Second partial derivative of v=e^(x*e^y)
In summary, the second partial derivative of v=e^(x*e^y) can be found by first determining Vx and Vy, followed by taking the second partial derivatives Vxx, Vyy, and Vxy. Integration by parts or substitution can be used to integrate t(t-1)^1/2.
sdoyle1
23
Find the second partial derivative of v=e^(x*e^y)
I know that I need to find Vx and Vy first and then the second partial derivative would be Vxx, Vyy, Vxy.
I'm really confused on how to find Vx or Vy
Vx= the derivative with regards to x, if y is a constant
so would it be Vx=e^(x*e^y) * (e^y)?
Any help would be great
You're forgetting one.
That's correct. What's Vy?
Would Vy= e^(x*e^y) * (xe^y)
Correct. Now you need to take the second partial derivatives.
Vxx would be the second derivative with respect to x but keeping y as a constant. This is where I get confused. Would it be:
Vxx=e^(xye^y)(ye^y)
= e^(xy^2e^y)
Wait, you would add the exponents, not multiply them.
So Vx= e^((xe^y)+y)
Vxx= e^(xe^y+y) * (e^y)
Correct
Ok then Vyy= xe^((xe^y)+y) * (x(e^y) +1)
Then Vxy= e^((xe^y)+y) * ((xe^y)+1) and Vyx is the same as Vxy
As an aside, how would I integrate t(t-1)^1/2 ?
Correct.
Try integration by parts.
Use the substitution: u = t-1 .
Good call. Both methods should work, but this is much simpler to do.
FAQ: Second partial derivative of v=e^(x*e^y)
What is the formula for the second partial derivative of v=e^(x*e^y)?
The formula for the second partial derivative of v=e^(x*e^y) is ∂^2v/∂x∂y = e^(x*e^y)*(e^y + x*e^y).
How do you calculate the second partial derivative of v=e^(x*e^y)?
To calculate the second partial derivative of v=e^(x*e^y), you first find the first partial derivatives with respect to x and y, and then take the second partial derivative of each of those derivatives with respect to x and y.
Why is the second partial derivative important in this equation?
The second partial derivative is important in this equation because it shows how the rate of change of v changes with respect to both x and y. It gives us information about the curvature of the surface defined by this equation and can help us understand the behavior of v in different directions.
What does a positive or negative second partial derivative indicate?
A positive second partial derivative indicates that v is increasing in both the x and y directions, while a negative second partial derivative indicates that v is decreasing in both directions. This can give us information about the concavity of the surface defined by this equation.
Can the second partial derivative of v=e^(x*e^y) be simplified?
Yes, the second partial derivative of v=e^(x*e^y) can be simplified to e^(x*e^y)*(e^y + x*e^y) by using the chain rule and product rule in calculus.
