Science Project on the Photoelectric Effect
In summary, Bobby is doing a science project on the photoelectric effect. He needs to measure the free electrons produced, and he suggests using a circuit with an anode plate and a cathode plate with an electrical field between the two, hooked up to an electrometer.
beatlemaniacj
49
I am doing a science project on the photo electric effect (the experiment is the correlation between frequency, intensity, and electrons released.) My one problem is that I need some way to measure the free electrons. I was thinking a simple circuit with an anode plate and a cathode plate with an electrical field between the two, hooked up to an electrometer. The free electrons produced would get attracted to the cathode and would affect the reading of the electrometer. Does this sound like a viable experiment?
You would need to do it in a vacuum.
beatlemaniacj,
I suggest you study the photoelectric effect first, and then decide on your science project. Here are two sites you can visit to get started. Also, check out the Hammatsu Handbook...it is an excellent guide to the correlations between frequency, intensity, etc. Good luck!
Bobbywhy
I know about the photoelectric effect. This is for a school science fair. I thought it would be an interesting project. As for the vacuum, wouldn't the electrostatic attraction propel the particles?
NascentOxygen is correct: You will need a vacuum. Electrons will not pass easily through air. You are correct: electrostatic potential can attract and move electric charges through air. Just experiment with a Van de Graf generator. You can charge up an object across a large air gap. But that would NOT demonstrate the photoelectric effect. But, of course, you already know about that.
Oops, I forgot to include a few references in an earlier post about your project. Excuse my forgetfulness. Below are three sites that you may find useful. The first two are technical explanations with descriptions of the science behind the photoelectric effect. But since you say you already know about the photoelectric effect you may just ignore them. The third one is an example of a real project similar to the one you are proposing.
http://en.wikipedia.org/wiki/Photomultiplier
http://en.wikipedia.org/wiki/Work_function
http://www.education.com/science-fair/article/photoelectric-effect/
My experiment involves parallel plates. Some of the electrons, hopefully will get attracted to the anode and register on the voltmeter. Not all of them need to. Just to show the ratios and such.
Related to Science Project on the Photoelectric Effect
1. What is the photoelectric effect?
The photoelectric effect is a phenomenon in which electrons are emitted from the surface of a material when it is exposed to light of a certain frequency.
2. What is the significance of the photoelectric effect?
The photoelectric effect provides evidence for the particle nature of light and led to the development of quantum mechanics. It also has practical applications in technologies such as solar cells and photoelectric sensors.
3. How does the photoelectric effect work?
When a photon of light hits the surface of a material, it transfers its energy to an electron. If the energy of the photon is greater than the work function (the minimum energy required to remove an electron from the surface), the electron will be emitted. This process is repeated for each photon, resulting in a flow of electrons.
4. What factors affect the photoelectric effect?
The intensity and frequency of the light, as well as the properties of the material such as its work function and surface area, can all affect the photoelectric effect.
5. How is the photoelectric effect used in everyday life?
The photoelectric effect is used in many technologies, including solar cells, photocells, and photoelectric sensors. It is also used in some medical imaging techniques, such as X-ray machines, and in the production of electronic devices.
