Second order correlation function for non ideal laser
In summary, the second-order correlation function (g2) is a constant (=1) for ideal laser or single frequency light sources. However, for non-ideal lasers, the g2 value at zero delay is typically larger than 1 and decays towards 1 with increased delay, with a time constant determined by the coherence time of the light. The shape of the decay towards 1 varies depending on the reason for the laser not being ideal.
pumpkin
Hi, it is known that second order correlation function (g2) is a constant( =1) for ideal laser or single frequency light sources. So, what is the second order correlation function for non ideal laser? Is it still a constant or something related to the coherence time of the laser?
For non-ideal laser the second-order correlation function at zero delay is typically larger than 1 (thermal light would show a value of 2) and decays down towards 1 with increased delaywith a time constant given by the coherence time of the light. The actual shape of the decay towards 1 depends on the reason why the laser is not ideal.
Related to Second order correlation function for non ideal laser
1. What is a second order correlation function for non ideal laser?
The second order correlation function for non ideal laser is a measure of the correlation between two photons emitted by a laser. It indicates the probability of the simultaneous detection of two photons at different points in space and time, and is influenced by the laser's imperfections and external factors.
2. How is the second order correlation function for non ideal laser calculated?
The second order correlation function for non ideal laser is calculated by taking the ratio of the probability of detecting two photons at different points and times, to the product of the probabilities of detecting each photon individually. This ratio is then normalized to account for any imperfections in the laser.
3. What factors can affect the second order correlation function for non ideal laser?
External factors such as temperature, pressure, and fluctuations in the laser's output power can affect the second order correlation function for non ideal laser. Imperfections in the laser's design, including mode competition and non-uniform gain, can also impact the function.
4. What is the significance of the second order correlation function for non ideal laser?
The second order correlation function for non ideal laser provides insight into the coherence and quality of a laser's output. It can also be used to characterize and optimize laser performance, and has applications in fields such as quantum optics and laser spectroscopy.
5. Can the second order correlation function for non ideal laser be improved?
While external factors and imperfections in the laser design can affect the function, there are techniques that can be used to improve the second order correlation function for non ideal laser. These include temperature and pressure stabilization, as well as careful design and optimization of the laser's components.
  • Atomic and Condensed Matter
  • Electrical Engineering
  • Quantum Physics
  • Optics
