Searching for Low Impact Fluid with Boiling Point of 150-180 F
A suitable working fluid for a waste heat recovery system should have a boiling point between 65.6 and 82.2 degrees Celsius, be minimally flammable, nontoxic, and environmentally friendly. The required boiling point range aligns with the facility's relatively constant temperature for effective heat recovery. Working pressure is anticipated to be at 1 ATM, with considerations for using sub-ambient pressures if water is selected as the fluid. Participants are encouraged to refer to a list of refrigerants to identify potential candidates that meet these criteria. The discussion aims to find optimal solutions for efficient waste heat recovery.
chemisthypnos
I am looking for a good working fluid whose boiling point is in the range of 150-180 F for a waste heat recovery system. The fluid should be minimally flammable, preferably nontoxic, and low in environmental impact. Does anyone know of any working fluids that match this description?
What working pressure?
What is the reason for the boiling point range requirement?
The working pressure is going to be 1 ATM ( atmospheric pressure). I am also considering using pressure below ambient if water is the working fluid so it will boil at a lower temperature.
The reason for the boiling point range is that 150-180 F will be the relatively constant temperature in the facility that we want to use waste heat recovery on.
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
