Self energy logarithmic divergence due to chiral symmetry.
In summary: Yes, it is easy to show (via formal manipulations of the path integral) that the effective action (which is finite) has the same symmetries as the classical action, provided that the functional measure in the path integral is invariant (this is not true when the symmetry is anomalous).
center o bass
560
In peskin at page 319 right above equation (10.6) he writes
"If the constant term in a taylor expansion of the self energy were proportional to the cutoff ##\Lambda##, the electron mass shift would also have a term proportional to ##\Lambda##. But the electron mass shift must actually be proportional to ##m## since chiral symmetry would forbid a mass shift if ##m## were zero."
So chiral symmetry is a symmetry between right and left handed fields. If the mass is zero the Lagrangian has this symmetry and the axial current is conserved classically. But how does this symmetry restrict the particle from getting a mass?
Is there an restriction within QFT which prevents a massless particle from gaining mass in mass renormalization?
If there will be a mass term then γ5 will not commute with the Hamiltonian.
And if ##\gamma_5## commutes with the Hamiltonian for the bare theory; it must also do so for the renormalized theory?
why not?
andrien said:
why not?
I would say that the properties action can't change since the bare and the renormalized theory are essentially the same theory, but perturbing about different coupling constants?
However I have read that it's not always true that if a theory is massless, one always obtain obtain a zero mass shift.
In these notes for example:
http://www.google.no/url?sa=t&rct=j...=-mHf2NPyluthnweklmsZzA&bvm=bv.47810305,d.bGE
at page 83 footnote 26.
Not all regularization schemes are very sensible,but it is expected that it should be zero.
Alright, but would you say that my argument above holds? I.e that the action of the renormalized theory must have the same properties as the bare theory and thus a symmetry of the Lagrangian in the bare theory is a symmetry in the renormalized Lagrangian?
FAQ: Self energy logarithmic divergence due to chiral symmetry.
1. What is self energy logarithmic divergence due to chiral symmetry?
Self energy logarithmic divergence due to chiral symmetry is a phenomenon that occurs in quantum field theory, specifically in the study of chiral symmetry breaking. It refers to the logarithmic increase in the self energy of a particle as its energy approaches the critical energy, which is the energy at which chiral symmetry is broken.
2. Why does self energy logarithmic divergence occur?
Self energy logarithmic divergence occurs due to the presence of massless particles in the theory. These particles contribute to the self energy of other particles and as their energy approaches the critical energy, the contribution becomes infinite, resulting in the logarithmic divergence.
3. How does self energy logarithmic divergence affect the behavior of particles?
The presence of self energy logarithmic divergence can significantly impact the behavior of particles. It can lead to the breakdown of perturbation theory and make the calculation of physical quantities, such as mass and coupling constants, difficult to determine.
4. Can self energy logarithmic divergence be avoided?
While self energy logarithmic divergence is a common occurrence in chiral symmetry breaking, it can be avoided by introducing a mass term for the massless particles in the theory. This effectively removes the infinite contribution to the self energy and prevents the divergence.
5. How is self energy logarithmic divergence studied?
Self energy logarithmic divergence is studied through various mathematical techniques, such as renormalization and dimensional regularization, in order to extract meaningful physical predictions from the theory. These techniques help to tame the infinite contributions and allow for the calculation of physical observables.
