Schrodinger equation for step potential
In summary, the conversation discusses the one-dimensional Schrodinger equation for a step potential and how to calculate the penetration depth Δx at which the probability density of the transmitted wave decays to half its value at x=0. It also mentions applying this result to an electron inside a metal block and a macroscopic particle with specific mass and velocity. The question does not require calculating transmission probabilities, but rather only determining the form of the wave function for x>0. The suggested approach is to use an imaginary k to account for the decay and adjust it with a factor of ln(2).
Abdul.119
73
Consider the one-dimensional Schrodinger equation for the step potential, that is for U(x) = 0 for x<0, and
for
. Consider a particle with mass m and energy E < U. Assume the particle is initially at x<0.
a) Calculate the penetration depth Δx at which the probability density of the transmitted wave "decayed" to half the value that it has at x=0.
b) Apply your result of part a) to an electron inside a metal block for which the work function is 4 eV.
c) Apply your resilt of part a) to a "macroscopic" particle with mass m=10^-15 kg and velocity v=10^-2 m/sec. Assume a barrier height that is 1.5 as high as the kinetic energy of the particle.
I have no idea where start with this one, I have a clue on how to find the transmission and reflection probabilities but I am not sure this is relevant for finding Δx. In this question are we suppose to use the equation Δp Δx >= ħ/2π ?
The question does not ask you to calculate transmission probabilities. Just write down the form of the wave function for x > 0.
For x>0 I believe the wave function would be u(x) = Ae^(ikx)
So imaginary k will give you the decay. Adjust with a factor ln(2).
I don't quite understand what you mean by adjust by a factor of ln(2). Also still not seeing how k will help find penetration depth Δx
Related to Schrodinger equation for step potential
1. What is the Schrodinger equation for a step potential?
The Schrodinger equation for a step potential is a mathematical equation that describes the quantum behavior of a particle encountering a potential step, where the potential energy suddenly changes from one value to another. It is given by: HΨ(x) = (−ħ²/2m) ∂²Ψ(x)/∂x² + V(x)Ψ(x) = EΨ(x), where H is the Hamiltonian operator, Ψ(x) is the wave function, ħ is the reduced Planck's constant, m is the mass of the particle, V(x) is the potential energy, E is the total energy of the particle, and x is the position of the particle.
2. What is the significance of the step potential in the Schrodinger equation?
The step potential in the Schrodinger equation represents a sudden change in the potential energy of a particle. This can occur, for example, when a particle encounters a barrier or a well. The step potential is important in understanding the behavior of quantum particles, as it allows us to investigate how particles interact with different types of potentials.
3. How is the Schrodinger equation solved for a step potential?
The Schrodinger equation for a step potential can be solved using various mathematical techniques, such as the method of separation of variables or the use of Green's functions. The specific method used depends on the complexity of the potential and the desired level of accuracy in the solution.
4. What are the different types of solutions to the Schrodinger equation for a step potential?
There are two types of solutions to the Schrodinger equation for a step potential: transmitted and reflected solutions. Transmitted solutions describe the behavior of a particle that passes through the potential step, while reflected solutions describe the behavior of a particle that is reflected back by the potential step. The overall behavior of the particle is determined by the combination of these two solutions.
5. How does the Schrodinger equation for a step potential relate to the wave-particle duality of quantum mechanics?
The Schrodinger equation for a step potential is a fundamental equation in quantum mechanics, which describes the wave-like behavior of particles at the quantum level. It demonstrates the wave-particle duality of quantum particles, where particles can exhibit both wave-like and particle-like properties. The solutions to the Schrodinger equation show that particles can have a probability of being found on either side of the potential step, rather than being confined to a specific location as classical particles would be.
