Self lock: conditions to make it work
In summary, to achieve self locking, the width x and the height y should have a relation of F1L1=F2L2.
Karol
1,380
The flat piece is between 2 walls and is pushed eccentrically by force F. what should be the relation between the width x and the height y in order to achieve self locking (that the piece won't go down)?
Friction Force: f=μN
Balance of moments: F1L1=F2L2
I make 2 equations of moments around the contact points with the walls. the friction coefficient is μ. round point A:
$$F\left(\frac{x}{2}-l\right)+yR_2=\mu R_1\rightarrow R_2=\frac{F\left(\frac{x}{2}-l\right)}{\mu x-y}$$
round point B:
$$F\left(\frac{x}{2}+l\right)=yR_1+\mu xR_1\rightarrow R_1=\frac{F\left(\frac{x}{2}+l\right)}{y+\mu x}$$
First i see that R1≠R2, is it true?
I now insert R1 and R2 in the forces equation with the inequality ##F\geq\mu(R_1+R_2)## and get:
$$\frac{2}{\mu}\geq (x-2l)(\mu x+y)+(x+2l)(\mu x-y)$$
I can't get a conclusion from that. where, in which book, is this subject covered? i feel i complicated it
R1 and R2 should be the same, otherwise your horizontal forces are not balanced.
It is possible to simplify the result (didn't check it) a bit.
You can solve this inequality for x or (easier) y.
O.K. I take moments around point A (new drawing):
$$F\left(\frac{x}{2}-l\right)+yR=\mu R x\rightarrow R=\frac{F\left(\frac{x}{2}-l\right)}{\mu x-y}$$
While moments around B give: ##Fl=Ry\rightarrow R=\frac{Fl}{y}##
The first equation involves μ. i think she's wrong, but i don't know why. also in that equation if l=0 still R exists and it's wrong
Ah, I think I see the problem: The force from friction does not have to be µ times the horizontal force - this is just the maximum value.
Right so i cannot take moments around A? but i am interested in the limit just before the sliding, then it is the maximum force, i am interested to find geometrical relations between x, y and l so it will just lock.
And it is strange that around point B the R forces balance the moment from F and around A it is the frictional force which balances even a greater moment added by R
You can, and the self-locking requirement probably means the frictional force becomes maximal at one side (not at both), but you don't know which one in advance.
How come the frictional force becomes maximal at one side only if R is the same on both sides? and even if it does it won't prevent from sliding since i made F=f1+f2=2μR. you need both sides to be the maximum.
I think it's easy to determine which. Imagine there were no friction at the lower point and consider torque about the other. Could the system remain static? Now consider no friction at the higher point, etc.
I didn't say it is hard, and considering torque around the center of the object will lead to the right answer.
In general friction should appear on both sides, I'm not sure if analyzing the setup with zero friction leads to the same result.
Thinking what would happen without friction at some point can be a useful way of figuring out which way friction acts there.
But why no friction at all, at any side? the friction maximizes on one side earlier, as you say, so there is no relevance to no friction, it doesn't happen.
And my initial question was what are relations between x and y to achieve self locking. and also on post #3 i showed moments around different points that lead to two different answers.
The zero friction (one side at a time, not both sides at once) was a thought experiment to establish which of the two contacts would necessarily be at limiting friction. There may in general be friction at the other point also.
In your post #3 there are a couple of problems with your equation for moments about B. The left hand side should be F(x/2+l). There is an unknown frictional force at A.
It's a tricky problem because you are looking for a condition such that it won't slip no matter how large F is.
I don't think there should be F(x/2+l) on the left side. i wrote ##Fl=Ry\rightarrow R=\frac{Fl}{y}## and i think it's true. and the two equal frictional forces make moments around B that cancel each other. in post #3 i attached a new drawing in which i moved point B, you probably still looked at the original drawing from post #1
You're right, I didn't notice you had moved B. I assume it is meant to be at the same height as A.
As I keep saying, you cannot assume the two frictional forces are the same.
I added an edit to my previous post that got lost somehow. There are only three equations to be had in a statics problem with one moveable object. If you write two equations for linear statics and two for moments about different points then the four equations will be linearly dependent.
All forces scale with F as we neglect the mass of the object, fixing it would not change the problem.
Yes, but I feel it makes it hard to think about.
Why does this condition of zero friction determine on which side is the limiting friction and what is a limiting friction, is it the maximum friction fmax=μR ?
And i cancel the friction one side at a time and take moments on the other, opposite, contact point and find that both friction forces aren't needed, the moment from F could be balanced with R only.
F and R only do not satisfy the vertical force balance.
Yes, so the thought experiment of the 0 friction doesn't help since at both points the other friction is needed, they are both needed
They may both be needed, but only one needs to be at maximum value. The point of the thought experiment is to tell you which one. Then you can work out the frictional force at the other (if that's of interest).
I uploaded a picture. i marked the lower left contact point with C and i take moments around it, assuming the frictional force f1 on the opposite corner is the maximum f1=μR:
$$F\left(\frac{x}{2}+l\right)=yR+\mu Rx\rightarrow R=\frac{F\left(\frac{x}{2}+l\right)}{y+\mu x}$$
If y gets bigger R diminishes and it's true, but if x grows R diminishes also and it's wrong.
If i take moments around A and assume the other frictional force is at the maximum f2=μR:
$$F\left(\frac{x}{2}-l\right)+Ry=\mu Rx\rightarrow R=\frac{F\left(\frac{x}{2}-l\right)}{\mu x-y}$$
That one isn't logical because of more reasons:
1. as y grows R grows. false
2. as x grows R lessens. false
3. if F acts outside, meaning ##\frac{x}{2}<l## R changes direction
I'm not following your logic.
I've changed my mind about what makes this problem tricky - it's the role of R. The trouble is, you've no way to find R, yet it is critical that it is sufficiently large. In a sense, the problem is insufficiently specified. The only way to solve it is to suppose that R can be arbitrarily large, increasing as necessary as F increases. (The same problem arises in analysing an object pushed into a narrow angle between two fixed frictional surfaces. The normal force can be arbitrarily large, it just depends on how tightly the object was pushed into the angle initially.)
So, you have to look for the relationship between x, y and mu which allows a sufficiently large R to hold everything in place. The two equations in your last post give you that.
Edit: I have doubts about what I wrote above. Will post more thoughts.
In order to maintain the inward direction of R, in calculating moments around A:
$$R=\frac{F\left(\frac{x}{2}-l\right)}{\mu x-y}\rightarrow \left\{ \begin {array}{ccc}\mbox{if }\frac{x}{2}<l, & \mu x<y & \surd \\ \mbox{if }\frac{x}{2}>l, & \mu x >y & \otimes \end{array}\right.$$
I don't understand what i got. The first condition says that if F is outside, the piece must be high (big y) and narrow, and if F is inside, the piece must be wide (large x). are there really 2 conditions for that? why does the application point of F make a difference?
I calculated moments when F is outside, indeed the equations differ a bit but the final result is the same.
In what i am really interested is a condition for the piece to move, not to lock, so how do i interpret the results?
This formula was from moments only, so the results, if i didn't made a logical mistake, enable F to be balanced, so what? what happens if i don't stand in the conditions, what does it mean that R's direction changes? such thing, i think, cannot happen in any case
I don't know why you mark the second result, ##\mu x > y## as wrong.
Let's go back to the two equations we're sure of,
1 ##F(x/2+L) = Ry+F_1x##
2 ##F(x/2-L) = F_2x-Ry##
From the geometry, it cannot slip at the top right corner unless it also slips at the bottom left. So we can assume ##F_2=\mu R##.
You can then obtain an equation which involves neither F2 nor R. Let F1 = c F. You can then get mu in terms of c, x, y and L.
What is the range of possible values for c?
Why? i can assume with the same reasoning that ##F_1=\mu R##
I use my equations with the assumption ##F_2=\mu R##:
$$\left\{\begin {array}{l}R=\frac{F\left(\frac{x}{2}-l\right)}{\mu x-y}\\F\left(\frac{x}{2}+l\right)=yR+f_1x\end{array}\right.$$
$$\rightarrow f_1=F\left(\frac{y-\mu\left(\frac{x}{2}+l\right)}{y-\mu x}\right)$$
$$f_1<F\rightarrow l+\frac{x}{2}<x$$
First, that is how i drew the sketch with F inside, it doesn't say something new, and secondly it's a restraining condition, what if F is outside?
Karol said:
Why? i can assume with the same reasoning that F1=μRF_1=\mu R
No. From the geometry, it could slip down at the lower left corner while pivoting at the top right. The converse is not true.
Karol said:
##\rightarrow f_1=F\left(\frac{y-\mu\left(\frac{x}{2}+l\right)}{y-\mu x}\right)##
Good, but provably ##\mu x > y##, so I would swap the signs in numerator and denominator.
For the range of ##f_1##, ##\mu## provides a basis for an upper limit, but what is the lower limit?
$$f_1=F\left(\frac{y-\mu\left(\frac{x}{2}+l\right)}{y-\mu x}\right)$$
The nominator and the denominator must have equal signs in order to maintain R's inward direction. f1 must also be bigger than 0 so it will have a value and that's it's minimum. for F inside:
$$\mbox{and}\left\{\begin{array}{ll}y-\mu\left(\frac{x}{2}+l\right)>0\\y-\mu x>0\end{array}\right.\rightarrow \mbox{and}\left\{\begin{array}{ll}y>\mu\left(\frac{x}{2}+l\right)\\y>\mu x\end{array}\right. \rightarrow y>\mu x$$
That isn't logical since it makes the part high (big y) which is good for sliding, not locking, and the equations here are for locking.
The nominator and denominator can be both negative, and i get a different result:
$$\mbox{and}\left\{\begin{array}{ll}y-\mu\left(\frac{x}{2}+l\right)<0\\y-\mu x<0\end{array}\right.\rightarrow \mbox{and}\left\{\begin{array}{ll}y<\mu\left(\frac{x}{2}+l\right)\\y<\mu x\end{array}\right. \rightarrow y<\mu\left(\frac{x}{2}+l\right)$$
That is logical since it implies a wide part.
Look at your second equation in post #21. F inside means x/2 > l, so ##\mu x > y##. Why do you keep asserting the opposite?
But if F is outside and x/2 < l then it's inverse: ##\mu x < y##
No. If x/2 < l then F2 acts downwards, so is negative.
Edit: I withdraw that. Need to think some more...
Yes, you're right, if F acts outside the wall then the the critical value of ##\mu## is less than y/x. But it would be wrong to interpret that as meaning y needs to be large for it to stay in place. All it says is that ##\mu## does not need to be as much as y/x.
In fact, the "F outside" case is easier. In that set-up, it cannot slip unless it slips at both contacts, so you can take ##F_1=F_2=\frac 12 F=\mu R##. You should get a very simple expression for ##\mu##.
  • #31
For F outside moments around A:
$$\mbox{and}\left\{\begin{array}{ll}F\left(\frac{x}{2}+l\right)=Ry+\mu Rx\\2\mu R<F\end{array}\right.\rightarrow F\left(\frac{x}{2}+l\right)<\frac{F}{2\mu}(y-\mu x)\rightarrow y>2\mu l$$
And for F inside its ##\mu x < y##
  • #32
I agree with your algebra for the F outside case, but the condition seems to be inverted. I thought we wanted the non-slip condition, so it would be ##2\mu R > F##, leading to ##\mu > y/(2l)##.
For F inside, perhaps you're doing the same, since you keep asserting ##\mu x < y## when I have shown the opposite must be true. Anyway, the inside case is more complicated because we cannot assume the top right corner is on the point of slipping. The frictional force there is anything from zero to ##\mu R##. It will take a bit of thought to decide which of those extremes is the right one for the purpose of answering the question.
Related to Self lock: conditions to make it work
What is self lock and how does it work?
Self lock is a mechanism that automatically locks or secures an object or system without the need for external intervention. It works by using specific conditions or triggers to activate the locking mechanism.
What are the common conditions that need to be met for self lock to work?
The conditions for self lock to work can vary depending on the specific system or object. However, some common conditions include time-based triggers, pressure sensors, temperature sensors, and mechanical triggers.
What are the advantages of using self lock?
Self lock offers several advantages, including increased security, convenience, and efficiency. It eliminates the need for manual locking and reduces the risk of human error. It also allows for remote locking and unlocking, making it ideal for automated systems.
What are the potential drawbacks of relying on self lock?
One potential drawback of self lock is the risk of malfunction or failure. If the conditions for activation are not properly calibrated or if there is a technical issue, the self lock may not work as intended. Additionally, self lock may not be suitable for all situations, and manual locking may still be necessary in certain cases.
How can self lock be improved or made more reliable?
To improve the reliability of self lock, regular maintenance and testing are essential. It is also important to have backup systems or manual overrides in case of failure. Additionally, advancements in technology and sensor accuracy can also contribute to making self lock more reliable.
  • Topology and Analysis
