Screen Flicker and Windows update
In summary, the conversation discusses a problem with a laptop screen flickering and the possibility of it being caused by a Windows update. The individual tried a system restore and it temporarily solved the issue but it started again after another Windows update. They also mention trying to roll back the video driver but it did not work. The conversation then delves into possible solutions, such as only installing priority updates from Microsoft and getting video driver updates from the manufacturer's website. They also mention a specific issue with the Radeon X1300 series and offer a potential solution for a dual screen setup.
larkspur
515
Could a Windows update be causing my laptop screen to flicker? A few weeks ago, my laptop screen started to flicker. I did a system restore to an earlier time without the flicker and the flicker stopped. Today the flicker is back. There was also a Windows Automatic update.
Coincidence?
Computer science news on Phys.org
Probably coincidence, yes. Did you look for a more recent version for your video driver?
I just now tried that and now I can only start Windows in Safe mode...When I tried System Restore to undo the driver change I get a blue screen that flashes up too quickly to read, then the Windows start up screen comes up. After that, I get the choice to start up in safe mode, safe mode with networking, safe mode with command prompt, last known good config. etc.
What video card do you have?
You can try to use last known good config as a boot option and see what happens. Additionally, it is also possible that the windows update may have updated your driver and changed some of the display settings. Try and see if you can access your display properties in "normal mode".
My video card is an ATI Mobility Radeon X1300.
I tried all options but could only start Windows in safe mode. I reinstalled Windows and can now start it normally. The screen flicker started again after another Windows update...
Interesting...
Did you allow windows update to update the driver? Never do this. What updates what updates were you applying exactly?
In the Device Manager, locate your display adapter. Double click on it and click the Driver tab. What sort of info does it say for the driver: manufacturer, date, etc? Is this the default driver that was provided when you installed windows? Have you tried "Roll Back Driver" ?
ranger said:
Interesting...
The Windows Automatic Updates kept saying there were updates ready to be installed. Most of them were security updates from what I could tell.
I had tried to roll back the driver but there was not one that had been saved(not the exact phrase)
Driver Provider: ATI Technologies Inc.
Driver date:2/16/2006
Driver Version: 8.205.3.0
Digital Signer: Microsoft Windows Hardware Compatibility Publisher
Right now my screen is not flickering----<keeping fingers crossed>.
Only choose priority updates from MS, video card drivers for your GPU should be downloaded from the manufacturer's website, in this case ATI/AMD.
Thanks!
Can you post an update, I'm curious as to how your machine is doing now. And would like to offer any more help if needed.
It started flickering again...
Here is what I found at ATI/AMD:
"Knowledge Base
AMD Customer Care Site Map > Radeon Support - PC > Radeon X1300 series >
737-28141: Radeon™ X1300 Pro PCI-E DMS59 - Intermittent flickering in dual display mode on DMS59 Dual DVI Y-Cable port
The information in this article applies to the following configuration(s):
* Catalyst Display Driver 7.5
* DELL Radeon™ X1300 Pro PCI-E DMS59
* DELL Optiplex 745
* Windows XP Professional
Symptoms:
Intermittent flickering occurs only on one monitor while in Extended Mode through DVI connection. There is no problem in Clone Mode or while analog CRT monitors are connected through DVI-VGA adapters.
Solution:
Currently there is no solution.
ATI Engineering has been advised of this issue and is investigating. Any updates will be published when they become available.
Well that sucks, when i get home i'll see what i can look up for you.
Much Appreciated!
What OS are you running, at this point I'm assuming XP or Vista, am i correct? What hardware is involved in this dual screen setup? If using a Dual DVI setup i'd do the following:
1) first uninstall your video card drivers, and reboot.
2) With your computer turned off, check the connections and see if they are in the following configuration ( assuming at this point you're using a dual DVI dongle, Y splitter)
2a) The screen on the left should be connected to "1" on the splitter
2b) The screen on the right should be connected to "2" on the splitter
3) Power on your computer, only the left one will turn on, don't worry.
4) If you have the disc for the video card that has the drivers, pop that in and when it auto executes, kill it from doing so.
5) Right click "My Computer">Properties>Hardware>Device Manager
5a) In the list, locate your "Display adaptor", right click on it and select "update driver"
6) In the following wizard you're going to make sure the second checkbox is selected and hit next, this will load the drivers directly from the disc bypassing the install shield provided by ATI7)Reboot
8) Right click on desktop>properties>settings
8a) right click on #2 monitor and click "attached", also check the box that says "extend my desktop to this monitor"
9) set the resolution to both and reboot
10) Increasing the refresh rate from 60hz to 75 sometimes does the trick.
if you don't have the disc, go ahead by downloading and installing the drivers via the.exe file obtained.
Let me know if this helps. :smile:
7)Reboot
Right now not flickering...hasn't flickered in about two hours...
Running Windows XP Media Center.
No splitter, just a flat panel monitor plugged into laptop and using the Windows dual screen option found in Display properties/ advanced.
Tempted to leave it alone until it flickers again <keeping fingers crossed>
Thanks for your help!
Related to Screen Flicker and Windows update
1. What causes screen flickering after a Windows update?
Screen flickering after a Windows update can be caused by a variety of factors, such as outdated or incompatible graphics drivers, conflicting software, or hardware issues. It is important to troubleshoot and identify the specific cause in order to find a solution.
2. How can I fix screen flickering after a Windows update?
The first step to fixing screen flickering after a Windows update is to check for and install any available updates for your graphics drivers. If that does not work, you can try disabling any conflicting software, performing a system restore, or seeking assistance from a technical support team.
3. Is screen flickering after a Windows update a common issue?
Yes, screen flickering after a Windows update is a common issue that many users experience. This is often due to the complex nature of Windows updates and the potential for conflicts with existing software and hardware on a user's device.
4. Can a Windows update cause permanent damage to my device?
In most cases, a Windows update will not cause permanent damage to your device. However, it is possible for a faulty update to cause issues that may require a repair or replacement of hardware components. It is important to always back up your important files and documents before performing a Windows update.
5. How can I prevent screen flickering after a Windows update?
To prevent screen flickering after a Windows update, it is important to regularly update your graphics drivers and other software. Additionally, you can avoid potential conflicts by researching and ensuring compatibility before installing new software or hardware on your device. Keeping a backup of your important files can also help in case of any issues with a Windows update.
  • Computing and Technology
