PeterDonis
Mentor
- 49,110
- 25,184
kent davidge said:You are arriving at this conclusion by assuming KrK^r vanishes, which is not a priori thing.
Yes, here I am only considering the case where ##K^t## is the only nonzero component. As I said at the end of that post, I'm going to refrain for now from explicitly considering the other cases and showing how they are eliminated.
kent davidge said:By checking the non trivial field of my post #42 you will see that it satisfies the Killing equations.
Ok, let's check. Since you wrote it with lower indexes, we can leave out the index lowering. So we have:
K_t = \sqrt{1- \frac{2m}{r}} \frac{mt}{r^2}
K_r = \sqrt{ \frac{1}{1- \frac{2m}{r}}}
The third Killing equation becomes
\partial_t K_r + \partial_r K_t - 2 \Gamma^t{}_{tr} K_t = 0 + \sqrt{ \frac{1}{1- \frac{2m}{r}}} \left( \frac{m}{r^2} \right) \frac{mt}{r^2} - \sqrt{1- \frac{2m}{r}} \frac{mt}{r^3} - 2 \frac{m}{r^2 \left( 1 - \frac{2m}{r} \right)} \sqrt{1- \frac{2m}{r}} \frac{mt}{r^2}
This does not all cancel out to zero, so the Killing equation is not satisfied.
I strongly suggest that you very, very carefully check your work. The fact that ##(1, 0)## is the only Killing vector field in the ##t-r## plane of Schwarzschild spacetime has been well known for decades and proving it is often assigned as a textbook problem. You should not be persisting in claiming that there are others; you should be looking for where you made a mistake.
