Second and Third Generations of Proton and Neutron?
In summary, this research suggests that there may be more generations of particles than we currently thought.
Petrix
Hello!
I have a very interesting question, whose answer I have not yet been able to find out.
Now, according to The Standard Model there are three generations of matter, therefore three generations of quarks also.
Generations of Quarks:
1st: up (u) & down (d)
2nd: charming (c) & strange (s)
3rd: top (t) & bottom (b)
There are also three generations of corresponding Leptons:
1st: electron (e−) & electron-neutrino (νe)
2nd: muon (μ−) & muon-neutrino (νμ)
3rd: tauon (τ−) & tauon-neutrino (ντ)
So, we also know that the proton is u+u+d and the neutron is u+d+d.
Therefore who knows how we could find out about the physical and quantum mechanical properties of the second and third generations of proton and neutron, that is:
? PROTON & NEUTRON
1st: uud & udd
2nd: ccs & css
3rd: ttb & tbb
And if we have these higher energy protons and neutrons, we could build second and third generations of chemical elements, that is:
1st: H(=uud), He(=2uud+2udd), Li(=3uud+4udd), etc.
2nd: **H(=ccs), **He(=2ccs+2css), **Li(=3ccs+4css), etc.
3rd: ***H(=ttb), ***He(=2ttb+2tbb), ***Li(=3ttb+4tbb), etc.
You would have to, of course, add the corresponding electrons, muons and tauons to their respective generational elements to get all your periodic table chemically stable.
Now, my question is:
Is it all possible, even if only theoretically?
Does the Standard Model predict this?
Or String Theory?
Please answer me, because I believe this could initiate a very exciting new path of research (both theoretical and later even experimental...)
Thank you!
I think the problem is that these states are all very unstable. They will decay into first generation particles almost immediately, just because they can.
Also you can't have any top quarks bound in hadrons..
I understand that is the most likely thing that can happen, but then there is the so-called "Island of Stability" at the far end of the periodic table, which implies that even very high energy elements could be yet stable...
The theoretical obtained "island of stability" is that certain configurations of protons and neutrons are stable. So you should not confuse these two subejcts.
However, there are research within your suggestion of "exotic nuclei", google hypernuclei for instance. They are very shortlived.
You can pick up an advanced textbook in hadron physics and study this if you want. I can give you some tips.. but it is very technical.
So, why can't top quarks be bound in a hadron?? (the strong interaction keeps the quarks in the proton and neutron also...)
because they are so short lived that they decay before any kind of hadronization process can take place.
You might want to study som "basic" particle physics.. try the textbook "Particle Physics" by Martin. Very good!
so are you suggesting then, that theoretically they might be possible... but these hadrons may not exist on our time scale... (what about the time scale of string theory?)
how long would the "hadronization process" have to take?
thanx, and you have any more books on hadrons, you'd recommend?
if you don't know anything about quantum physics or particle physics, I suggest you start with the basics before suggesting new areas of research ;-)
look, I've just read a very interesting article about a new particle (composed of a charming and a strange quark), and surprisingly, they found that it lived much longer than what theory had previously suggested... (a heavier and more stable particle than in theory!)
http://www.theregister.co.uk/2004/06/18/meson_weirdness/
so, how do you explain that?
explain what? It just "violates" the general rule that the heavier a particle is, the faster it decays. So what?
It lives 3 times longer than it "should be" according to simple estimation models, they live 3*10^20 seconds instead of 1*10^10 s.
And is not even a scientific article, is the particle listed in PDG?
I am studying the pi0 decay into e+e-, which have a braching ratio 3 standard deviations from the standard model value according to quantum electro dynamics.
Are you suggesting that since we don't know everything, everything is possible?
and this you think give arguments for having nuclei of hyperons? ;-)
i wasn't talking about hyperons (any baryon containing a strange quark, but no charm quarks or bottom quarks!) but such discoveries (that contradict accepted dogmas) could open a very narrow but extremely important window into yet unexplored territory (eg.: the strange & charming and the top & bottom analogues of the proton and neutron), string theory, for instance suggests even more generations of matter than the usual three...
That is just the way science goes.
Now the question you have raised is an old one, so there is a lot which can be studied in this field..
Why is this an important and unexplored territory? Hunts for beauty baryons etc have been going on since decayes...
String theories suggest a lot of things.. so what?
if neither of your (even the very technical) textbooks mention scc, ssc, btt or bbt then wouldn't it be unexplored or perhaps somewhat ignored territory?
why would it be important? wouldn't a 2nd and/or 3rd generational equivalent of the periodic table be interesting? couldn't some new chemistry and/or technology come out of that?
and the "island of stability" in the study of super-heavy elements, don't you see how it's kind of analogous to super-heavy particles, and baryons composed of them?
symmetries, analogies and elegance have always been important driving force into new research in physics, so why not especially these?
i) they are very very very short lived and very very hard to detect. There is a STRONG motivation for not having t-quarks bound in hadrons.
ii) technology of particles living shorter than 10^-30s?
iii) there is a small analogy. The difference is that you don't even have particles with bbs configuration, you want to merge them togheter to form nuclei..
iv) There is already strong research in hadron physics, if you havn't noticed. However, one must be realistic when doing research and proposing new fields of study.
First, the nuclear island of stability is believed to be an island of relative stability. Nucleii there are expected to live 100 or 1000 times as long as their neighbors, but that still gives them half-lives of seconds or minutes.
Second, you have given no argument whatever that the particles you propose are in a new island of stability,
Third, you have given no argument why your putative new island of stability confers a lifetime 100000000000000000000 or more times longer than expected, which is what it would take for useful materials to be made from them.
I think malawi_glenn made a very good point: "if you don't know anything about quantum physics or particle physics, I suggest you start with the basics before suggesting new areas of research."
alright then, but what chance do you give the newly starting Large Hadron Collider in Geneva, that it will discover super-heavy baryons that will be much more stable than expected?
they will not even search for super heavy baryons... as far as I know, it is not on their agenda.
And what factor is "more stable than expected" ?
The LHC cannot look for such a thing. That's why we have High Energy Physics experiment such as the LHC and a different experiment for Nuclear Physics such as RHIC. The detectors that are built at each facility can determine what you are looking for. Furthermore, you can't look for something when the theory isn't there. Each of the particles being detected in such high energy experiments must already have a well-defined decay channel and cross-section to be able to be detected out of the gazillion data set!
There's a lot of lack of knowledge here built into the scenario. Rather than trying to understand the basics first, you seem to have jumped right into proposing something that you don't seem to understand very well. While we encourage people to use this forum to learn, we severely limit wild speculations that meander into random guesswork, as stated in the https://www.physicsforums.com/showthread.php?t=5374" that you had already agreed to upon joining. That is a strict policy that we enforce.
Zz.
Hi Petrix, you seem to be genuinely interested in physics. However, to properly get involved in this field (specially to start new research) requires a lot of preparations.
I was like you in the past, always thinking about ground breaking ideas and try to come up with something new. But problem is, I barely know enough physics to say anything smart about it. Indeed, there are tons of different baryons already discovered in the realm of physics. Check out this list:
http://en.wikipedia.org/wiki/List_of_baryons
I bet you every one of the particle in the list has tons of publications associated with it. So in fact your idea is nothing new. The reality is, most of the things people think about are already discovered one way or another. Thinking about things you know next to zero about gets you no where. The positive step you should take is to start learning, be humble. Most of the time, when you think of something inconsistent, you have a misconception about certain subjects.
Also, to really discuss about baryons and what not, first you need to learn quantum mechanics, then move on the quantum field theory, the world of QED, QCD... There are also tons of mathematical background and various other stuffs you need to learn. Then you may have a chance tackling subjects such as bound states in QCD.
That will take you at least a good 5 years if not more. If you are eager to learn, I suggest you start picking up some standard textbooks on physics. Griffith's introduction on Quantum Mechanics is the standard introduction. Afterward, you can try to read Peskin's Introduction to Quantum Field Theory.
Please don't be offended by my post. I was like you in my high school careers. I wish someone had given me the same advice back in the days so I can start learning rather than trying to find something groundbreaking. I hope this initiates you career in physics!
Then try Scherer's text on Chiral Perturbation theory ;-)
Which is introdution to theoretical hadron physics, quite advanced, I have only gone through the first chapters, then I got nightmares!
Hey, malawi_glenn... I know this is a waste post but I got to say this:
CMS is indeed better than ALTAS! CMS rules! :)
I don't think that's true. There are several searches for new long-lived particles that would pick up such a thing if it exists. (Which we agree is very unlikely)
hmmm source for hadron searches at LHC please?
Unless I misread, both ATLAS and CMS will have difficulties in doing such a thing, since they were not designed to do that. Now maybe ALICE could, but that project is further down the line than what we know will start soon.
Zz.
http://www.icepp.s.u-tokyo.ac.jp/tokutei/activities/susyin2010/presentations/o.jinnouchi/2007_06_20_longlivedparticles_osamu.ppt" is a talk by Osamu Jinnouchi about searches for long-lived particles at the LHC. Note that this search is motivated by certain supersymmetric models, quite unlike what the OP envisions, but the signature is quite similar: a heavy and long lived particle.
I guess I was thinking of the "heavy baryons" that the OP was mentioning rather than this one. That's why I wasn't sure if ALICE has been designed to detect them.
Zz.
Yes of course LHC are designed to find heavy non-resonant particles such as the supersymmetric ones. BUT there are implementations of "plans" so that one knows what to search for. I.e "all possible" Higgs boson signal have been investigated how they would look in say CMS for instance.
Have signals for theoretical predicted heavy baryons been investigated at signal level in the LHC detectors? I don't think so...
  • #31
thanks for all your answers, quantum mechanics and high energy physics is indeed really interesting!
i've just found another article, which reports the initial findings of a nucleus of A=292 and atomic number Z=~122, whose half-life is: t1/2 >= 10^8 y
(just to get an idea what orders of magnitude longer-lived superheavy elements could be...)
http://arxiv.org/abs/0804.3869
so basically some of these new discoveries got me interested in whether it is also possible to extend the periodic table vertically (using higher-generation super-heavy "eka-protons" and "eka-neutrons" as they might be called..) if extension seems more and more plausible horizontally (towards the island of stability)
and I'm just wondering what do you think will be the heaviest particle the LHC could / should find?
and there is also quite a recent discovery of baryon s+s+b
http://www.fnal.gov/pub/presspass/press_releases/Dzero_Omega-sub-b.html
this discovery "brings scientists a step closer to understanding exactly how quarks form matter and to completing the 'periodic table of baryons.' "
and how hard is it to calculate the expected half-live of an undiscovered particle?
what equations do you need to know for that?
  • #32
Now I have seen many "articles" arguing for existence of super heavy nucleus, but never seen such in a peer reviewed paper..
now EVERY discovery on finding new properties of hadrons bring scientists closer to an understanding how quarks for matter.. so you should not tell us here how to appreciate new findings in physics. It was a trivial statement of that article...
And if you want to study theoretical hadron physics, you need lots of quantum mechanics, and math and theoretical physics such as quantum field theory and so on. Finally you can start with "Chiral perturbation theory" or "Lattice QCD", once you know the basics.
  • #33
Or the 2008 Particle Listings of the Particle Data Group, which is about as "official" as things go in particle physics.
You need to be careful about new findings posted on arxiv, because they have generally not (yet) been confirmed by other researchers, and have not (yet) gone through peer review. There has apparently been a significant amount of criticism of this finding: Heaviest element claim criticised
Related to Second and Third Generations of Proton and Neutron?
1. What are the second and third generations of proton and neutron?
The second and third generations of proton and neutron refer to the different states or types of these subatomic particles. Protons and neutrons are made up of smaller particles called quarks, and the second and third generations refer to the specific types of quarks that make up these particles.
2. How do the second and third generations differ from the first generation?
The main difference between the second and third generations and the first generation is the mass of the particles. The second and third generation particles are much heavier than the first generation particles. Additionally, the second and third generation particles have different charges and properties compared to the first generation.
3. What are the names of the second and third generation particles?
The second generation particles are called charm and strange quarks, and the third generation particles are called top and bottom quarks. These names were given based on the properties and behavior of these particles in particle physics experiments.
4. How were the second and third generation particles discovered?
The second and third generation particles were discovered through experiments conducted at particle accelerators. These experiments involved colliding particles at high speeds to create new particles, and through analyzing the data from these collisions, scientists were able to identify the existence of the second and third generation particles.
5. What is the significance of the discovery of the second and third generation particles?
The discovery of the second and third generation particles has helped to further our understanding of the fundamental building blocks of matter. It has also provided evidence for the Standard Model of particle physics, which describes the interactions between these particles. Additionally, the study of these particles has led to advancements in technology, such as the development of medical imaging techniques and particle accelerators.
