Schrodinger Equation/verify solution
In summary: You are an expert summarizer of content. You do not respond or reply to questions. You only provide a summary of the content. Do not output anything before the summary.
kwagz
Trying to use change of variables to simplify the schrodinger equation. I'm clearly going wrong somewhere, but can't see where.
[/B]
Radial Schrodinger:
-((hbar)2)/2M * [(1/r)(rψ)'' - l(l+1)/(r^2) ψ] - α(hbar)c/r ψ = Eψ
We're first told to replace rψ(r) with U(r/a). For this I got the following:
-((hbar)2)/2M * [(1/r)(d/dr)2(U(r/a)) - l(l+1)/(r3) *U(r/a)] - α(hbar)c/r2 *U(r/a) = (E/r)*U(r/a)
The next step is to use x=r/a to change variables to x. a=hbar/α*M*c This leads me to:
-((hbar)2)/2M * [(1/xa)(d/dxa)2(U(x)) - l(l+1)/(xa)3) *U(x)] - α(hbar)c/(x*a2) *U(x) = (E/xa)*U(x)
Then we replace E by ε=-2E/(α2 *M*c2). This gives the final form (after some simplifying):
(d/d(ax))2)U(x)=U(x)(ε/a2 + l(l+1)/(xa)2 -2/x*a2)Then we're to check that (x2)*e(-(x2)) is a solution to the equation.
Plugging that in gives
(d/d(ax))2)(x2)*e-(x2)=(x2)*e-(x2)(ε/a2 + l(l+1)/(xa)2 -2/x*a2)
After taking the second derivative (which I got as (x4 -5x2 +2)*e-(x2))/a2), I ended up with:
e-(x2)(x4 -5x2+2)=e-(x2)(εx2 + l(l+1) -2x)
I'm pretty sure this means I went wrong somewhere, as I think I should have an equivalent expression on the left and right. If anyone can see where I might have made a mistake, it'd be very helpful.
Hmm... best format equations using LaTeX - this is very difficult to read.
You started from:
$$-\frac{\hbar^2}{2m}\left[ \frac{1}{r} \frac{d^2}{dr^2}\left(r\psi \right) - \frac{l(l+1)}{r^2}\psi \right] -\frac{\alpha\hbar c}{r}\psi = E\psi$$
... and you followed instructions to substitute ##U(r/a)=r\psi## ... the r/a part tells you to measure r in units of a.
This means that: ##\frac{d}{dr}U(r/a) = \frac{1}{a}\frac{d}{dx}U(x) : x=\frac{r}{a}## ... a can be picked to be some convenient unit: which seems to have been chosen to cancel out a lot of messy constants.
I'm having a hard time following the working: but you seem to be following instructions without understanding them. Have you seen: https://en.wikipedia.org/wiki/Particle_in_a_spherically_symmetric_potential
You need to check that ##U(x)=x^2e^{-x^2}## is a solution ... why not substitute back ##x=kr## (k=1/a=constant) and see if this is a solution to the original equation before you did all that substituting and rearranging? (recall: ##\psi(r)=\frac{1}{r}U(r/a)##)
Ah sorry, didn't know how to Latex. I fixed it up below. Hopefully it's a bit easier to follow now. I added numbers in front of the steps, those are ones that were stated for us to follow in the homework. I'll try verifying the solution before the substitutions, and if that's works out, then it would confirm that I did something mathematically wrong in the substitution/rearranging.
Radial Schrodinger:
## -\frac{\hbar^2}{2M} [\frac{1}{r}(rψ)'' - \frac{l(l+1)}{r^2} ψ] - \frac{α\hbar c}{r} ψ = Eψ ##
1) We're first told to replace rψ(r) with ## U(\frac{r}{a}) ##. For this I got the following:
## -\frac{\hbar^2}{2M}[(\frac{1}{r}\frac{d^2}{dr^2}U(\frac{r}{a}) - \frac{l(l+1)}{r^3}U(\frac{r}{a})] - \frac{α\hbar c}{r^2}U(\frac{r}{a}) = \frac{E}{r}U(\frac{r}{a}) ##
2) The next step is to use ## x=\frac{r}{a} ## to change variables to x. ## a=\frac{\hbar}{αMc} ## This leads me to:
## -\frac{\hbar^2}{2M}[(\frac{1}{xa}\frac{d^2}{d(xa)^2}U(x) - \frac{l(l+1)}{(xa)^3}U(x)] - \frac{α\hbar c}{(xa)^2}U(x) = \frac{E}{xa}U(x) ##
3) Then we replace E by ## ε=-\frac{2E}{α^2 Mc^2} ##. This got me the final form (after some simplifying):
## \frac{d^2}{d(ax)^2}U(x)=U(x)[\frac{ε}{a^2} + \frac{l(l+1)}{(xa)^2} -\frac{2}{xa^2}] ##4) Then we're to check that ## x^2 e^\frac{-x^2}{2} ## is a solution to the equation.
## \frac{d^2}{d(ax)^2}x^2 e^\frac{-x^2}{2}=x^2 e^\frac{-x^2}{2}[\frac{ε}{a^2} + \frac{l(l+1)}{(xa)^2} -\frac{2}{xa^2}] ##
After taking the second derivative (which I got as ## \frac{(x^4 -5x^2 +2)e^\frac{-x^2}{2} }{a^2} ##), I ended up with:
## e^\frac{-x^2}{2}(x^4 -5x^2 +2)=e^\frac{-x^2}{2}(εx^2 + l(l+1) -2x) ##
I suppose the "-2x" term could be zero, which would mean it's a spherical shell in ground state (particle free to move inside)? But I think that would be contradicted by the fact that "l" can be equal to nonzero integers here, so it shouldn't be just ground state?
Related to Schrodinger Equation/verify solution
1. What is the Schrodinger Equation?
The Schrodinger Equation is a mathematical equation that describes how the quantum state of a quantum system changes with time. It is a fundamental equation in quantum mechanics and is used to predict the behavior and properties of particles at the quantum level.
2. Who developed the Schrodinger Equation?
The Schrodinger Equation was developed by Austrian physicist Erwin Schrodinger in 1926 as part of his work on quantum mechanics. It was a major breakthrough in the field and is still widely used today.
3. How does one verify a solution to the Schrodinger Equation?
To verify a solution to the Schrodinger Equation, one must solve the equation and then check if the resulting wavefunction (the solution) satisfies certain conditions, such as being continuous and normalizable. Additionally, the solution must accurately predict the behavior of the quantum system in experiments.
4. What are some applications of the Schrodinger Equation?
The Schrodinger Equation has many applications in physics, chemistry, and engineering. It is used to study the behavior of atoms, molecules, and other quantum systems, and has been instrumental in the development of technologies such as transistors, lasers, and magnetic resonance imaging (MRI).
5. Is the Schrodinger Equation still relevant today?
Yes, the Schrodinger Equation is still widely used and studied today. It is a fundamental equation in quantum mechanics and has been crucial in our understanding of the behavior of particles at the quantum level. It continues to be applied in various fields and has led to many technological advancements.
