I Schwartz derivation of the Feynman rules for scalar fields
eoghan
TL;DR Summary
Justify why the fields die off at infinite time, and why the interaction vacuum can be exchanged with the free vacuum.
Hi everyone,
In his book "Quantum field theory and the standard model", Schwartz derives the position-space Feynman rules starting from the Schwinger-Dyson formula (section 7.1.1). I have two questions about his derivation.
1) As a first step, he rewrites the correlation function as
\langle\Omega\vert\phi_1\phi_2\vert\Omega\rangle = i\int d^4x (\Box_xD_{x1})\langle\Omega\vert\phi_x\phi_2\vert\Omega\rangle = i\int d^4x D_{x1}\Box_x\langle\Omega\vert\phi_x\phi_2\vert\Omega\rangle
where ##D_{x1}## is the Feynman propagator, such that ##\Box_xD_{x1}=-i\delta_{x1}##
In the last step, he integrated by parts supposing that the term ##D_{x1}\langle\Omega\vert\phi_x\phi_2\vert\Omega\rangle## disappears on the boundary of the integration domain.
However, previously while deriving the LSZ formula (section 6.1, just before Eq 6.9), he notes "we will obviously have to be careful about boundary conditions at ##t=\pm\infty##. However, we can safely assume that the fields die off at ##\vec x=\pm\infty##, allowing us to integrate by parts in ##\vec x##". Shouldn't this apply also for the present derivation? I mean, how can we justify that ##D_{x1}\langle\Omega\vert\phi_x\phi_2\vert\Omega\rangle## dies off also at the time boundary?
2) In computing the two points correlation function in the presence of interaction, Schwartz notices that ##\langle\Omega\vert\phi_1\phi_2\vert\Omega\rangle## contains a term ##g^2\langle\Omega\vert\phi^2_x\phi^2_y\vert\Omega\rangle## (Eq 7.19). Since we are interested only in order ##g^2##, he says that we should use the free field result for ##\langle\Omega\vert\phi^2_x\phi^2_y\vert\Omega\rangle##. This makes sense, but in the free field, the empty state is ##\vert 0\rangle\neq \vert\Omega\rangle##. And indeed, later on he shows that between ##\vert\Omega\rangle## and ##\vert 0\rangle## there is a factor proportional to the exponential of the interaction potential (Eq 7.53 and following).
Of course, his strategy of considering the interacting and free vacuum equal is correct, because the final result is correct. But I do not see how it can be justified.
Shouldn't we have to take into account the exponentials in Eq 7.19? Or am I missing something?Thank you in advance!
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
