Seals for a shaft with 24000 rpm
  • Thread starter Wasiq
In summary, seals for a shaft operating at 24,000 rpm must be designed to withstand high rotational speeds while preventing leakage of lubricants and contaminants. These seals should have low friction characteristics to minimize wear and heat generation, as well as materials that can handle the thermal and mechanical stresses associated with such high speeds. Proper selection of seal type, installation techniques, and maintenance are crucial for ensuring optimal performance and longevity in high-speed applications.
Wasiq
Hi everyone! I am having a problem with the leakage through the hole between high high-rotation shaft and the wall of the case that is of 2.5 mm each point. Attached below is the pdf that show that the outer diameter is 12.5 mm while the diameter of the shaft is 12mm . There are some of the characteristics:
  1. Shaft rpm= 24000 rpm
  2. Linear velocity= 13.4 m/s
  3. Temperature= Between 150-180
  4. Exposed to tar and grease
I have used multiple types of solutions such as rotary shaft sealing but there is no solution. Can you tell me about the correct sealing through which the leakages will be minimum.
  • Fumecatch.pdf
Is the fluid air?
We need a better picture of the structure and some idea of the pressure differences between chambers.
Have you considered a labyrinth seal?
A small disc attached to the shaft may throw out air and prevent flow along the shaft.
Is a sealed ball bearing insufficient?
Your PDF shows what appears to be a centrifugal blower, but does not show what we need to know:
1) A detailed drawing of the portion of the shaft around the seal, the blower housing around the seal, and the seal housing.
2) What are you sealing - is it a liquid or gas? What liquid or gas?
3) What is the temperature of the substance that you are sealing?
4) What is the pressure difference across the seal?
5) How long does it need to last - minutes, hours, days, months, years, or decades?
6) What is the shaft deflection at the seal location?
7) Discuss the "exposed to tar and grease". Is it a few drops splashing, or a high pressure stream aimed at the seal?
8) What is the allowable seal leakage? There is a huge difference between 1 cc/year and 1 cc/day, and zero leak seals can get very expensive.
Tell us exactly what seal designs you have tried. Why did each of those not work?
A 12 mm diameter shaft running 24,000 RPM will have a surface velocity of 15 m/sec, so what is moving at 13.4 m/sec?
Do you think ball bearings can withstand 24000 rpm
NSK 6801 - 12 mm ID x 21 mm OD x 5 mm wide.
open in oil = 38,000 RPM.
metal shield = 32,000 RPM.
non-contact sealed = 32,000 RPM.
rubber lip sealed = 20,000 RPM.
lemme have a check on it
Beyond 'labyrinths', consider eg 'magnetic bearings', where shaft does not extend through sealed enclosure ??
Okay, may also have 'trad' bearings to accommodate 'excursions'...
The issue is that the objective is not just suspending the axle in space and reducing friction.
It’s also providing an air seal for the blower housing. A magnetic bearing would not provide that seal.
IIRC, there was a trick used in model-boating before modern materials such as ferro-fluids and PTFE to have a threaded prop-shaft so that its usual rotation acted as a screw-pump within stern-tube to drive inevitable ingress along shaft back outwards. Think 'lead-screw'...
You could not run in reverse for 'long', and the wary fitted a small, float-switched bilge-pump in reserve...
Think 'cellar sump-pump'...
Hmm: In your application, could you have a magnetic coupling so the blower shaft is entirely within the housing, and there are no through-housing axle seals to wrangle ?? Per oil-free air-compressors and 'hygienic' equipment...
FAQ: Seals for a shaft with 24000 rpm
1. What type of seal is best for a shaft operating at 24000 RPM?
The best type of seal for a shaft operating at 24000 RPM typically includes mechanical seals or specially designed lip seals. Mechanical seals are preferred for high-speed applications as they provide better sealing performance and can handle high pressures and temperatures. It's essential to consider the specific application and the fluid being sealed when selecting the appropriate seal type.
2. How do I determine the correct size of a seal for a high-speed shaft?
To determine the correct size of a seal for a high-speed shaft, you need to measure the shaft diameter and the housing bore where the seal will be installed. Ensure that the seal's inner diameter matches the shaft diameter and the outer diameter fits snugly in the housing. It's also important to account for any tolerances and the type of sealing material used.
3. What materials are recommended for seals in high-speed applications?
Recommended materials for seals in high-speed applications include fluorocarbon elastomers (like Viton), nitrile rubber, and various thermoplastics. These materials offer excellent resistance to wear, temperature, and chemical exposure, making them suitable for high RPM conditions. The choice of material should also consider the operating environment and the type of fluid being sealed.
4. How can I ensure the longevity of seals in high-speed applications?
To ensure the longevity of seals in high-speed applications, it is important to maintain proper lubrication, avoid misalignment, and ensure that the sealing surfaces are smooth and free of contaminants. Regular maintenance checks and monitoring for wear can also help identify potential issues before they lead to seal failure.
5. What are the common failure modes for seals at high RPMs?
Common failure modes for seals at high RPMs include wear due to friction, heat build-up, and material degradation. Other issues can arise from improper installation, shaft misalignment, or contamination of the sealing surfaces. Regular inspections and choosing the right seal material can help mitigate these failure modes.
