Schutz GR Book, Question about World line.
In summary, the diagram on page 5 of B.Schutz's "A First Course in General Relativity" 2nd Edition shows a spacetime diagram in natural units with the vertical axis representing time (t) and the horizontal axis representing distance (x). The slope of a world line, which represents the path of a particle moving with velocity v, is equal to dt/dx and is given by the equation 1/v. When v=1 (the speed of light), the slope is positive at 45 degrees. When v>1, the slope is positive but less than 45 degrees. The world line for |v|<1 has a negative slope, going from upper left to lower right, because there are
Lou Arnold
This isn't homework, nor is it an exercise problem; merely a question about a diagram.
Re: B.Schutz book "A First Course in General Relativity" 2nd Edition, (Asian print version), page 5, Figure 1.1 "A spacetime diagram in natural units".
From section 1.4 Spacetime diagrams:
A world line is the locus of events observed by the reference frame as a particle moves with velocity v.
The vertical axis is t. The horizontal axis is x.
The equation is: slope=dt/dx = 1/v where v=1 is the speed of light.
When v=1, the slope of the world line is positive at 45 degrees. When v>1, the slope is positive but less than 45 degrees.
Q: The World line for |v|<1 has a negative slope - goes from upper left to lower right. Can someone explain why this slope is negative and why not positive greater than 45 degrees?
Lou.
Welcome to PF.
Suppose that you wish to draw a world line corresponding to |v| = .5, which is an example of |v| < 1. There are two possible values of v that satisfy |v| = .5; namely, v = +.5 and v = -.5. So, if you wanted to draw a world line that satisfies |v| = .5, you have a choice of drawing a line with a positive slope of 2 or a line with a negative slope of -2. Either line would make an angle with respect to the x-axis that has a magnitude greater than 45o. Schutz chose to draw a line corresponding to the negative value of v that satisfies |v| < 1.
I understand your logic. Not very kind of Schutz to omit that small explanation
Thanks for your help.
I see dizzying notation coming in the next sections. I may need more help.
FAQ: Schutz GR Book, Question about World line.
What is the Schutz GR Book?
The Schutz GR Book is a textbook on general relativity written by Bernard F. Schutz. It provides an introduction to the theory of relativity and its applications in physics and cosmology.
What does "GR" stand for in Schutz GR Book?
"GR" stands for general relativity, which is a theory of gravitation developed by Albert Einstein. It is a fundamental theory in physics that explains the effects of gravity on massive objects.
What is a world line?
A world line is a path traced by an object or a particle through space and time. It represents the history of an object's motion in four-dimensional spacetime.
How does Schutz GR Book explain world lines?
The Schutz GR Book explains world lines in the context of general relativity. It discusses the concept of spacetime curvature and how it affects the motion of objects, leading to the formation of world lines.
Is the Schutz GR Book suitable for beginners?
The Schutz GR Book is a comprehensive textbook that is suitable for both beginners and advanced readers. It provides a clear and accessible explanation of general relativity and its applications, making it a valuable resource for anyone interested in the subject.
