Self-studier w/ kleppner & kolenkow question
  • Thread starter pton265
  • Tags
    Kleppner
In summary: Your Name]In summary, the conversation discusses a problem involving a mass moving in a circular motion on a frictionless table, held by a string passing through a hole in the table. The string is slowly pulled, causing the mass to spiral inward and break from uniform circular motion. The question at hand is whether the work done in pulling the string equals the increase in kinetic energy of the mass. The person asking the question provides their analysis and intuition about the motion, while also mentioning a solution they found that may have overlooked the radial component of velocity. The response suggests double-checking calculations and seeking help if needed.
pton265
Hi,
This is my first post. I'm reviewing mechanics out of K&K and have a question about problem 4.5:
"Mass m whirls on a frictionless table, held to a circular motion by a string which passes through a hole in the table. The string is slowly pulled through the hole so that the radius of the circle changes from l1 to l2. Show that the work done in pulling the string equals the increase in kinetic energy of the mass."
I'm assuming the mass starts with uniform circular motion at radius l1, and I analyze in polar coordinates with the center of this circle as the origin. My initial intuition about the motion:
(1) Angular acceleration is non-zero (positive), but there cannot be a [tex]\widehat{}\theta[/tex] component of acceleration (the force is always radial) - which is only true if
2[tex]\dot{}r[/tex][tex]\dot{}\theta[/tex] = -r[tex]\ddot{}\theta[/tex].
(2) The only way for the string to do work (increase the magnitude of m's velocity) is if m's trajectory (and, therefore, velocity) has some radial component. That is, the force must at some point have a non-orthogonal component with respect to the trajectory. Since the force is everywhere radial, the [tex]\widehat{}\theta[/tex] component of velocity is unchanged, while the radial component of velocity increases (in the negative [tex]\widehat{}r[/tex] direction). This statement does not contradict (1), where I state angular acceleration is non-zero (right?!). Physically, all of this corresponds to the mass breaking from uniform circular motion and spiraling inward toward the center of the table (i.e. where the hole is). When it reaches l2, it will NOT be in uniform circular motion because it's velocity must have some radial component (inward).
Now, the only solution (http://hep.ucsb.edu/courses/ph21/problems/p7sol.pdf ) I've found takes (1) to be true, but (2) to be false. The final velocity in the solution has a magnitude such that the velocity can not possibly have a radial component. In other words, once the mass reaches l2, it pops back into uniform circular motion (albeit, with higher velocity). How can the trajectory take this form (i.e. that of consecutively smaller concentric circles)?? Is the solution wrong? If not, where is my error?
Please bear in mind that the only assumed knowledge at this point is of translational motion, linear momentum, and the Work-energy theorem in one dimension (KK chs.1-4) - not angular momentum, rotational motion, etc.
My apologies if there is already a similar thread - I've searched PF pretty thoroughly.
Thanks very much for any and all help...
L
Hi L,
Thank you for your question and for providing such thorough analysis of the problem. Your intuition about the motion is correct - the mass will indeed break from uniform circular motion and spiral inward towards the center of the table as the string is pulled through the hole.
The solution you found may have overlooked the fact that the velocity of the mass must have a radial component in order for the string to do work and increase the kinetic energy. As you mentioned, this is due to the fact that the force is always radial and cannot have a non-orthogonal component with respect to the trajectory.
It is possible that the solution you found was for a different scenario where the string is pulled at a constant rate, resulting in the mass maintaining uniform circular motion. However, in the scenario described in the problem, the string is being pulled slowly, allowing for a change in velocity and a non-uniform circular motion.
I would suggest double-checking your calculations and making sure that you are considering the radial component of velocity in your analysis. If you are still having trouble, I would recommend seeking help from a professor or classmate who may have a better understanding of the problem.
I hope this helps and good luck with your review! Keep up the good work.
FAQ: Self-studier w/ kleppner & kolenkow question
1. What is "Self-studier w/ kleppner & kolenkow question"?
"Self-studier w/ kleppner & kolenkow question" is a study guide designed for self-study of the book "An Introduction to Mechanics" by David Kleppner and Robert J. Kolenkow. It includes solutions to the end-of-chapter questions and problems in the book, along with additional practice questions and explanations.
2. Who is the target audience for this study guide?
The study guide is intended for students and individuals who are self-studying the book "An Introduction to Mechanics". It can also be useful for instructors who are looking for additional practice questions and explanations for their students.
3. Are the solutions in this study guide reliable?
Yes, the solutions provided in this study guide are reliable and have been thoroughly checked for accuracy. However, it is always recommended to double-check your work and understanding of the material.
4. Can this study guide be used as a substitute for a textbook?
No, this study guide should not be used as a substitute for the textbook. It is meant to supplement the material and provide additional practice and explanations, but it does not replace the comprehensive content found in the textbook.
5. Is this study guide suitable for all levels of learners?
Yes, this study guide is suitable for learners of all levels. It provides solutions and explanations for both basic and advanced problems, making it useful for beginners as well as more experienced learners.
