See if you can create a valid answer
  • MHB
  • Thread starter Yuugen0127
In summary: Thank you for your cooperation.In summary, the conversation is about a teacher sharing a statistic that 3% of the population has the surname Potato in a 1:33 ratio, but none of the 34 students in the class have this surname. The question is whether this is rare or not, and the mathematical proof suggests that it is rare due to the low probability of not having the surname Potato.
Yuugen0127
Resolved Please Delete
So here's a question for you all.
There was once a teacher who said
"According to a recent census, 3% of the population in our country has the surname Potato. That's in a ratio of 1 to 33 people. This class has 34 people in it, but none of you have the surname Potato. Pretty rare, isn't it?"
Explain whether you agree or not with mathematical proof.
Mathematics news on Phys.org
Hi, and welcome to the forum.
This phrase sounds like you already know the answer and want to offer this question as a puzzle. If this is the case, then you should post it to the http://mathhelpboards.com/challenge-questions-puzzles-28/. Be sure you do know the answer! If, on the other hand, you need help with the solution, then you should describe what you know about the subject, what you have tried and what your difficulty is. Please see forum http://mathhelpboards.com/rules/ in this regard (click "Expand" on top).
Note that the probability that a given person is not a Potato is 0.97. Also, $P(A\text{ and }B)=P(A)P(B)$ if $A$ and $B$ are independent events.
I have restored your posts' original content. Please DO NOT edit the first post of a thread you have begun to remove the content...this renders the thread useless. One of the things we value most here are threads with questions that are then discussed and hopefully brought to resolution. So, rather than come along and delete the question when you have resolved it, post your solution for the benefit of others who may find your thread. This enriches our site and does not leave threads with gutted content.
FAQ: See if you can create a valid answer
How do you create a valid answer?
Creating a valid answer involves gathering relevant information, conducting research, and using critical thinking skills to formulate a logical and accurate response to a question or problem.
What is the process for creating a valid answer?
The process for creating a valid answer involves identifying the question or problem, gathering data and information, analyzing and interpreting the information, and formulating a response based on evidence and reasoning.
How do you ensure that your answer is valid?
To ensure that an answer is valid, it is important to use reliable and credible sources of information, apply sound reasoning and critical thinking skills, and consider alternative perspectives or explanations.
What are some common mistakes to avoid when creating a valid answer?
Some common mistakes to avoid when creating a valid answer include relying on biased or unreliable sources, making assumptions without evidence, and failing to consider alternative explanations or perspectives.
Can a valid answer change over time?
Yes, a valid answer can change over time as new information and evidence becomes available. It is important to continuously evaluate and update answers based on the most current and reliable information.
12K
