Second order differential equation.(Damped oscillation)
In summary, the conversation is about solving a damped oscillation equation with no external forces. The initial conditions are given and the final solution is x=e-1t[3cos(t)+8sin(t)]. There was some uncertainty about the correctness of the solution, but it was confirmed to be correct and the conversation ended with a reminder to substitute the solution into the differential equation to verify it.
mr pizzle
Hi could do with a little help with this question please!
The question
A damped oscillation with no external forces can be modeled by the equation:
[itex]\frac{d^2x}{dt^2}[/itex]+2[itex]\frac{dx}{dt}[/itex]+2x=0
Where x mm is amplitude of the oscillation at time seconds. The initial amplitude of the oscillation is 3mm (i.e. when t=0) and the intial velocity is 5mm/s.
Solve the equation for x.
Ok! so far I have;
[itex] m^2+2m+2=0 [/itex]
[itex]\frac{-b±\sqrt{b^2-4ac}}{2a}[/itex]
[itex]\frac{-2±\sqrt{2^2-4x1x2}}{2x1}[/itex]
[itex]\frac{-2±\sqrt{-4}}{2}[/itex]
[itex]\frac{-2}{2}[/itex]±[itex]\frac{\sqrt{-4}}{2}[/itex]
m=-1±j[itex]\frac{\sqrt{4}}{2}[/itex]
Equating this with m=α±jβ
Gives α=-1 β=1
Substituting into the general solution (complex roots)
x=e-1t[Acos(t)+Bsin(t)]
x=3 t=0
3=e-1x0[Acos(0)+Bsin(0)]
3=A
This is the part we are unsure of!
[itex]\frac{dx}{dt}[/itex]=e-1t[-Asin(t)+Bcos(t)]-1e-1t[Acos(t)+Bsin(t)]
By the product rule;
=e-1t[B-A]cos(t)-[A-B]sin(t)
x=0 [itex]\frac{dx}{dt}[/itex]=5
5=e0[B-A]cos(0)-[A-B]sin(0)
5=[B-A]
We know A=3 so therefore B=8
Is this correct? If not any help would be greatly appreciated.
Yes, that is correct. I'm not sure why you had any question about it.
Just wasn't sure. Followed it from a book from a similar question and don't fully understand it! The question was different enough to have doubts!
when you have the solution, you can substitute it into your differential equation to see if you end up with 0.
Your solution for the second order differential equation is correct. However, the initial conditions given in the question are not consistent with your solution.
When t = 0, the initial amplitude is given as 3mm, but your solution has a general amplitude of 3cos(t) + 8sin(t). This means that at t = 0, the amplitude should be 3, not 3cos(0) + 8sin(0) = 8. Similarly, the initial velocity given is 5mm/s, but your solution has a general velocity of -3sin(t) + 8cos(t), which at t = 0 would be 8, not 5.
To solve this, you can adjust your solution by including a constant term in the general solution. This would give you a solution of x = e^(-t)[Acos(t) + Bsin(t)] + C, where C is a constant that can be determined by plugging in the initial conditions.
Alternatively, you can also use the initial conditions to solve for A and B, and then use those values in your solution without including the constant term. This would give you a solution of x = e^(-t)[3cos(t) + 8sin(t)].
In terms of the physical interpretation of the solution, your solution shows that the amplitude of the damped oscillation decreases over time, as seen by the exponential term e^(-t). The presence of the sine and cosine terms indicate that the oscillation is periodic, and the values of A and B determine the specific shape of the oscillation. The presence of the damping term (2dx/dt) in the differential equation means that the oscillation will eventually come to a stop, as seen by the decreasing amplitude over time.
FAQ: Second order differential equation.(Damped oscillation)
What is a second order differential equation?
A second order differential equation is a mathematical equation that relates the second derivative of a function to the function itself. It is often used to describe physical systems that involve acceleration, such as damped oscillation.
What is damped oscillation?
Damped oscillation is a type of motion where a system experiences a gradual decrease in amplitude over time due to the presence of a damping force. This force acts to dissipate the energy of the system, resulting in a decrease in the magnitude of the oscillations.
How do you solve a second order differential equation for damped oscillation?
To solve a second order differential equation for damped oscillation, one approach is to first find the general solution of the equation using techniques such as separation of variables or variation of parameters. Then, based on the initial conditions of the system, a specific solution can be determined.
What factors affect the behavior of a damped oscillation system?
The behavior of a damped oscillation system is affected by several factors, including the magnitude of the damping force, the initial conditions of the system, and the natural frequency of the oscillation. Additionally, the presence of external forces can also impact the behavior of the system.
What are some real-world applications of damped oscillation?
Damped oscillation can be observed in various physical systems, such as a swinging pendulum, a mass-spring system, or an electrical circuit with a resistor, inductor, and capacitor. It is also relevant in engineering fields, such as in the design of shock absorbers and vibration dampers.
