thomas49th
- 655
Show that the equation x= e^t converts the equation
[tex]ax^{2}\frac{d^{2}y}{dx^{2}} + bx\frac{dy}{dx} + cy = 0[/tex]
in which a,b,c are coefficients
x = e^t and so does dx/dt. So you can write dx/dt = x
using the chain rule
dy/dx = dy/dt * dt/dx
=> dy/dt * 1/x
now here is the bit that is tricky.
[tex]ax^{2}\frac{d^{2}y}{dx^{2}} + b\frac{dx}{dt} + cy = 0[/tex]
Apparently I cannot simply stick [tex]\frac{dy}{dt} * \frac{1}{x}[/tex]
into the second order deravite to give [tex]\frac{d^{2}y}{d^{2}t} * \frac{1}{x^{2}}[/tex]. Why not? Does [tex]\frac{d^{2}y}{dx^{2}} \neq \frac{dy}{dx^{2}}[/tex]??
Also I thought maybe you differentiate the chain rule again
[tex]\frac{d^{2}y}{dx^{2}} = -\frac{dy}{dt}\frac{1}{x^{2}}[/tex]
But that doesn't seem to help (have I differentiated it correctly as I didn't use the product rule because I don't think dy/dt is a function of x).
Any suggestions
Thomas
