I Second order non-homogeneous linear ordinary differential equation
Hall
I shall not begin with expressing my annoyance at the perfect equality between the number of people studying ODE and the numbers of ways of solving the Second Order Non-homogeneous Linear Ordinary Differential Equation (I'm a little doubtful about the correct syntactical position of 'linear').
I'm studying from Prof. Arthur Mattuck's lectures, and it is the lecture #13 which is confusing me. He embarks on solving (if someone who has seen my other thread can he tell me whether I have used 'embark' (an intransitive verb) in a correct way?)
\begin{align*}
y^{''} + Ay^{'} + By = e^{\alpha x} &&\textrm{where α is a complex number}
\end{align*}
And writes the LHS as ##P(D) y## which I understand totally. The case when ##P(\alpha) \neq 0## is clear to me, the solution is
y_p = \frac{e^{\alpha x} }{P(\alpha)}
But when he moves to the case when ##P(\alpha) = 0##, I get a little confused. Though, I can prove
\begin{align*}
P(D) e^{ax} u(x) = e^{ax} P(D+a) u(x) && \textrm{ it's no longer α, we got a there, but it is still complex}
\end{align*}
Now, I don't understand things from time : 37:00 in the linked video. My doubts are thus:
  • He says "if a is simple root of P(D)" then the solution is ##y_p = \frac{x e^{ax} }{P'(a)}##. How can ##a## be a root of ##P(D)## which is an operator? The operator have a null space not a solution set. We should say if ##a## is a solution of polynomial ##P(x)##.
  • The second doubt is concerning the differentiation of ##P(D)##. I still don't understand what does a derivative of an operator mean, and above that with respect to another operator ##D##.
I hope my doubt shall be resolved.
He's talking about the polynomial ##P##, which is just a polynomial. It is only when you take ##P(D)## that the entire thing becomes an operator. So simply consider what happens to the polynomial. (He should probably have written it has ##P(z)## or something like this.)
Likes Hall and topsquark
Thanks for clearing that.
I'm just wondering how he guessed ##y_p = \frac{x e^{ax} }{P'(a)}##? Yes, it works but how he got it?
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
