stef6987
- 32
How to find the initial capacitor voltage if the capacitor is in series with a 1.5 ohm resistor, these 2 are in parallel with a reversed polarity 6v DC source, (reversed polarity - the negative terminal is pointing up) i assume the voltage across the resistor and capacitor should be -6 volts because of the polarity of the source, the switch is opened at t = 0 nd the 6volt source is disconnected leaving a second order series circuit with another 12v source, another 6ohm resistor and 1.25H inductor (these 3 are in series with the 6v source at t<0 due to the open circuiting circuiting of the capacitor no current goes through the 1.5ohm and capacitor) when t<0 i could find the initial current from simple kvl: -6 - 12 + 6i = 0 ( the inductor is short circuited) hence i(0-) = i(0+) = 3 amps. for t>0 we hve the series second order circuit. check my solutions to see if I am correct.
i(0+) = 3amps, if I am right the voltage across the 1.5 ohm resistor and capacitor is -6 volts or 6volts? we can find the voltage over the resistor using V=ir = 3*1.5=4.5 volts and subtract this from the -6 or 6 volts? and that would be the initial capacitor voltage, am i correct? thankyou
