Schwinger effect verified by Unruh temperature?
In summary, the Schwinger effect, which is the creation of particle-antiparticle pairs in a strong electric field, has been verified by the Unruh temperature, which is the temperature experienced by an accelerating observer in empty space. This verification provides further evidence for the existence of the Schwinger effect and its connection to the Unruh effect.
jcap
170
According to https://arxiv.org/abs/1407.4569, equation (2.15), the Schwinger electron-positron pair production rate in Minkowski space, ##N_S##, is given in natural units by
$$N_S=\exp(-\frac{m}{2T_U})$$
where the `Unruh temperature for the accelerating charge', ##T_U##, is given by
$$T_U=\frac{1}{2\pi}\frac{qE}{m}$$
where ##q## is the electron charge, ##m## is the electron mass and ##E## is the applied electric field.
In principle, could the Schwinger effect be confirmed by measuring the temperature ##T_U## rather than trying to detect electron-positron pairs?
In SI Units:
$$T_U = \frac{1}{2\pi}\frac{\hbar}{c k_B}\frac{q E}{m}$$
If the static electric field ##E=1## MV/m then the Unruh temperature ##T_U\sim 10^{-3}##K.
Could one use laser cooling to cool atoms down to the millikelvin range and then apply a large electric field of say ##10^6## V/m? The atoms should warm up due to the Unruh temperature, ##T_U \sim 10^{-3}##K, induced by the static electric field. Perhaps this temperature rise would cause quantum decoherence that could then be detected?
(see https://en.wikipedia.org/wiki/Laser_cooling)
The relation between the Schwinger and Unruh effects is best thought of as a formal analogy. As first demonstrated by Nikishov, I believe, (see equation 11'), the probability that a pair is produced at a certain energy is given by what looks a lot like a thermal factor, so it's tempting to go ahead and define a temperature and say the produced particles are "at" that temperature. However, it's not a perfect analogy:
1. The energy comes squared in the formula, unlike a typical Boltzmann factor.
2. The pair distribution is degenerate with respect to the momentum component parallel to the electric field. This is because the Schwinger process is essentially a tunneling process, so that component is always zero at the "moment" of creation, and is subsequently accelerated by the field.
3. Unruh radiation is in a mixed state because Rindler space is divided in two wedges (so some information about the field is concealed from the observer, and in particular, those correlations that would permit them to identify the state as a vacuum state in disguise). This is at the heart of the thermal interpretation. In contrast, pairs produced by an electric background are indeed in a pure state.
So, in short, the analogy is cute but don't take it too seriously.
Likes Demystifier and jcap
LeandroMdO said:
3. Unruh radiation is in a mixed state because Rindler space is divided in two wedges. This is at the heart of the thermal interpretation. In contrast, pairs produced by an electric background are indeed in a pure state.
Perhaps the background Unruh-like radiation is thermal even though the particle pairs themselves (if any are produced) are in a pure state.
You can see clearly in the Heisenberg picture that it must be a pure state. You set up the theory in the vacuum state and what changes due to the applied electric field are the creation and annihilation operators. After some time you can turn off the electric field, and you find that the theory is no longer in the vacuum state with respect to the new creation and annihilation operators. But it's still very much the vacuum state with respect to the original ones.
There is some subtlety in the Unruh case because the Rindler space is divided into wedges. No such subtlety arises in the electric field calculation. There is no "background Unruh-like radiation". As I said, it's just a formal analogy.
Related to Schwinger effect verified by Unruh temperature?
1. What is the Schwinger effect?
The Schwinger effect refers to the phenomenon of particle creation in the presence of a strong electric field. This effect was first predicted by physicist Julian Schwinger in 1951, and has since been verified through various experiments and theoretical calculations.
2. What is Unruh temperature?
Unruh temperature is a theoretical concept proposed by physicist William Unruh in 1976. It refers to the temperature that an accelerating observer would experience in a vacuum. This concept is based on the idea that acceleration can produce radiation, similar to how temperature produces thermal radiation.
3. How are the Schwinger effect and Unruh temperature related?
The Schwinger effect and Unruh temperature are related through the concept of particle creation in the presence of a strong electric field. The Unruh temperature provides a theoretical framework for understanding how the Schwinger effect occurs.
4. How was the Schwinger effect verified by Unruh temperature?
The Schwinger effect has been verified through various experiments and theoretical calculations. One key experiment involved using a super-strong laser to create a strong electric field, which resulted in the creation of electron-positron pairs. These results were in line with the predictions of the Schwinger effect and further supported the concept of Unruh temperature.
5. What are the implications of the Schwinger effect being verified by Unruh temperature?
The verification of the Schwinger effect by Unruh temperature has significant implications for our understanding of quantum field theory and the nature of vacuum. It also has potential applications in fields such as nuclear and particle physics, as well as in the development of new technologies such as particle accelerators.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
