Scientists turn CO2 back into coal
In summary: Which other products are produced when sunlight and CO2 are combined?Some oxygen, water, carbon monoxide.Might this find its way to Mars to collect CO2 for an energy dense fuel.Will it run on hopes and dreams?The skepticism here just reflects the fact that this technique as is will not solve the problem of global warming alone. The energy requirements to reduce atmospheric CO2 in this manner are obviously enormous, but no one promised a direct solution. The key things that these researchers demonstrated is proof of principle, efficiency and scalability.
Auto-Didact
751
562
Climate rewind: Scientists turn carbon dioxide back into coal
Article said:
Researchers have used liquid metals to turn carbon dioxide back into solid coal, in a world-first breakthrough that could transform our approach to carbon capture and storage.
The research team led by RMIT University in Melbourne, Australia, have developed a new technique that can efficiently convert CO2 from a gas into solid particles of carbon.
Published in the journal Nature Communications, the research offers an alternative pathway for safely and permanently removing the greenhouse gas from our atmosphere.
The article says that this process takes place using a liquid metal catalyst at room temperature and is both efficient and scalable. The rest of the article can be read over at phys.org (link in title).
The published paper (open access) is here:
Esrafilzadeh et al. 2019, Room temperature CO2 reduction to solid carbon species on liquid metals featuring atomically thin ceria interfaces
Abstract said:
Negative carbon emission technologies are critical for ensuring a future stable climate. However, the gaseous state of CO2 does render the indefinite storage of this greenhouse gas challenging. Herein, we created a liquid metal electrocatalyst that contains metallic elemental cerium nanoparticles, which facilitates the electrochemical reduction of CO2 to layered solid carbonaceous species, at a low onset potential of −310 mV vs CO2/C. We exploited the formation of a cerium oxide catalyst at the liquid metal/electrolyte interface, which together with cerium nanoparticles, promoted the room temperature reduction of CO2. Due to the inhibition of van der Waals adhesion at the liquid interface, the electrode was remarkably resistant to deactivation via coking caused by solid carbonaceous species. The as-produced solid carbonaceous materials could be utilised for the fabrication of high-performance capacitor electrodes. Overall, this liquid metal enabled electrocatalytic process at room temperature may result in a viable negative emission technology.
Likes OmCheeto
An efficient way of turning sunlight and CO2 into coal might provide an easy way of transporting fuel to polar regions.
Likes russ_watters
Media. Hype.
An "efficient" method to reverse combustion just requires exactly as much energy be put back into it as you got out of it. Which does absolutely nothing for us as long as there is a single coal power plant in existence.
Likes nuuskur, Rive and Bystander
I have no problem with stuffing all the coal back down the mines - except I don't know where the energy will come from.
Likes russ_watters
So what else is produced besides the C(s) ?
some oxygen, water, carbon monoxide.
I couldn't find the gaseous off products.
Likes russ_watters and Rive
I see no good reason why a centuries long approach, utilizing both natural and artificial power sources - including those that we have yet to invent - could not lead to a wide-scale carbon recapture technology. It is usually better to let such a technology come from private industry instead of only from government funded research.
This means there needs to be an associated economic incentive - e.g. that such a technique leads to efficient production of precious fuels or compounds such as carbon nanotubes - which is both in high demand and easily scalable; consequently, such a scenario might, as a side effect, eventually lead to a significant reduction or even full resolution of the problem of global warming.
russ_watters said:
Media. Hype.
We need to establish selective enforcement for that pesky second law.
Likes Bystander and russ_watters
Related to Scientists turn CO2 back into coal
What is the process of turning CO2 back into coal?
The process of turning CO2 back into coal is known as carbon capture and storage (CCS). First, CO2 is captured from industrial emissions or directly from the atmosphere. Then, the captured CO2 is compressed and injected into underground geological formations, where it reacts with certain minerals to form solid carbonate compounds, essentially creating coal.
Why is turning CO2 back into coal important?
Turning CO2 back into coal is important because it helps to reduce the amount of greenhouse gases in the atmosphere. CO2 is a major contributor to climate change, and by converting it into solid coal, we are essentially storing it away for thousands of years and preventing it from contributing to global warming.
What are the potential benefits of turning CO2 back into coal?
The potential benefits of turning CO2 back into coal include reducing the amount of greenhouse gases in the atmosphere, mitigating the effects of climate change, and creating a new source of fuel for energy production. It can also help to reduce the environmental impact of industries that produce large amounts of CO2 emissions, such as power plants and factories.
Are there any risks or challenges associated with turning CO2 back into coal?
One potential risk of turning CO2 back into coal is the potential for leaks or accidents during the capture and storage process. There is also the challenge of finding suitable geological formations for storing the captured CO2. Additionally, there may be economic challenges in implementing large-scale CCS projects.
Is turning CO2 back into coal a sustainable solution for reducing greenhouse gas emissions?
While turning CO2 back into coal can help to reduce greenhouse gas emissions in the short term, it is not considered a sustainable long-term solution. It is important for industries and individuals to also focus on reducing their overall carbon footprint and transitioning to renewable energy sources to truly combat climate change.
