Sciene fair project, freefall stuff - need one equation for time
In summary, the conversation discusses a science fair project on tennis ball bounce height and finding the force it hits the ground with. The calculations done involve the mass, acceleration, and height of the drop, as well as equations for time, velocity, and impact force. The issue of air resistance and accurately measuring the time and duration of the collision is also mentioned.
Gumbosplat
Ok, so I'm doing this science fair project on tennis ball bounce hieght, and I have to find the force that it hits the ground with. I'm trying to do this mathematically, because I can't record the time accurately in the actual experiment.
The mass of the ball is 0.0567kg, the acceleration is just gravity, 9.8m/s/s, and the height of the drop varies; 0.2m, 0.4m, 0.6m, and 1m.
I just need to know how to calculate time, but I'm not sure what the equation is. I tried t=√2d/a, but that gives me very weird results.
t=√2d/a (?)
v=d/t
F=m(Δv/Δt)
so for the 0.2m height, I did these calculations.
d=0.2m
a=9.8m/s/s
m=0.0567kg
t=√2d/a
t=√0.4m/9.8m/s/s
t=√0.40s/s
t=0.2s
v=d/t
v=0.2m/0.2s
v=1m/s
F=m(Δv/Δt)
F=0.0567kg(1m/s /0.2s)
F=0.0567kg(5.0m/s/s)
F=0.284N
and for the 0.4m height, I did
d=0.4m
a=9.8m/s/s
m=0.0567kg
t=√2d/a
t=√0.8m/9.8m/s/s
t=√0.08s/s
t=0.894s
v=d/t
v=0.4m/0.894s
v=0.447m/s
but that doesn't make sense! how can the velocity be less from a greater height? I feel like I'm doing the time equation wrong, and I've looked everywhere online and can't find a reliable time from distance and acceleration equation. This is driving me crazy, please help! Also, am I calculating impact force correctly?
Welcome to PF!
The first part where you find t = 0.2 s is correct.
After you use v = d/t things go wild because v= d/t does not apply to accelerated motion.
Use v = a*t to find the final velocity.
Air resistance may be significant with a tennis ball. Have you thought of taking a movie of the bouncing ball with a clock or stopwatch in the picture? You should be able to get a pretty accurate record of the distance and time that way.
Don't confuse the time it takes for the ball to drop (which is easy to calculate using freefall equations) with the duration of the collision with the ground (not so easy to calculate). You'll have to poke around to see if you can get estimates of the latter.
Delphi51 said:
Welcome to PF!
Thank you so much! Now I have to kick myself all day for forgetting the velocity formula, you really just made my day, though.
Are you sure that the air resistance would be significant at this small of a height?
Hint:
You have already computed the time it takes for the ball to reach the ground. If you were to measure how high the ball bounces, you can determine the time it took to reach that altitude. Now if you timed the entire trip, you can perform some other calculations that would lead you to an estimate of the average force on the ground.
LawrenceC said:
Hint:
Measuring the bounce height is part of my experiment, and I have recorded those heights. Do you mean you can't find the force without factoring in the total time? I thought that you could just use F=m(Δv/Δt) for just the way down, would this be inaccurate?
That would tell you the force acting while the ball is falling--but you already know that. It's just the weight of the ball. (In fact that would be circular reasoning, since you used the fact that it's in free fall to calculate the time.)
To find the force during the collision, you need the time of the collision. LawrenceC has an interesting idea for measuring that collision time, but I suspect it won't work in practice since the collision time will be too small. But worth a shot!
Hm, I don't think I can measure that accurately...
I wonder, could I use F=(mv)/t of this?
That's equivalent to what you've already tried.
Is there an equation I should be using? I'm really at a loss as to what to even begin with.
I'm going to calculate KE, and then force from that
If you can estimate how much the ball compresses during its collision with the floor, you can calculate the average force from that.
Posting new calculations for 0.2m
d=0.2m
a=9.8m/s/s
m=0.0567kg
t=√2d/a
t=√0.4m/9.8m/s/s
t=√0.04s/s
t=0.2s
v=at
v=9.8m/s/s*0.2s
v=1.96m/s
KE=1/2 m v^2
KE=0.028kg*3.841m^2/s^2
KE=0.108J
How would I be able to estimate that? I'm not able to actually measure that, and I don't know how to calculate that anyway.
Could I also base force calculations off of the distance traveled into the ground after collision? I'd estimate that to be around 0.0001m on a hardwood floor, just a guess.
You should be able to SEE the compression of the ball on a video of it hitting the floor. You could repeat it a few times to get a better picture. Even a cell phone video might be good enough. Then measure what force is needed to compress the ball to the same compression you see in the video. Measurements are needed because theoretical methods depend on the nature of the ball.
I think a measurement of the duration of the ball's collision with the floor would be more useful. From that, you could use the impulse formula to calculate the average force.
Related to Sciene fair project, freefall stuff - need one equation for time
1. What is a science fair project?
A science fair project is an experiment or investigation that is conducted by students to explore a scientific concept or question. It typically involves following the scientific method to formulate a hypothesis, design and conduct an experiment, analyze data, and draw conclusions.
2. What is freefall?
Freefall is the motion of an object under the influence of gravity only, with no other external forces acting on it. In freefall, the object is accelerating towards the ground at a constant rate of 9.8 m/s².
3. What is the equation for time in freefall?
The equation for time in freefall is t = √(2h/g), where t is the time in seconds, h is the height in meters, and g is the acceleration due to gravity (9.8 m/s²).
4. How can I use the equation for time in freefall in my science fair project?
The equation for time in freefall can be used to calculate the time it takes for an object to fall from a certain height. This can be incorporated into your project by measuring the height of an object, dropping it, and then using the equation to calculate the expected time of fall. You can then compare this to your actual results and analyze any discrepancies.
5. Can the equation for time in freefall be used for objects with different masses?
Yes, the equation for time in freefall can be used for objects with different masses as long as they are dropped from the same height. This is because the mass of an object does not affect its acceleration due to gravity. However, if air resistance is a factor, the equation may not be as accurate for objects with different masses.
