Alltimegreat1
- 115
- 5
Is it possible?
The law of diffraction provides the answer based on your optics diameter - and it is negativeAlltimegreat1 said:Is it possible?
Yes, it is possible to see the Martian moons Phobos and Deimos with a pair of $60 binoculars. However, the quality and strength of the binoculars will affect the clarity and size of the moons you can see.
The size of the Martian moons through $60 binoculars will vary depending on the magnification power of the binoculars. On average, Phobos will appear about 14 arcseconds in diameter and Deimos will appear about 6 arcseconds in diameter. This may not seem very large, but it is still possible to see them as distinct, separate objects.
The best time to see the Martian moons through $60 binoculars is when Mars is at its closest approach to Earth, which happens every 26 months. During this time, the moons will appear larger and brighter in the sky, making them easier to see with binoculars.
Yes, the best location to see the Martian moons with $60 binoculars is in a dark, clear sky away from city lights. The direction in which you should look will depend on your location and the current position of Mars in the sky. It is best to consult a star map or astronomy app to determine the exact direction.
Along with the Martian moons, you may also be able to see other objects in the sky such as stars, constellations, and even other planets like Jupiter and Saturn. The quality and strength of the binoculars will determine which objects are visible and how clearly they can be seen.
