MHB Selection Sort & Insertion Sort: Step-by-Step Guide to Sorting Data
  • Thread starter Thread starter Henry R
    Algorithm Sorting
The discussion focuses on sorting the data set 22, 85, 43, 28, 65, 35 using selection sort and insertion sort algorithms. Participants confirm familiarity with these algorithms from class, mentioning quick sort and simple selection sort as well. The importance of understanding these sorting methods through step-by-step analysis is emphasized, with suggestions to refer to Wikipedia for visual aids like GIFs that illustrate the processes. It is recommended to use pseudocode and manually work through the sorting steps on paper for better comprehension, especially given the small size of the data set.
Henry R
How to do this?
Show the step by step how the following data is sorted into ascending order using the given sorting algorithm :
22 85 43 28 65 35
i) Selection sort.
ii) Insertion Sort.
Technology news on Phys.org
Henry R said:
How to do this?
22 85 43 28 65 35
i) Selection sort.
ii) Insertion Sort.
Have you seen these algorithms in class?
yes. It's about sorting.
- - - Updated - - -
Yeah. They talk about quick sort, simple selection sort and something like that.
Henry R said:
How to do this?
22 85 43 28 65 35
i) Selection sort.
ii) Insertion Sort.
The Wikipedia pages on these two sorting methods not only have text examples, but also .gifs to illustrate how they work.
Best way to analyse these algorithms step by step is to obtain the pseudocode and then work through it step by step using a pen and paper. Your list only contains 6 elements so it won't take long to do it manually. You'll also gain a much better understanding of the algorithms this way.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
I am trying to run an .ipynb file and have installed Miniconda as well as created an environment as such -conda create -n <env_name> python=3.7 ipykernel jupyter I am assuming this is successful as I can activate this environment via the anaconda prompt and following command -conda activate <env_name> Then I downloaded and installed VS code and I am trying to edit an .ipynb file. I want to select a kernel, via VS Code but when I press the button on the upper right corner I am greeted...
9K
