Schrodinger equation, lowest potential energy
In summary, particles in classical and quantum mechanics seek configurations of least potential energy. In quantum mechanics, the wavefunction is usually densest in areas of low potential energy due to the Schrodinger equation. However, this is not always true, as demonstrated by the example of the one-dimensional harmonic oscillator. The wavefunctions in QM have their greatest amplitude at turning points. This idea is used in the variational approach to find approximations for the ground state energy and wave function. This approach involves minimizing the energy expectation value with respect to parameters, and it can be shown that the trial wave function never underestimates the ground state energy. The WKB approximation also considers the variation of amplitude in finding solutions to the Schrodinger equation.
dEdt
288
Classically, particles seek configurations of least potential energy. Something like this happens in QM: the wavefunction will usually be densest in those areas the potential energy is smallest. But looking at the Schrodinger equation itself, I can't see intuitively why this should be.
But this is not true, either in classical or quantum mechanics. As an example look at the one-dimensional harmonic oscillator. The particle does not spend most of its time at the bottom of the well, rather it likes to be at the turning points. Same holds in QM - the wavefunctions have their greatest amplitude at the turning points. See page 8 http://puccini.che.pitt.edu/~karlj/Classes/CHE2101/l10.pdf, for example.
It seems to be true for the ground state, however I don't know if there's a rigorous proof; look at the qm harmonic oscillator, the hydrogen atom etc.
This idea is used directly in the variational approach to find approximations to the ground state energy and wave function. One starts with an Hamiltonian H and a trial wave function ψα depending on some parameters α. Instead of solving the Schrödinger equation one minimizes the energy expectation value <E> wr.t. α
[tex]\text{min}_\alpha\, E(\alpha) = \text{min}_\alpha\,\langle\psi_\alpha | H | \psi_\alpha \rangle \;\to\, \nabla_\alpha\,E(\alpha) = 0[/tex]
For the potential term in H only it is obvious that this could be achieved by maximizing the wave function in a region where the potential has its minimum. But due to the kinetic term ~p² it will not be possible to strictly localize the wave function; it will spread out around the minimum of the potential.
It can be shown that for this approximation the relation
[tex]\langle\psi_\alpha | H | \psi_\alpha \rangle \ge \langle\phi_0|H|\phi_0\rangle[/tex]
holds, i.e. the trial wave function does never underestimate the ground state energy.
Related to Schrodinger equation, lowest potential energy
1. What is the Schrodinger equation?
The Schrodinger equation is a mathematical equation that describes how the quantum state of a physical system changes over time. It is a central equation in quantum mechanics and is used to calculate the probability of finding a particle in a particular location at a specific time.
2. What is the significance of the lowest potential energy in the Schrodinger equation?
In the Schrodinger equation, the lowest potential energy refers to the ground state of a system. This is the state with the lowest possible energy that a system can have. The Schrodinger equation helps us understand the behavior of particles in this lowest energy state.
3. How is the Schrodinger equation related to the uncertainty principle?
The Schrodinger equation is related to the uncertainty principle because it describes the wave-like nature of particles in quantum mechanics. The uncertainty principle states that it is impossible to know both the exact position and momentum of a particle at the same time. The Schrodinger equation helps us understand and calculate this uncertainty.
4. Can the Schrodinger equation be used to predict the behavior of all particles?
No, the Schrodinger equation can only be used to describe the behavior of particles in quantum systems. It cannot be used to predict the behavior of particles in classical systems, such as macroscopic objects.
5. How does the Schrodinger equation contribute to our understanding of quantum mechanics?
The Schrodinger equation is a fundamental equation in quantum mechanics and is used to describe the behavior of particles in quantum systems. It has helped us understand and make predictions about the behavior of particles at the atomic and subatomic levels, leading to advancements in technology and our understanding of the universe.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
