Second Order Differential Nonhomogeneous Equation
You're done. I don't know what your concern is.In summary, the conversation discusses using the method of undetermined coefficients to find a specific solution for a given differential equation. The attempt at a solution involves using the quadratic equation to find the roots, setting up the equation for Yp, and solving for the constants. One person suggests using the D Operator method or variation of parameters method, while another person confirms that the attempted solution is correct and the D parameter is not needed. The conversation ends with a clarification that the roots of the auxiliary equation are 1 and -4, not -1 and -4.
GogumaDork
Use the method of undetermined coefficients to find one solution of
http://img85.imageshack.us/img85/6844/4ab921ad6ba6851cc91401c.png
Note that the method finds a specific solution, not the general one.
Y = Yc + Yp
Yc = C1e^(r1t)+C2e^(rt) when roots are not the same.
For the homogeneous part I used the quadratic equation to get the roots -1 and -4.
Y = Yc + Yp
Yc = C1e^-t +C2e^-4t
I tried Yp = (At^2+Bt+C)*De^(4t) but it doesn't seem correct after solving a bunch of derivatives and plugging it back into y'' + 3y' -4y and solving for constants.
How to determine the Y-particular for this problem?
Hii. Method of undetermined coefficients is sometimes lengthy but it sure does give the correct particular integral. As u hav already written the rough Yp,what u hav to do now is just replace it for y in the original equation and compare the coefficients of (e^4t)t^2,(e^4t)t and e^4t on both sides of the equation and u will get the expression for Yp. There are however other useful and short methods for finding Yp. One is the D Operator method and the other is the variation of parameters method. These are too long for me to describe elaborately here,but u must check these out in the net or any other reference books.Any standard engineering mathematics book would contain these topics.Personally I recommend using the D Operator method as it is very useful when exploited efficiently.
And welcome to Physics Forums...
Y = Yc + Yp
Y = Yc + Yp
Can you show what you did and where it went wrong? The numbers aren't pretty but it certainly seems to be working fine for me. You don't need the D parameter. Set it equal to 1. Then I'll get you started. A=(-1/24).
And one more thing, the roots of your auxiliary equation are 1 and -4 respectively.
That would be true. Nice catch. But you don't need them to find the particular solution.
Related to Second Order Differential Nonhomogeneous Equation
1. What is a second order differential nonhomogeneous equation?
A second order differential nonhomogeneous equation is a mathematical equation that involves a second derivative of an unknown function, as well as a non-zero function on the right-hand side. This type of equation is commonly used in physics, engineering, and other fields to model systems with changing rates of change.
2. What is the difference between a second order differential equation and a first order differential equation?
A second order differential equation has a second derivative of the unknown function, while a first order differential equation only has a first derivative. This means that a second order equation has more complex solutions and can model more complex systems.
3. How do you solve a second order differential nonhomogeneous equation?
To solve a second order differential nonhomogeneous equation, you can use various methods such as the method of undetermined coefficients, variation of parameters, or Laplace transforms. These methods involve finding a particular solution and then using it to find the general solution.
4. What is a particular solution in the context of a second order differential nonhomogeneous equation?
A particular solution is a specific solution to a differential equation that satisfies the nonhomogeneous part of the equation. It is used to find the general solution, which is a family of solutions that includes the particular solution and any other solutions that satisfy the equation.
5. Can a second order differential nonhomogeneous equation have multiple solutions?
Yes, a second order differential nonhomogeneous equation can have multiple solutions. The general solution of the equation includes a constant term, which can take on different values, resulting in multiple solutions. Additionally, different methods of solving the equation may result in different solutions.
