Self Bias Transistor Design Problem
In summary, the conversation discusses solving for three variables - RD, RS1, and RS2 - using various equations and given values. The speaker has solved for RD using the AVNL equation and a given value of -8, but is struggling to find RS1 and RS2. They suggest using knowledge of Vgs and Vds to find the total source resistance and derive an expression for the voltage gain in order to solve for RS1.
charkins
I have to solve for RD, RS1, and RS2.
AVNL=-mg(Rd//rd)
Vdd-Id(Rd+RStotal)=0
Bias Line Eq: Vg-Vgsq-Idq(RStotal)
I have solved for RD by using the AVNL equation and the given value of -8 for AVNL.
I found RD to be 2000 ohms.
I cannot figure out how to get Rs1 and Rs2.
That's not correct. The voltage gain can only be approximated as (-gm Rd) if there is no un-bypassed source resistance (RS1).
Start by using the knowledge of Vgs (quiescent) to find the total source resistance (RS1+RS2), and then use the knowledge of Vds (quiescent) to find the value of RD.
Finally you need to derive (or look up) a correct expression for the voltage gain to solve for RS1.
FAQ: Self Bias Transistor Design Problem
What is a self bias transistor design problem?
A self bias transistor design problem refers to the challenges and considerations involved in designing a transistor circuit that can self-adjust its bias voltage without the need for external biasing components or adjustments. This is important for achieving a stable and reliable operation of the transistor.
Why is self bias important in transistor design?
Self bias is important because it allows the transistor to maintain a consistent and stable operating point, even as external factors such as temperature or power supply variations can affect the bias voltage. This ensures that the transistor can function properly and reliably in different conditions.
What are the common methods used in self bias transistor design?
There are several methods used in self bias transistor design, including using a resistor or diode in the circuit to provide a self-bias voltage, using a feedback loop to adjust the bias voltage, or using a transistor with specific characteristics that allow for self-biasing.
How does self bias affect the performance of a transistor?
Self bias can greatly affect the performance of a transistor as it ensures that the transistor operates within its specified range of parameters, such as gain, frequency response, and linearity. Without proper self-biasing, the performance of the transistor may be unpredictable and unstable.
What are some common issues encountered in self bias transistor design?
Some common issues encountered in self bias transistor design include thermal instability, where the bias voltage changes with temperature, leading to variations in transistor performance. Another issue is bias drift, where the bias voltage changes over time, affecting the stability of the circuit. These issues must be carefully considered and addressed in the design process.
