Schwarzschild radius question.
In summary, when an object is accelerated close to the speed of light, there is a causal connection between it and an observer. However, if the observer accelerates away from the object, they will eventually lose this connection. The C-metric represents this scenario and shows that a uniformly accelerating black hole can have both a Schwarzschild horizon and a Rindler horizon. This means that from an observer's point of view, no black holes will form.
Katamari
An object is accelerated close to c. Does the relativistic mass contribute to the sch. radius as seen by an observer? Is it simultaneously a black hole and not a black hole?
Suppose something is traveling at close to c as measured by some observer. As long as the relative velocity is constant, there will be a causal connection between them. That means light signals can pass between them.
However if one observer accelerates away from another, with constant (local) acceleration, eventually they will lose causal contact. See the 'Rindler Horizon'.
But no black holes will form from any observers point of view.
Thanks.
There is an exact solution of Einstein's equations known as the C-metric which represents the gravitational field of a uniformly accelerating black hole. It contains both a Scwharzschild horizon and a Rindler horizon.
Related to Schwarzschild radius question.
1. What is the Schwarzschild radius?
The Schwarzschild radius, also known as the gravitational radius, is a measure of the size of the event horizon of a black hole. It represents the distance from the center of the black hole at which the escape velocity equals the speed of light.
2. How is the Schwarzschild radius calculated?
The Schwarzschild radius can be calculated using the formula Rs = 2GM/c^2, where Rs is the Schwarzschild radius, G is the gravitational constant, M is the mass of the black hole, and c is the speed of light.
3. Can objects other than black holes have a Schwarzschild radius?
Yes, any object with a mass can have a Schwarzschild radius, but it is only significant for objects with extreme densities, such as black holes.
4. What happens at the Schwarzschild radius?
At the Schwarzschild radius, the escape velocity is equal to the speed of light, which means that anything that crosses this boundary will be unable to escape the gravitational pull of the black hole.
5. Can the Schwarzschild radius change?
Yes, the Schwarzschild radius can change if the mass of the black hole changes. As the mass increases, the Schwarzschild radius also increases, and vice versa.
