occurs due to the interaction between the neutrons and the atoms in the crystal lattice. This interaction can be caused by the electric and magnetic fields of the atoms, as well as the nuclear forces between the neutrons and the nuclei of the atoms.
3. What are the applications of studying scattering of neutrons from 2d crystal lattice?
The study of scattering of neutrons from 2d crystal lattice has many applications in materials science, physics, and chemistry. It can be used to investigate the structure and dynamics of materials, as well as to study the magnetic and electronic properties of crystals.
4. How is scattering of neutrons from 2d crystal lattice measured?
Scattering of neutrons from 2d crystal lattice is typically measured using a technique called neutron diffraction. This involves directing a beam of neutrons at the crystal and measuring the scattered neutrons at various angles. The resulting diffraction pattern can then be analyzed to determine information about the crystal lattice.
5. Can scattering of neutrons from 2d crystal lattice be used to study biological systems?
Yes, scattering of neutrons from 2d crystal lattice has been used to study biological systems such as proteins and membranes. Neutrons are able to penetrate biological materials without damaging them, making it a useful tool for studying the structure and function of these systems.
  • Atomic and Condensed Matter
