SE equation with a strong potential
  • Thread starter eljose
  • Tags
    Potential
In summary, the conversation discusses solving an equation with two potentials, V and V_0, using a first order development with V/N as perturbation. The change of variables x² -> Nx² and V as V/N must be managed, and the Hamiltonian H_{0} is defined to solve the equation using the WKB approach. The Feynman Path-integral is also mentioned as a method to calculate the K0 propagator, and perturbation theory is used to calculate corrections to first and second order. The conversation ends with questions about the validity of the WKB approach and whether first order perturbation theory will work.
eljose
492
let be the SE with two potentials V and V_0 with N>>>>1 a big number..
[tex]i\hbar\frac{d\psi}{dt}=-\frac{\hbar^{2}}{2m}D^{2}\psi+(V+NV_{0})\psi[/tex]
then my question is how could we solve it approximately..thanks...
If you know a solution for V_0, then change t as tN and x² as Nx² and V as V/N. Then perform a first order development with V/N as pertubation.
Note that V0 probably depends on x, and therefore you need to manage the change of variables x² -> Nx² in the potential term too.
If V0 as a dependence like VO(x/xref), then xref² has simply to be replaced by N xref². Should be simple.
thanks..i manage in a very similar way described by you:
first i divide all equation by N e=1/N tehn we would have:
[tex]ie\hbar\frac{d\psi}{dt}=-\frac{e\hbar^{2}}{2m}D^{2}\psi+(eV+V_{0})\psi[/tex]
after that i define the Hamiltonian [tex]H_{0}=-\frac{e\hbar^{2}}{2m}D^{2}\psi+V_{0}\psi [/tex] to solve this i use the WKB approach as e<<<1
then after that i treat V as a perturbation and solve it to first and second order...
But what is this good for?..let,s suppose we have a Lagrangian of the form L0+V with the potential then we could add a term NV0 in the Feynman Path-integral, to obtain the K0 propagator we use the development of Taylor of S near its classical solution in the form:
[tex] S[\phi]=S[\phi_{c}]+(1/2)\delta^{2}S[\phi_{c}]\phi^{2}+...[/tex]
then we evaluate this functional integral to calculte K0,for the rest we use perturbation theory to calculate the corrections to first and second order...
Solve for the [itex] NV_0 [/itex] and then use perturbation theory for the other potential...
Seems to me that more info is required. WKB is great, but not always valid. Can one solve with either potential; maybe one could solve exacly with both -- two square wells. Do you have a specific problem in mind? Are you talking bound states or scattering, or perhaps both? Given the magnitudes involved, will first order perturbation theory work? (One solvable case is a 1/r potential, with a very large angular momentum, with n=L*(L+1) so the effective potential is (-)q*q/r + n/(r*r), a good test case.
Regards,
Reilly Atkinson
Regards,
Reilly Atkinson
FAQ: SE equation with a strong potential
What is the Schrödinger equation with a strong potential?
The Schrödinger equation with a strong potential is a mathematical equation used in quantum mechanics to describe the evolution of a quantum system in time. It takes into account both the kinetic energy and potential energy of the system, and is commonly used to study the behavior of particles in a potential well or barrier.
How is the Schrödinger equation with a strong potential different from the regular Schrödinger equation?
The regular Schrödinger equation only considers weak potentials, while the Schrödinger equation with a strong potential takes into account strong potentials that significantly affect the behavior of the system. This means that the solutions to the strong potential equation may differ greatly from those of the regular equation.
What are some applications of the Schrödinger equation with a strong potential?
The Schrödinger equation with a strong potential has many applications in physics, particularly in studying the behavior of particles in potential wells and barriers. It is also used in the study of quantum tunneling, where particles can pass through potential barriers that would be impossible according to classical physics.
How is the Schrödinger equation with a strong potential solved?
Solving the Schrödinger equation with a strong potential is a complex process and often requires numerical methods. However, for certain types of potentials, analytical solutions can be obtained. These solutions can then be used to make predictions about the behavior of the system.
What are some limitations of the Schrödinger equation with a strong potential?
The Schrödinger equation with a strong potential is a non-relativistic equation, meaning it does not take into account the effects of special relativity. It also does not take into account quantum field theory, which is necessary for understanding certain phenomena such as particle interactions. Additionally, it is limited to describing systems with a finite number of particles and cannot be used for systems with an infinite number of particles, such as a quantum field.
