Segmentation error form the fortran code
In summary: STORI(J1,I) * STORI(J2,I)ANORM(IT) = ANORM(IT) + STORA(J1,I) * STORA(J1,I): + STORB(J1,I) * STORB(J1,I): +...+ STORI(J1,I) * STORI(J1,I)10 CONTINUERETURNENDIn summary, the program TCORR is designed to calculate time correlation functions in one sweep with low memory requirement. It analyzes data and calculates a time correlation function, with an example being the velocity autocorrelation function. The program requires input and output file names and initializes counters and arrays before beginning the calculation. It also includes subroutines for
lehloks
Hi Forum users
I have a velocity autocorrelation code which was made to read a three component velocity vectors and I have modified to read a 9 component stress tensor data. I can compile it successfully but when I try to run it and compute a stress correlation function I get an error: i.e. segmentation fault. I have also included the type of data formate the code was initially meant to correlate.
Thanks in advance for the help
OUTPUT ERROR
**** PROGRAM TCORR ****
CALCULATION OF TIME CORRELATION FUNCTIONS
ENTER DATA FILE NAME
DFILE.txt
ENTER RESULTS FILE NAME
TI1
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
8336
Segmentation fault
Code:
[C PROGRAM TCORR
COMMON / BLOCK1 / STORA, STORB, STORC, STORD,STORE,STORF,STORG,
& STORH, STORI
C COMMON / BLOCK2/STORB
COMMON / BLOCK2 / PA, PB, PC, PD, PE, PF, PG, PH , PI
c COMMON / BLOCK4/ VB
COMMON / BLOCK3 / PACF, ANORM
C *******************************************************************
C ** CALCULATION OF TIME CORRELATION FUNCTIONS. **
C ** **
C ** THIS PROGRAM ANALYZES DATA TO CALCULATE A TIME CORRELATION **
C ** FUNCTION IN ONE SWEEP (LOW MEMORY REQUIREMENT). IN THIS **
C ** EXAMPLE THE VELOCITY AUTO-CORRELATION FUNCTION IS CALCULATED. **
C ** **
C ** PRINCIPAL VARIABLES: **
C ** **
C ** INTEGER N NUMBER OF ATOMS
C ** INTEGER NSTEP NUMBER OF STEPS ON THE TAPE
C ** INTEGER IOR INTERVAL FOR TIME ORIGINS
C ** INTEGER NT CORRELATION LENGTH, INCLUDING T=0
C ** INTEGER NTIMOR NUMBER OF TIME ORIGINS
C ** INTEGER NLABEL LABEL FOR STEP (1,2,3...NSTEP)
C ** REAL VX(N),VY(N),VZ(N) VELOCITIES
C ** REAL VACF(NT) THE CORRELATION FUNCTION
C ** NSTEP AND NT SHOULD BE MULTIPLES OF IOR.
C ** REAL PA,PB,PC = Pxx,Pxy,Pxz STRESSES
C ** REAL PD,PE,PF = Pyx,Pyy,Pyz STRESSES
C ** REAL PG,PH,PI = Pzx,Pzy,Pzz STRESSES
C ** ROUTINES REFERENCED:
C ** **
C ** SUBROUTINE STORE (J1)
C ROUTINE TO STORE THE DATA FOR CORRELATION **
C SUBROUTINE CORR ( J1, J2, IT )
C ROUTINE TO CORRELATE THE STORED TIME ORIGINS **
C USAGE: **
C ** **
C DATA IN FILE DFILE ON FORTRAN UNIT DUNIT. **
C RESULTS IN FILE RFILE ON FORTRAN UNIT RUNIT. **
INTEGER N, NSTEP, IOR, NT, NDIM, DUNIT, RUNIT, NTIMOR
INTEGER FULLUP
PARAMETER ( N = 2377, NSTEP = 8, IOR = 2, NT = 8 )
PARAMETER ( DUNIT = 10, RUNIT = 11 )
PARAMETER ( NDIM = NT / IOR + 1, NTIMOR = NSTEP / IOR )
PARAMETER ( FULLUP = NDIM - 1 )
REAL PA(N), PB(N), PC(N), PD(N), PE(N), PF(N), PG(N), PH(N), PI(N)
REAL STORA(NDIM,N), STORB(NDIM,N), STORC(NDIM,N),STORD(NDIM,N),
& STORE(NDIM,N),STORF(NDIM,N),STORG(NDIM,N),STORH(NDIM,N),
& STORI(NDIM,N)
REAL PACF(NT), ANORM(NT)
INTEGER S(NTIMOR), TM(NTIMOR)
INTEGER TS, TSS, L, NINCOR, K, R, JA, IB, IN, IA, JO, I
INTEGER NLABEL
CHARACTER DUMMY * 5
CHARACTER DFILE * 30
CHARACTER RFILE * 30
WRITE(*,'('' **** PROGRAM TCORR **** '')')
WRITE(*,'('' CALCULATION OF TIME CORRELATION FUNCTIONS '')')
C ** READ IN FILE NAMES **
WRITE(*,'('' ENTER DATA FILE NAME '')')
READ (*,'(A)') DFILE
WRITE (*,'('' ENTER RESULTS FILE NAME '')')
READ (*,'(A)') RFILE
C ** INITIALIZE COUNTERS **
NINCOR = FULLUP
JA = 1
IA = 1
IB = 1
C ** ZERO ARRAYS **
DO 5 I = 1, NT
PACF(I) = 0.0
ANORM(I) = 0.0
write(*,*) PACF(I)
5 CONTINUE
C ** OPEN DATA FILE AND RESULTS FILE **
OPEN ( UNIT = DUNIT, FILE = DFILE, STATUS = 'OLD',
: FORM = 'FORMATTED')
OPEN ( UNIT = RUNIT, FILE = RFILE, STATUS = 'NEW' )
C ** CALCULATION BEGINS **
DO 40 L = 1, NTIMOR
JA = JA + 1
S(L) = JA - 1
READ (DUNIT, '(A5,I4)') DUMMY, NLABEL
DO 7 R = 1, N
c READ (DUNIT,'(1X,F17.14,8(13X,F17.14))')PA(R),PB(R),PC(R),PD(R),
c & PE(R),PF(R),PG(R),PH(R),PI(R)
READ(DUNIT,'(E13.6,8(2X,E13.6))')PA(R),PB(R),PC(R),PD(R),
7 CONTINUE
TM(L) = NLABEL
write(*,*) TM(L)
C ** STORE STEP AS A TIME ORIGIN **
CALL STOREE ( JA )
C ** CORRELATE THE ORIGINS IN STORE **
DO 10 IN = IA, L
TSS = TM(L) - TM(IN)
TS = TSS + 1
JO = S(IN) + 1
CALL CORR ( JO, JA, TS )
10 CONTINUE
C ** READ IN DATA BETWEEN TIME ORIGINS. THIS CAN **
C ** BE CONVENIENTLY STORED IN ELEMENT 1 OF THE **
C ** ARRAYS STORX ETC. AND CAN THEN BEN CORRELATED **
C ** WITH THE TIME ORIGINS. **
DO 30 K = 1, IOR - 1
DO 15 R = 1, N
15 CONTINUE
CALL STOREE ( 1 )
DO 20 IN = IA, L
TSS = NLABEL - TM(IN)
TS = TSS + 1
JO = S(IN) + 1
CALL CORR ( JO, 1, TS )
20 CONTINUE
30 CONTINUE
IF ( L .GE. FULLUP ) THEN
IF ( L .EQ. NINCOR ) THEN
NINCOR = NINCOR + FULLUP
JA = 1
ENDIF
IA = IA + 1
ENDIF
40 CONTINUE
CLOSE ( DUNIT )
C ** NORMALISE CORRELATION FUNCTIONS **
PACF(1) = PACF(1) / ANORM(1) / REAL ( N )
DO 50 I = 2, NT
PACF(I) = PACF(I) / ANORM(I) / REAL ( N ) / PACF(1)
50 CONTINUE
WRITE ( RUNIT, '('' VELOCITY ACF '')')
WRITE ( RUNIT, '(I6,E15.6)') ( I, PACF(I), I = 1, NT )
CLOSE ( RUNIT )
STOP
END
SUBROUTINE STOREE ( J1 )
c COMMON/ BLOCK1 / STORX, STORY, STORZ, STORA, STORB
& STORH,STORI
c COMMON/BLOCK2/STORB
COMMON/ BLOCK2 / PA, PB, PC, PD, PE, PF, PG, PH, PI
C ** SUBROUTINE TO STORE TIME ORIGINS **
INTEGER J1
INTEGER N, NT, IOR, NDIM
PARAMETER ( N = 2377, NT = 8, IOR =2 )
PARAMETER ( NDIM = NT / IOR + 1 )
& STORI(NDIM,N)
REAL PA(N), PB(N), PC(N), PD(N), PE(N), PF(N),PG(N), PH(N), PI(N)
INTEGER I
DO 10 I = 1, N
STORA(J1,I) = PA(I)
STORB(J1,I) = PB(I)
STORC(J1,I) = PC(I)
STORD(J1,I) = PD(I)
STORE(J1,I) = PE(I)
STORF(J1,I) = PF(I)
STORG(J1,I) = PG(I)
STORH(J1,I) = PH(I)
STORI(J1,I) = PI(I)
10 CONTINUE
RETURN
END
& STORH,STORI
c COMMON/ BLOCK1 / STORX, STORY, STORZ,STORA
COMMON/ BLOCK3 / PACF, ANORM
C ** SUBROUTINE TO CORRELATE TIME ORIGINS **
INTEGER J1, J2, IT
PARAMETER ( N = 2377, NT = 8, IOR = 2 )
& STORI(NDIM,N)
c REAL STORX(NDIM,N), STORY(NDIM,N), STORZ(NDIM,N),STORA(NDIM,N),
c & STORB(NDIM,N)
INTEGER I
C ********************************************************************
DO 10 I = 1, N
PACF(IT) = PACF(IT) + STORA(J1,I) * STORA(J2,I)
: + STORB(J1,I) * STORB(J2,I)
: + STORC(J1,I) * STORC(J2,I)
: + STORD(J1,I) * STORD(J2,I)
: + STORE(J1,I) * STORE(J2,I)
: + STORF(J1,I) * STORF(J2,I)
: + STORG(J1,I) * STORG(J2,I)
: + STORH(J1,I) * STORH(J2,I)
: + STORI(J1,I) * STORI(J2,I)
10 CONTINUE
ANORM(IT) = ANORM(IT) + 1.0
RETURN
END
DATA
Code:
[/1.000010E+04 6.223473E-01 -3.664185E+00 2.488328E+00 -3.664185E+00 1.899320E+00 2.983450E-01 2.488328E+00 2.983450E-01 3.010223E+00
1.000020E+04 -1.791006E+00 1.525541E-01 1.653747E+00 1.525541E-01 -3.636319E+00 2.703241E+00 1.653747E+00 2.703241E+00 4.975571E+00
1.000030E+04 -3.129378E-01 -3.663724E+00 1.656161E+00 -3.663724E+00 -4.128011E+00 -2.043832E+00 1.656161E+00 -2.043832E+00 3.279852E+00
1.000040E+04 -6.450919E+00 -3.708082E+00 -2.611070E+00 -3.708082E+00 -5.693249E+00 4.460507E-01 -2.611070E+00 4.460507E-01 1.607329E+00
1.000050E+04 3.146279E+00 -5.644253E-01 5.284613E-01 -5.644253E-01 -4.642398E+00 1.216114E+00 5.284613E-01 1.216114E+00 4.043103E+00
1.000060E+04 4.873293E+00 2.183875E+00 6.155124E-03 2.183875E+00 5.325019E+00 -4.930211E-02 6.155124E-03 -4.930211E-02 1.012324E+00
1.000070E+04 -1.353394E+00 2.333362E+00 4.408005E+00 2.333362E+00 -4.269528E+00 -7.599770E-01 4.408005E+00 -7.599770E-01 -4.354086E+00
1.000080E+04 -4.813567E+00 -2.603514E+00 -2.146995E-01 -2.603514E+00 3.169052E+00 -3.620447E+00 -2.146995E-01 -3.620447E+00 -7.228028E+00
1.000090E+04 -3.882664E+00 1.025861E+00 6.714240E+00 1.025861E+00 -4.198472E+00 1.217365E+00 6.714240E+00 1.217365E+00 -1.349967E+00
1.000100E+04 8.225114E+00 -1.288076E+00 -4.120618E+00 -1.288076E+00 8.242155E+00 1.484652E+00 -4.120618E+00 1.484652E+00 -1.395376E+00
1.000110E+04 -4.278094E-01 1.302281E-01 -1.920785E-02 1.302281E-01 4.527090E+00 -1.287830E+00 -1.920785E-02 -1.287830E+00 8.564435E-01
1.000120E+04 -2.129472E+00 -8.630678E-01 -2.741652E+00 -8.630678E-01 5.669820E-01 -3.469758E+00 -2.741652E+00 -3.469758E+00 2.849660E+00
1.000130E+04 -1.388297E+00 -4.542468E-01 -3.584711E+00 -4.542468E-01 5.000307E+00 1.873149E-01 -3.584711E+00 1.873149E-01 -5.513841E+00
1.000140E+04 -2.208094E+00 -1.588296E+00 2.894718E+00 -1.588296E+00 -1.531510E+00 -3.102739E+00 2.894718E+00 -3.102739E+00 1.971957E+00
1.000150E+04 -2.362187E+00 4.148493E+00 -1.156406E+00 4.148493E+00 8.843932E+00 -2.263363E+00 -1.156406E+00 -2.263363E+00 3.948367E+00
1.000160E+04 4.293848E+00 -8.717760E-01 -4.857359E+00 -8.717760E-01 -1.039215E+00 -4.006499E+00 -4.857359E+00 -4.006499E+00 5.529035E+00
1.000170E+04 6.008994E+00 4.474473E+00 -7.412315E-01 4.474473E+00 1.533358E+00 -2.114606E+00 -7.412315E-01 -2.114606E+00 4.151184E+00
1.000180E+04 2.549805E+00 -1.988171E-01 -8.086132E-01 -1.988171E-01 4.636833E+00 2.004581E+00 -8.086132E-01 2.004581E+00 1.121635E+00
1.000190E+04 1.884038E+00 2.886740E-01 -1.110394E-02 2.886740E-01 9.626488E-01 3.640551E-01 -1.110394E-02 3.640551E-01 -3.440572E+00
1.000200E+04 3.120294E+00 1.187718E+00 4.085338E+00 1.187718E+00 6.202198E+00 -3.173531E-01 4.085338E+00 -3.173531E-01 3.308024E+00
1.000210E+04 4.883089E+00 -4.223909E-01 -8.868787E-01 -4.223909E-01 -4.729599E+00 5.564123E+00 -8.868787E-01 5.564123E+00 -4.126135E+00
1.000220E+04 -6.236270E+00 -9.843776E-01 -2.407780E+00 -9.843776E-01 -2.957732E+00 4.747150E+00 -2.407780E+00 4.747150E+00 1.559040E+00
1.000230E+04 -1.780105E+00 -2.137214E+00 -5.485467E-01 -2.137214E+00 2.781043E+00 -2.217609E+00 -5.485467E-01 -2.217609E+00 1.718062E+00
1.000240E+04 -5.111529E+00 -1.521354E+00 -6.175900E+00 -1.521354E+00 -1.973681E+00 8.255795E-01 -6.175900E+00 8.255795E-01 -1.655795E+00
1.000250E+04 -5.330991E+00 -4.261089E+00 7.381286E-01 -4.261089E+00 -7.567198E+00 1.392663E+00 7.381286E-01 1.392663E+00 -6.545155E+00
1.000260E+04 -6.243782E-01 3.789372E+00 -3.943346E+00 3.789372E+00 1.153042E+00 5.273850E-01 -3.943346E+00 5.273850E-01 6.059340E+00
1.000270E+04 -3.980964E+00 8.120442E+00 -1.562085E+00 8.120442E+00 3.230575E+00 -1.117039E+00 -1.562085E+00 -1.117039E+00 -3.087427E+00
1.000280E+04 -9.319135E-02 -6.109320E-01 -5.879235E-01 -6.109320E-01 -1.577245E+00 -2.184000E+00 -5.879235E-01 -2.184000E+00 -2.892314E+00
1.000290E+04 3.304992E-01 1.486312E+00 1.969823E+00 1.486312E+00 -1.392437E+00 1.316654E+00 1.969823E+00 1.316654E+00 3.901087E+00
1.000300E+04 -2.294725E-01 -2.442103E-01 -2.194509E+00 -2.442103E-01 1.277485E+00 -5.398374E-01 -2.194509E+00 -5.398374E-01 7.853932E-01
1.000310E+04 9.462532E+00 -6.513826E+00 5.213425E-01 -6.513826E+00 9.879859E+00 4.694737E+00 5.213425E-01 4.694737E+00 1.090147E+00
1.000320E+04 -5.361188E+00 -5.342272E+00 8.158420E-01 -5.342272E+00 3.276005E-01 8.863708E-01 8.158420E-01 8.863708E-01 5.660149E+00
1.000330E+04 -1.467439E+00 6.519859E-01 3.014452E-01 6.519859E-01 1.162301E+01 -3.233772E+00 3.014452E-01 -3.233772E+00 3.717345E+00
1.000340E+04 -4.811940E+00 -4.800248E-01 1.216208E+00 -4.800248E-01 -5.772343E-01 -3.451997E-01 1.216208E+00 -3.451997E-01 -4.984954E+00
1.000350E+04 -5.078319E+00 -6.066364E-01 9.366926E-01 -6.066364E-01 3.000697E+00 2.218479E+00 9.366926E-01 2.218479E+00 -3.292760E+00
1.000360E+04 6.385810E+00 7.841234E-01 4.822792E+00 7.841234E-01 2.436286E+00 -2.018650E+00 4.822792E+00 -2.018650E+00 -2.194116E+00
1.000370E+04 2.244729E+00 -4.070176E+00 -9.467727E-01 -4.070176E+00 5.664441E+00 -5.750406E-01 -9.467727E-01 -5.750406E-01 1.374589E+00
1.000380E+04 -1.608836E+00 4.057103E+00 -9.719371E-01 4.057103E+00 -3.387367E-01 1.915489E+00 -9.719371E-01 1.915489E+00 1.625737E+00
1.000390E+04 -4.542367E+00 -5.237635E+00 9.438007E-01 -5.237635E+00 -5.430743E+00 4.518610E+00 9.438007E-01 4.518610E+00 -1.827717E+00
1.000400E+04 2.002808E+00 1.630871E+00 -1.877269E-01 1.630871E+00 -2.281501E+00 8.627181E-01 -1.877269E-01 8.627181E-01 3.100278E+00
1.000410E+04 3.543448E+00 1.824904E+00 -2.156255E+00 1.824904E+00 2.578403E+00 -1.105649E+00 -2.156255E+00 -1.105649E+00 -5.751973E+00
1.000420E+04 6.168638E+00 1.881836E+00 -8.843819E-01 1.881836E+00 -2.260070E+00 -3.110424E+00 -8.843819E-01 -3.110424E+00 -7.044914E+00
1.000430E+04 -4.072518E+00 -2.834909E+00 3.382775E+00 -2.834909E+00 3.871989E+00 -5.028691E+00 3.382775E+00 -5.028691E+00 -4.210028E+00
1.000440E+04 7.008325E+00 -1.559439E+00 -1.436902E+00 -1.559439E+00 8.371497E+00 -2.518365E+00 -1.436902E+00 -2.518365E+00 1.495700E+00
1.000450E+04 -8.829623E+00 -4.140527E-01 3.347391E+00 -4.140527E-01 -9.291294E-01 -7.492739E-01 3.347391E+00 -7.492739E-01 -1.281331E+01
1.000460E+04 2.247049E+00 -2.657417E+00 3.154380E-01 -2.657417E+00 -6.116580E+00 -5.229492E+00 3.154380E-01 -5.229492E+00 -4.626847E+00
1.000470E+04 1.367584E+01 -5.088453E+00 -5.997885E+00 -5.088453E+00 1.032811E+01 -1.740847E+00 -5.997885E+00 -1.740847E+00 -1.834946E-01
1.000480E+04 4.518350E+00 -1.516833E+00 9.302873E-01 -1.516833E+00 4.125968E+00 -3.015525E+00 9.302873E-01 -3.015525E+00 -2.995732E+00
1.000490E+04 2.337245E+00 -5.072033E+00 2.885876E+00 -5.072033E+00 4.065533E+00 1.618054E+00 2.885876E+00 1.618054E+00 -1.911990E+00
1.000500E+04 -1.809472E+00 -6.461211E+00 2.704525E+00 -6.461211E+00 -2.229136E-02 2.824328E+00 2.704525E+00 2.824328E+00 -5.401895E+00
1.000510E+04 -4.019570E+00 2.768689E+00 -4.150727E+00 2.768689E+00 3.803728E+00 1.117661E+00 -4.150727E+00 1.117661E+00 -2.088222E+01
1.000520E+04 -4.703619E+00 -1.793318E+00 -2.342140E+00 -1.793318E+00 -1.722167E+00 -1.783093E+00 -2.342140E+00 -1.783093E+00 -9.129213E+00
Original Data format to be correlated:
[/STEP 1
0.00000000000000 0.00000000000000 0.00000000000000
0.00010703812381 -0.00017907303145 0.00012845544357
0.00007086879372 -0.00020989410868 -0.00012629189678
-0.00000514347034 -0.00032707162009 -0.00004409049289
0.00010881028378 -0.00013028912781 -0.00026799460440
0.00010384640076 -0.00022617983701 0.00011577020987
-0.00015678637226 0.00005965340793 0.00005029434091
0.00015091005383 -0.00035119896993 0.00014458338425
-0.00004205347437 0.00029641535287 -0.00006770444703
0.00011338315538 0.00013223598310 0.00014689456032
0.00011067923208 -0.00009236400923 -0.00018006605952
STEP 2
0.00010947611239 -0.00015730214483 0.00011035102784
-0.00094308570313 -0.00028271152464 -0.00030895485437
-0.00007548695858 0.00094436386887 0.00052657379138
-0.00016726996547 0.00003910375158 0.00057890424342
-0.00009081549950 -0.00026510370240 -0.00018462750363
STEP 3
linuxubuntu lehloks is online now   	Report This Post
Technology news on Phys.org
It looks like you are using Fortran 77 for your program.
I can't tell for sure from your program listing, but you should make sure that columns 1-5 are reserved only for things like statement label numbers or for indicating comments.
Column 6 should be reserved to indicate statement continuation from the previous line.
Column 7-72 for statements.
Your write file should be opened with a FORM='FORMATTED' option.
Hi SteamKing
yes its fortran 77,I can compile and run it,the only problem is when i insert input requested by the code.
regards
A segmentation fault usually means your program is trying to write into an illegal portion of memory. Are you trying to fill up an array, and perhaps running out of space? Since we don't have the source code, it's tough to know.
Hi harborsparrow
I have included the source code in this thread below ,and if you look at the beggining of my thread ,I have included all the information regarding the code.
Code:
& STORH, STORI
C ** **
C ** **
C ** **
C ** **
C USAGE: **
C ** **
INTEGER FULLUP
& STORI(NDIM,N)
INTEGER NLABEL
CHARACTER DUMMY * 5
NINCOR = FULLUP
JA = 1
IA = 1
IB = 1
C ** ZERO ARRAYS **
DO 5 I = 1, NT
PACF(I) = 0.0
ANORM(I) = 0.0
write(*,*) PACF(I)
5 CONTINUEC ** OPEN DATA FILE AND RESULTS FILE **
DO 40 L = 1, NTIMOR
JA = JA + 1
S(L) = JA - 1
DO 7 R = 1, N
7 CONTINUE
TM(L) = NLABEL
write(*,*) TM(L)
CALL STOREE ( JA )
DO 10 IN = IA, L
TS = TSS + 1
JO = S(IN) + 1
10 CONTINUE
DO 15 R = 1, N
15 CONTINUE
CALL STOREE ( 1 )
DO 20 IN = IA, L
TS = TSS + 1
JO = S(IN) + 1
20 CONTINUE
30 CONTINUE
JA = 1
ENDIF
IA = IA + 1
ENDIF
40 CONTINUE
CLOSE ( DUNIT )
DO 50 I = 2, NT
50 CONTINUE
CLOSE ( RUNIT )
STOP
ENDSUBROUTINE STOREE ( J1 )
& STORH,STORI
INTEGER J1
& STORI(NDIM,N)
INTEGER I
DO 10 I = 1, N
STORA(J1,I) = PA(I)
STORB(J1,I) = PB(I)
STORC(J1,I) = PC(I)
STORD(J1,I) = PD(I)
STORE(J1,I) = PE(I)
STORF(J1,I) = PF(I)
STORG(J1,I) = PG(I)
STORH(J1,I) = PH(I)
STORI(J1,I) = PI(I)
10 CONTINUE
RETURN
END
& STORH,STORI
INTEGER J1, J2, IT
& STORI(NDIM,N)
c & STORB(NDIM,N)
INTEGER I
DO 10 I = 1, N
10 CONTINUE
RETURN
END
FAQ: Segmentation error form the fortran code
What is segmentation error from the Fortran code?
Segmentation error is a type of runtime error that occurs when a program attempts to access memory that it is not allowed to access. It is commonly encountered in Fortran programs due to the use of pointers and array indexing.
Why does segmentation error occur in Fortran code?
Segmentation error can occur in Fortran code due to a variety of reasons, such as trying to access an array element outside of its bounds, attempting to dereference a null pointer, or accessing memory that has been deallocated.
How can I fix segmentation error in my Fortran code?
To fix segmentation error, you will need to carefully analyze your code and identify the source of the error. This may involve checking array indices, ensuring that pointers are properly initialized, and using memory management techniques such as allocating and deallocating memory properly.
Can segmentation error cause data loss in my Fortran program?
Yes, segmentation error can potentially cause data loss in your Fortran program. This is because the error can cause the program to crash, which may result in data being lost if it was not saved to a file or other storage device.
Is there a way to prevent segmentation error in Fortran code?
While it is not possible to completely prevent segmentation error in Fortran code, there are some measures you can take to reduce the likelihood of encountering it. This includes carefully managing memory, checking array bounds, and using debugging tools to identify and fix errors in your code.
