Second derivative of a complex matrix
In summary, the conversation revolved around reproducing results from a paper and specifically focusing on the second derivative of certain invariants. The conversation included a discussion on the decomposition of a complex matrix into real and imaginary parts, the use of the trace operator, and the application of Einstein Summation Notation. The conversation also addressed an incorrect identity and notation used in the process. Through further clarification and explicit notation, the individual was able to correct their mistakes and reach the desired results.
idmena
Hi all
I am trying to reproduce some results from a paper, but I'm not sure how to proceed. I have the following: ##\phi## is a complex matrix and can be decomposed into real and imaginary parts:
$$\phi=\frac{\phi_R +i\phi_I}{\sqrt{2}}$$
so that
$$\phi^\dagger\phi=\frac{\phi_R^2 +\phi_I^2}{2}$$
Using this matrix I can construct invariants like:
$$Tr(\phi^\dagger\phi)\\
Tr\left(\phi^\dagger\phi\phi^\dagger\phi\right)\\
Tr(\phi^\dagger\phi)Tr(\phi^\dagger\phi)$$
and so on. I am interested in the second derivative of this invariants for a specific configuration, where ##\phi## is diagonal and real. I am having trouble with the second one, I hope you can help me.
First I have the derivative with respect to the real part:
$$\frac{\delta}{\delta\phi_{Rcd}} Tr\left(\phi^\dagger\phi\phi^\dagger\phi\right) = Tr\left(2\phi_{Rcd}\,\phi^\dagger\phi\right)$$
For the case that ##\phi## is real, ##\phi_I = 0## and ##\phi_R \to \sqrt{2}\phi##. Now, writing down the indices I have been omitting, we have:
$$= 2\sqrt{2}Tr\left(\phi_{cd}\phi_{xy}\phi_{xy}\right)\\
= 2\sqrt{2}\delta_y^c\delta_d^x\delta_x^y\phi_{cd}\phi_{xy}\phi_{xy}\\
= 2\sqrt{2}\delta_d^c\,\phi_{cd}^3$$
where in the second line I used the trace operator to contract the indices. This result matches the paper I am reproducing.
Now, for the second derivative I have:
$$\frac{\delta}{\delta\phi_{Rab}\delta\phi_{Rcd}} Tr\left(\phi^\dagger\phi\phi^\dagger\phi\right) = \frac{\delta}{\delta\phi_{Rcd}}Tr\left(2\phi_{Rcd}\,\phi^\dagger\phi\right) = 2\,Tr\left(\delta_c^a\delta_d^b\,\phi^\dagger\phi +\phi_{Rcd}\,\phi_{Rab}\right)$$
I am unsure on how to treat the first term here. Writing down the indices explicitly like I did before, I have:
$$Tr\left(\delta_c^a\delta_d^b\,\phi^\dagger\phi\right) = Tr\left(\delta_c^a\delta_d^b\,\phi_{xy}\phi_{xy}\right)$$
I know the trace contracts the outer indices, but how do I treat the deltas? Which indices are contracting with which in this case?
Simplifying the second term yields:
$$=2\,Tr\left(\delta_c^a\delta_d^b\,\phi^\dagger\phi\right) +2\delta_d^a \delta_c^b \,\phi_{Rba}\,\phi_{Rab}\\
=2\,Tr\left(\delta_c^a\delta_d^b\,\phi^\dagger\phi\right) +4\delta_d^a \delta_c^b \,\phi_{ba}\,\phi_{ab}$$
where in the second line I assumed that ##\phi## is real and swapped ##\phi_R \to \sqrt{2}\phi##
I was supposed to get:
$$=2\delta_c^a\delta_d^b \left(\phi_a^2 +\phi_b^2\right) +2\delta_d^a\delta_c^b \phi_a \phi_b$$
Where do the two ##\phi_a^2 +\phi_b^2## come from? And how come I got a factor of 2 extra in the second term?
Can anyone help me on how to fill the gap?
Thank you all very much!
Where did you get the following equation?
I am not aware of any such identity, and when I choose an arbitrary matrix ##\phi## and calculate the two sides of the equality, they do not match:
Code:
Code:
Phi_real <- matrix(1:4, ncol=2) / sqrt(2)
Phi_Im <- matrix(8:5, ncol=2) / sqrt(2)
Phi <- Phi_real + (0+1i) * Phi_Im
# calculate left side of equation
Conj(t(Phi)) %*% Phi
# calculate right side of equation
(Phi_real %*% Phi_real + Phi_Im %*% Phi_Im) / 2
Results:
Code:
       [,1]   [,2]
[1,] 59+ 0i 47-18i
[2,] 47+18i 43+ 0i
      [,1]  [,2]
[1,] 28.25 23.25
[2,] 25.25 22.25
Also, your use of Einstein Summation Notation is unfamiliar to me. As I was taught it, one only implicitly sums matching indices when one index is up and one index is down, not when both are at the same level. Further, even if one drops the 'different levels' requirement, the expression ##\delta^c_d\, \phi_{cd}^3## does not appear to validly imply a summation as it has a total of four c's and four d's. I suspect some of the later problems may relate to invalid use of implicit summation, but I cannot be sure without better understanding your intention. When in doubt, it's best to write out summation explicitly, to avoid invalid steps.
Likes FactChecker
Hi, thank you for your quick reply.
You are right, I should've written the summation explicitly, I now realize I was making mistakes due to being confused by my own notation.
Sorry about that, since I am always taking the trace of the invariants, the identity I mean to write was:
$$Tr\left(\phi^\dagger\phi\right) = \left(\phi^\dagger\phi\right)_{ii} = \frac{\left(\phi_{Rij}\right)^\dagger\phi_{Rji} + \left(\phi_{Iij}\right)^\dagger\phi_{Iji}}{2} = \frac{\phi_{Rji}^2 +\phi_{Iji}^2}{2}$$
Sure, the correct way is to match up and down indices, I agree. In this case I was just using the indices to refer to elements of the matrix, in which case I'm used to writing everything downstairs (e.g. ##\left(AB\right)_{ij} = A_{ik}B_{kj}##). For the case of ##\phi_{cd}^3## I was referring to the third power of the (c,d) element of ##\phi## (where the entries of ##\phi## are scalars).
I have written down all indices explicitly and realized where my mistakes were, I got the right results now.
Thank you for your helpful comment!
Related to Second derivative of a complex matrix
1. What is the definition of the second derivative of a complex matrix?
The second derivative of a complex matrix is a mathematical concept that describes how the elements of a matrix change with respect to each other. It is the rate of change of the first derivative, which represents the rate of change of each element in the matrix.
2. How is the second derivative of a complex matrix calculated?
The second derivative of a complex matrix can be calculated using the rules of matrix calculus. This involves taking the derivative of each element in the first derivative matrix, and then arranging the new elements into a new matrix.
3. What is the significance of the second derivative of a complex matrix in scientific research?
The second derivative of a complex matrix is often used in scientific research to understand the behavior of complex systems. It can provide insights into the rate of change of different elements in a system, and how they interact with each other.
4. Can the second derivative of a complex matrix be negative?
Yes, the second derivative of a complex matrix can be negative. This indicates that the rate of change of the elements in the matrix is decreasing, or that the elements are changing in a concave manner.
5. Are there any real-world applications of the second derivative of a complex matrix?
Yes, the second derivative of a complex matrix has many real-world applications, such as in physics, engineering, and economics. It can be used to analyze the stability of systems, optimize processes, and model complex phenomena.
  • Linear and Abstract Algebra
  • Quantum Physics
  • Quantum Physics
