Schwarzschild geometry unstable orbit GR question
In summary, In this geometry the derivative of the effective potential goes to zero at two places. One is a stable equilibrium and the other is unstable. The unstable r value for circular orbits occurs at r_{max} = \frac{l^2}{2 M}( 1-\sqrt{1-12 (\frac{M}{l}) ^2}) while the goal is to show that when this orbit is perturbed in the radial direction that the perturbation grows exponentialy. The key observation that tells us the orbit is unstable is that when the potential is expanded around the unstable equilibrium point, the left hand side goes to zero and the equation of motion is a differential equation for r (or the perturbation delta r
Allday
164
Hey folks,
working problems in Hartle's GR book and having trouble with this one. Chapter 9 discusses the simplest physically relavent curved geometry, that of Mr. Swarzschild
[tex] ds^s = -(1 - \frac{2 G M}{r}) dt^2
+ (1 - \frac{2 M}{r})^{-1} dr^2
+r^2(d\theta^2 + sin^2\theta d\phi^2) [/tex]
In this geometry the derivative of the effective potential goes to zero at two places. one is a stable equilibrium and the other is unstable.
[tex]
V_{eff} = -\frac{M}{r} + \frac{l^2}{2 r^2} - \frac{M L^2}{r^3}
[/tex]
the unstable r value for circular orbits occurs at
[tex]
[/tex]
[tex]
\delta_{r} \propto e^{\tau / \tau_*}
[/tex]
where [tex] \tau_* [/tex] is some constant
we also have a constant related to the conserved energy per unit rest mass to take advantage of
[tex]
\epsilon=\frac{1}{2}(\frac{dr}{d\tau})^2+V_{eff}(r)
[/tex]
i know that the derivative above will determine how this pertubation will grow and that
[tex] \epsilon - V_{eff} = 0 [/tex]
for circular orbits at the unstable r. I've tried expanding the potential around this unstable equilibrium point which yields derivatives of V multiplied by the deltar under a square root for the derivative but I can't see how to connect this to the exponential form of the proper time.
If you expand the effective potential around the unstable equilibrium radius [tex] r* [/tex] you find the following form for the effective energy equation:
[tex]
\epsilon = \frac{1}{2}\left(\frac{dr}{d\tau} \right) + V_{eff}(r*) + \frac{1}{2} \frac{d^2 V_{eff}(r*)}{dr^2}(r-r*)^2.
[/tex]
Let me ask you, what is the key observation that tells us the orbit is unstable?
To find an expression for [tex] \tau_* [/tex] and obtain the exponential dependence, try differentiating the effective energy conservation equation with respect to [tex] \tau [/tex] to obtain the equation of motion. What is the solution of the resulting differential equation?
Hi Physics Monkey,
the fact that we are looking at an unstable equuilibrium means the first derivative of the potential is 0 and that the second derivative is negative. I've done the expansion and now differentiated wrt to tau. Assuming that the energy remains constant during the perturbation the left hand side will go to zero leaving,
[tex]
\frac{d^2\delta_r}{d\tau^2} + \frac{d^2V}{dr^2}\frac{d\delta_r}{d\tau}=0
[/tex]
this is a differential equation for r (or the perturbation delta r) with an exponential solution. solving for the constant [tex] \tau^* [/tex] I get that it is equal to
[tex]
\frac{1}{\tau^*}=-\frac{d^2V}{dr^2}
[/tex]
which is positive because the derivative itself is negative. this is reasonable and leads to plunging in for negative pertubations and escaping to infinity for positive pertubations. thanks for the help.
Hi Allday,
You're on the right track but you still have a few mistakes. When differentiating the energy equation and finding the equation of motion, you should obtain
[tex]
\frac{d^2 \delta}{d\tau^2}\frac{d \delta}{d \tau} + \frac{d^2 V}{d r^2} \delta \frac{d \delta}{d \tau} = 0,
[/tex]
so there is a small mistake in your equation. Cancelling the velocity from both terms, you find the equation of motion
[tex]
\frac{d^2 \delta}{d\tau^2} = -\frac{d^2 V}{d r^2}\delta},
[/tex]
which you correctly indicate has exponential solutions. However, you have the time constant wrong. Think about the dimensions of [tex] 1/\tau_* [/tex] and [tex] d^2 V/dr^2 [/tex] (remember that we are using geometric units here and V is dimensionless). You're very close however.
[tex]
\epsilon = \frac{1}{2}\left(\frac{dr}{d\tau} \right) + V_{eff}(r*) + \frac{1}{2} \frac{d^2 V_{eff}(r*)}{dr^2}\delta^2_r
[/tex].
[tex] \frac{d\epsilon}{d\tau}=0 [/tex]
Because [tex] \delta_r [/tex] = [tex]r - r^* [/tex]
that means [tex] r = \delta_r + r^* [/tex]
and that means the only difference between [tex] \delta_r [/tex] and r is the constant [tex] r^* [/tex] and either will do in the derivative.
[tex] \frac{d}{d\tau}\frac{d\delta_r}{d\tau} = \frac{d^2\delta_r}{d\tau^2} [/tex]
V and its derivatives evaluated at [tex] r^* [/tex] are constants and so don't contribute to the derivatives.
using the product rule,
[tex] \frac{d\delta^2_r(\tau)}{d\tau} = 2 \delta_r \frac{d\delta_r}{d\tau} [/tex]
therefore it looks like
[tex] \frac{d^2\delta_r}{d\tau^2} = -2 \delta_r \frac{d^2V(r^*)}{dr^2} \frac{d\delta_r}{d\tau} [/tex]
where am i going wrong?
You forgot the 1/2 in front of the second derivative of the potential. Also, the derivative of [tex] \frac{1}{2}\left( \frac{d \delta }{d \tau} \right)^2 [/tex] with respect to tau is [tex] \frac{d^2 \delta}{d\tau^2}\frac{d \delta}{d\tau} [/tex] (use the chain rule).
Ahhhhh got it
hey physics monkey, finally got around to finishing up. I realized what you were saying about the units (havent quite gotten used to checking dimensionality in geometrized units but now that I've looked at it, it seems much simpler...almost everything has the same units!) looks as if the time constant should be inversly proportional to the square root of the second derivative of the potential giving units of 1/time on the left and 1/length on the right which are measured in the same units. pretty sure this is right, thanks for your help
Gabe
Related to Schwarzschild geometry unstable orbit GR question
1. What is Schwarzschild geometry?
Schwarzschild geometry is a mathematical model used to describe the curvature of spacetime around a non-rotating, spherically symmetric mass. It is a key concept in the theory of general relativity and is named after the German physicist Karl Schwarzschild.
2. What is an unstable orbit in Schwarzschild geometry?
An unstable orbit in Schwarzschild geometry refers to a trajectory of an object in which it moves towards a central mass, but is not able to maintain a circular orbit due to the strong gravitational pull. The object may either fall into the mass or escape from it, depending on its initial velocity.
3. How is general relativity related to Schwarzschild geometry?
General relativity, a theory of gravity proposed by Albert Einstein, provides the mathematical framework for understanding the curvature of spacetime in Schwarzschild geometry. In this theory, the presence of mass and energy curves the fabric of spacetime, causing objects to follow curved paths.
4. What is the significance of unstable orbits in Schwarzschild geometry?
The concept of unstable orbits in Schwarzschild geometry has important implications in understanding the behavior of objects in the vicinity of massive objects such as black holes. It also helps us to better understand the effects of strong gravitational fields on the motion of celestial bodies.
5. Can unstable orbits in Schwarzschild geometry be stable under certain conditions?
Yes, under certain conditions, unstable orbits in Schwarzschild geometry can become stable. This can occur when the object's initial velocity is precisely adjusted to compensate for the strong gravitational pull, allowing it to maintain a circular orbit. This is known as a stable circular orbit or a "gravitational sweet spot".
