Scientists engineer E. coli that eats carbon dioxide
In summary, researchers have engineered E. coli to be able to generate all of its carbon from CO2, making it a potential replacement for petrochemicals in manufacturing. This was achieved by re-engineering the bacterium's metabolism and introducing new enzymes that allowed it to convert CO2 into sugars and other organic compounds. The use of formate as an energy source and electrochemical production of CO2 made this process possible. This work represents a significant step towards a more sustainable future and is a proof of concept for a new technology.
Ygggdrasil
Insights Author
4,199
E. coli is one of the best studied and most widely used bacteria in biotechnology. This week, published in the journal Cell, researchers report having engineered the bacterium to be able to generate all of its carbon from CO2, opening the way toward using these bacteria for replacement of petrochemicals in manufacturing.
So, Ron Milo, a synthetic biologist at the Weizmann Institute of Science in Rehovot, Israel, and his colleagues decided to see whether they could transform E. coli into an autotroph. To do so, they re-engineered two essential parts of the bacterium’s metabolism: how it gets energy and what source of carbon it uses to grow.
On the energy side, the researchers couldn’t give the bacterium the ability to carry out photosynthesis, because the process is too complex. Instead, they inserted the gene for an enzyme that enabled the microbe to eat formate, one of the simplest carbon-containing compounds, and one other strains of E. coli can’t eat. The microbes could then transform the formate into ATP, an energy-rich molecule that cells can use. That diet gave the microbe the energy it needed to use the second batch of three new enzymes it received—all of which enabled it to convert CO2 into sugars and other organic molecules. The researchers also deleted several enzymes the bacterium normally uses for metabolism, forcing it to depend on the new diet to grow.
https://www.sciencemag.org/news/201...-eat-food-grow-thanks-bit-genetic-engineering
Here is a diagram summarizing the metabolism of the engineered microbe:
The scientists chose to use formate as the energy source for the bacteria because formate can be prodcued electrochemically from CO2. Therefore, when combined with a carbon-free source of electricity, the bacteria could be used to generate carbon-based compounds without net carbon emissions.
Previous work had generated bacteria which could incorporate a limited amount of CO2 into its biomass, but this work represents the first example where essentially all of the carbon in the bacteria comes from CO2. Generating the bacteria involved a clever combination of well thought out rational changes to the metabolism of the bacteria combined with directed evolution to introduce additional changes in the bacteria to actually get them to work as intended.
Citation to published research:
Gleizer et al. Conversion of Escherichia coli to Generate All Biomass Carbon from CO2. Cell 179: 1255 (2019)
https://www.cell.com/cell/fulltext/S0092-8674(19)31230-9
Abstract:
The living world is largely divided into autotrophs that convert CO2 into biomass and heterotrophs that consume organic compounds. In spite of widespread interest in renewable energy storage and more sustainable food production, the engineering of industrially relevant heterotrophic model organisms to use CO2 as their sole carbon source has so far remained an outstanding challenge. Here, we report the achievement of this transformation on laboratory timescales. We constructed and evolved Escherichia coli to produce all its biomass carbon from CO2. Reducing power and energy, but not carbon, are supplied via the one-carbon molecule formate, which can be produced electrochemically. Rubisco and phosphoribulokinase were co-expressed with formate dehydrogenase to enable CO2 fixation and reduction via the Calvin-Benson-Bassham cycle. Autotrophic growth was achieved following several months of continuous laboratory evolution in a chemostat under intensifying organic carbon limitation and confirmed via isotopic labeling.
Likes ChemAir, Choppy, epenguin and 7 others
Biology news on Phys.org
Hybrid electrochemical-biological carbon fixation cycle is very unlikely to be economical. More likely outcome is what elecetrochemical cycle will be improved to produce more useful products which can be used directly - i.e. formaldehyde in short term.
Likes mfb
I don’t think that this is intended to be a commercial product. It seems like more of a test bed for a new technology. In particular the microbes seem deliberately limited simply to prove that all of the biomass came from CO2. The idea of a tailored or designed metabolism is impressive.
Likes jim mcnamara and trurle
I think the term may be 'proof of concept' more than anything else.
Likes Dale
Related to Scientists engineer E. coli that eats carbon dioxide
What is the significance of scientists engineering E. coli that eats carbon dioxide?
The significance of this engineering achievement is that it provides a potential solution to reducing carbon dioxide levels in the atmosphere, which is a major contributor to climate change. By using E. coli to consume carbon dioxide, it could potentially help mitigate the negative effects of greenhouse gas emissions.
How did scientists engineer E. coli to consume carbon dioxide?
The scientists used genetic engineering techniques to modify the E. coli's metabolic pathways. They inserted genes that allowed the bacteria to produce enzymes that could convert carbon dioxide into usable energy and biomass.
What are the potential applications of this engineered E. coli?
Aside from potentially reducing carbon dioxide levels in the atmosphere, this engineered E. coli could also have industrial applications. It could be used to produce biofuels or other useful chemicals from carbon dioxide, which would be a more sustainable and environmentally-friendly alternative to traditional methods.
Are there any potential risks associated with this engineering achievement?
As with any new technology, there are potential risks that need to be carefully considered. One concern is the possibility of unintended consequences if the engineered E. coli were to be released into the environment. There is also the risk of the bacteria mutating and potentially causing harm. These risks need to be thoroughly evaluated and addressed before any practical applications can be pursued.
What other methods are being explored to reduce carbon dioxide levels in the atmosphere?
There are various methods being explored, such as carbon capture and storage, reforestation, and renewable energy sources. Each method has its own advantages and limitations, and it is important to continue researching and developing a range of solutions to address the issue of climate change.
  • Biology and Medical
  • General Discussion
11K
  • Materials and Chemical Engineering
9K
