Second Derivative Test for Local Extrema
In summary, if ##f^{\prime}(c)=0## and ##f^{\prime\prime}(c)=0##, then ##f## can have a local maximum, a local minimum, or neither. Examples of such possibilities include ##f(x)=1-x^4## for a local maximum and ##f(x)=x^4## for a local minimum.
22990atinesh
143
Suppose ##f^{\prime\prime}## is continuous on an open interval that contains x = c
1. If ##f^{\prime}(c)=0## and ##f^{\prime\prime}(c)<0##, then ##f## has local maximum at x = c.
2. If ##f^{\prime}(c)=0## and ##f^{\prime\prime}(c)>0##, then ##f## has local minimum at x = c.
3. If ##f^{\prime}(c)=0## and ##f^{\prime\prime}(c)=0##, then the test fails. The function ##f## may have a local maximum, a local minimum, or neither.
I've a little doubt in point 3. I've come up with only 1 example for the possibility when
##f^{\prime}(c)=0##, ##f^{\prime\prime}(c)=0## and ##f## has neither local maximum or local minimum.
Ex: ##f(x)=x^3##
Please give examples for other two possibilities when
##f^{\prime}(c)=0##, ##f^{\prime\prime}(c)=0## and f has local maximum
##f^{\prime}(c)=0## , ##f^{\prime\prime}(c)=0## and f has local minimum
For the first, [itex]f(x)= 1- x^4[/itex]. For the second, [itex]f(x)= x^4[/itex].
Likes 1 person
Thanx I get it
Related to Second Derivative Test for Local Extrema
What is the second derivative test for local extrema?
The second derivative test is a method used to determine the nature of the critical points on a graph. It involves calculating the second derivative of a function at a critical point and examining the concavity of the graph at that point.
How do you use the second derivative test to find local extrema?
To use the second derivative test, you first find the critical points of the function by setting the first derivative equal to zero. Then, you calculate the second derivative at each critical point. If the second derivative is positive, the graph is concave up and the critical point is a local minimum. If the second derivative is negative, the graph is concave down and the critical point is a local maximum.
What is the difference between a local minimum and a local maximum?
A local minimum is the lowest point on a graph within a specific interval, while a local maximum is the highest point on a graph within a specific interval. Both are considered local extrema, which are points where the function changes from increasing to decreasing (local maximum) or from decreasing to increasing (local minimum).
Can the second derivative test be used to find global extrema?
No, the second derivative test can only be used to find local extrema. To find global extrema, you need to consider the entire domain of the function, not just a specific interval. This can be done by using the first derivative test or by finding all critical points and evaluating the function at each point to determine the global extrema.
What are some limitations of the second derivative test?
The second derivative test can only be used for functions that are twice differentiable, meaning that their first and second derivatives exist and are continuous. It also cannot be used if the first derivative is equal to zero at a critical point, as this would result in an inconclusive result. Additionally, the test may not accurately determine the nature of a critical point if the function has complex behavior or multiple variables.
  • Calculus
