Schroedinger Equation Problem
  • Thread starter explodingbird
In summary, the Schrödinger equation is a mathematical equation that describes the behavior of quantum particles and was developed by Erwin Schrödinger in 1926. It is one of the foundational equations of quantum mechanics and is used to calculate the probability of finding a particle in a particular state. There are two versions of the equation - the time-dependent and time-independent - which are used in different contexts. While the Schrödinger equation cannot be solved exactly in most cases, it has been solved for some simple systems, such as the hydrogen atom. This equation also relates to the uncertainty principle, as it allows us to calculate the probability of a particle's position and momentum, consistent with the principle's limitations.
explodingbird
What would you expect for <p> and <p^2> for the ground state of the simple harmonic oscillator?
Expectation value = <p> = integral psi* * (partial derivative with respect to x of psi) dx
I have no idea.
Think about the classical model and then use the theorem of Ehrenfest or the virial theorem to draw the required conclusion.
FAQ: Schroedinger Equation Problem
What is the Schrödinger equation?
The Schrödinger equation is a mathematical equation that describes the behavior of quantum particles, such as electrons. It was developed by physicist Erwin Schrödinger in 1926.
What is the significance of the Schrödinger equation?
The Schrödinger equation is one of the foundational equations of quantum mechanics and is used to calculate the probability of finding a particle in a particular state. It has been instrumental in our understanding of the behavior of subatomic particles and has many practical applications in fields such as chemistry and materials science.
What is the difference between the time-dependent and time-independent Schrödinger equations?
The time-dependent Schrödinger equation describes how a quantum system changes over time, while the time-independent Schrödinger equation describes the stationary states of a quantum system, where the system's behavior does not change over time. Both equations are important in quantum mechanics and are used in different contexts.
Can the Schrödinger equation be solved exactly?
In most cases, the Schrödinger equation cannot be solved exactly due to the complexity of the equations and the large number of variables involved. However, in some simple systems, such as the hydrogen atom, exact solutions can be found.
How is the Schrödinger equation related to the uncertainty principle?
The Schrödinger equation describes the probability of finding a particle in a certain state, rather than its exact position or momentum. This is related to the uncertainty principle, which states that it is impossible to know both the position and momentum of a particle simultaneously with complete accuracy. The Schrödinger equation allows us to calculate the probability of a particle's position and momentum, which is consistent with the uncertainty principle.
