Scientific notation, and an exponent question
In summary, scientific notation is a compact way of writing very large or very small numbers by representing them as a decimal number between 1 and 10 multiplied by a power of 10. To convert a number into scientific notation, move the decimal point and use the number of places as the exponent. The purpose of using scientific notation is to easily express and compare numbers with different magnitudes. To perform operations with numbers in scientific notation, convert both numbers into the same power of 10 and use the same power of 10 as the final answer's exponent. The exponent in scientific notation will always be a whole number since it represents the number of times the decimal point was moved to get the new number.
Tyrion101
166
I'm curious but usually negative exponents mean you're going to put those numbers on the bottom (sorry forgot the exact term it is much earlier than I normally get up) (example 6^-1 =1/6 so why is scientific notation different? Or is it? (Ex: 5x10^-3=.005)
Mathematics news on Phys.org
Scientific notation works the same way. [itex] 5 \cdot 10^{-3}=\frac{5}{10^3}=.005 [/itex]
The term you are looking for may be "denominator".
So I'm just not thinking about it in the right way. The fraction should have been a clue perhaps?
Related to Scientific notation, and an exponent question
1. What is scientific notation?
Scientific notation is a way of writing numbers that are very large or very small in a more compact form. It involves representing a number as a product of a decimal number between 1 and 10 and a power of 10.
2. How do you convert a number into scientific notation?
To convert a number into scientific notation, move the decimal point to the right or left until there is only one non-zero digit to the left of the decimal point. This new number will be the decimal number in scientific notation, and the number of places you moved the decimal point will be the exponent.
3. What is the purpose of using scientific notation?
Using scientific notation allows us to express numbers that are too large or too small to be easily written or understood in standard decimal notation. It also makes it easier to perform calculations and compare numbers with different magnitudes.
4. How do you perform operations with numbers in scientific notation?
To perform operations with numbers in scientific notation, you must first convert both numbers into the same power of 10. Then, you can add, subtract, multiply, or divide the decimal numbers, and use the same power of 10 as the final answer's exponent.
5. Why is the exponent in scientific notation always a whole number?
The exponent in scientific notation represents the number of times the decimal point was moved to the left or right to get the new number. Since moving the decimal point always involves multiplying or dividing by powers of 10, the exponent will always be a whole number in scientific notation.
  • General Math
  • Science and Math Textbooks
  • General Math
  • General Math
  • General Math
