Schwarzschild Radius of Masses Other Than Black Holes
In summary, the Schwarzschild Radius is a critical radius calculated from the mass of a spherically symmetric object, where if the object's radius is smaller than the Schwarzschild radius, it becomes a black hole. However, for objects larger than their Schwarzschild radius, the radius has no physical significance. The wikipedia article mentioned that the sun has a radius of 3km, but this does not mean that the sun is a black hole, as its radius is larger than its Schwarzschild radius.
FanticalZappy
Recently I have been researching black holes, and came across the "Schwarzschild Radius". The wikipedia page on Schwarzschild radius's mentioned that the Sun has a radius of 3km. If that is so, then how can that be so, as that would mean that light cannot escape it.
So when it said "3km", did they mean that the radius was 3km, or that the radius is 3km larger than that of the sun?
- James
Edit: This is my first post and I am not used to the way forums work, so if i have gotten something wrong then please excuse me.
First, this is a subject under General Relativity not Quantum Mechanics.
Second, consider an object with mass m. It can have any shape. Schwarzschild Radius is the radius of a sphere that if that sphere with that radius had the mass m, then it would become a black hole. It is in fact the critical radius which means any radius smaller than Schwarzschild Radius has the same property.
It's neither.
The Schwatzchild radius is a quantity calculated from the mass of a spherically symmetric object. If the radius of the object is smaller than the Schwarzschild radius, it becomes a black hole with the event horizon at the Schwarzschild radius. However if (like the sun) the object is larger than its Schwarzschild radius, the Schwarzschild radius has no physical significance.
Thus, you can interpret the wikipedia article as saying that the sun isn't a black hole, but if it were, it would be only 6 km across.
Related to Schwarzschild Radius of Masses Other Than Black Holes
1. What is the Schwarzschild Radius of mass other than black holes?
The Schwarzschild Radius is a measure of the size of the event horizon of a black hole. However, it can also be calculated for any object with mass, not just black holes.
2. How is the Schwarzschild Radius calculated for masses other than black holes?
The Schwarzschild Radius is calculated using the equation R = 2GM/c^2, where R is the radius, G is the gravitational constant, M is the mass of the object, and c is the speed of light. This equation is based on Einstein's theory of general relativity.
3. Can the Schwarzschild Radius be measured for objects other than black holes?
Yes, the Schwarzschild Radius can be calculated for any object with mass. However, it may be too small to be measured directly for most objects, as it is proportional to the mass of the object. Only extremely massive objects, such as neutron stars, may have a Schwarzschild Radius large enough to be measurable.
4. How does the Schwarzschild Radius affect the behavior of objects with mass?
The Schwarzschild Radius represents the point at which the gravitational pull of an object becomes so strong that not even light can escape. This means that any object within the Schwarzschild Radius will be pulled towards the center of the object, and cannot escape. This is why black holes are often described as having an "infinite" gravitational pull.
5. Is the Schwarzschild Radius the same for all objects with the same mass?
Yes, the Schwarzschild Radius is directly proportional to the mass of the object. This means that two objects with the same mass will have the same Schwarzschild Radius, regardless of their composition or density. However, the Schwarzschild Radius may vary for objects with significantly different masses.
