Why Is the Electric Potential the Same for Inner and Outer Semi-Circles?
In summary, the electric potential is the same for inner and outer semi-circles due to the property of equipotential surfaces, which states that points at the same potential do not require work to move charges between them. In a uniform electric field or around symmetric charge distributions, the electric potential remains constant along these surfaces. Therefore, regardless of the distance from the charge, as long as the geometry is maintained, the potential experienced by points on the inner and outer semi-circles remains equal.
cherry
Two semicircular rods and two short, straight rods are joined in the configuration shown. The rods carry a charge of λ = 55C/m. The radii are R1 = 4.3 m and R2 = 9.5 m.
Calculate the potential at the centre of this configuration (point P). Please note that there are also charges on the straight segments.
V = kλ ln[r + l / r]
V = kq / r
I solved using the formulae listed in the relevant equations and got the right answer.
However, I noticed something strange to me.
The electric potential due to the inner semi-circle was equal to that due to the outer semi-circle.
But based on the formula for calculating V, we notice that there is "r" involved.
So shouldn't the electric potential be different?
My professor gave a hint saying to "utilize spherical symmetry" but I still don't understand why they would be equal.
  • Love
Likes Delta2
haruspex said:
Hi! Sorry, I forgot to upload the picture. For some reason, I am not getting the settings to upload a photo. So here is a Google Drive image of the diagram.
cherry said:
Homework Statement: Two semicircular rods and two short, straight rods are joined in the configuration shown. The rods carry a charge of λ = 55C/m. The radii are R1 = 4.3 m and R2 = 9.5 m.
Relevant Equations: V = kλ ln[r + l / r]
V = kq / r
The qualitative explanation is that the inner semi-circle has smaller radius but has smaller semi-circumference too, so smaller total charge. It happens that the total charge of each of the two semi-circumference , is equal to ##q_1=\pi \lambda r_1##, ##q_2=\pi \lambda r_2## while the potentials (at center) are ##V_1=K\frac{q_1}{r_1}## and ##V_2=K\frac{q_2}{r_2}## , so you can see that each of the radius ##r_1,r_2## gets simplified when calculating the potentials and leave just ##\pi K\lambda## in both cases
So whenever there are concentric circles, the electric potential is the same?
Delta2 said:
The qualitative explanation is that the inner semi-circle has smaller radius but has smaller semi-circumference two, so smaller total charge. It happens that the total charge of each of the two semi-circumference , is equal to ##q_1=\pi \lambda r_1##, ##q_2=\pi \lambda r_2## while the potentials (at center) are ##V_1=K\frac{q_1}{r_1}## and ##V_2=K\frac{q_2}{r_2}## , so you can see that each of the radius ##r_1,r_2## gets simplified when calculating the potentials and leave just ##\pi K\lambda## in both cases
Oh, so whenever there are concentric circles with different radii, the electric potential is the same across all circles?
Likes Delta2
Yes. given that all concentric circles carry the same linear charge density ##\lambda##.
And also I think this holds only for the potential at the center of the configuration.
Got it, thank you!
Likes Delta2
FAQ: Why Is the Electric Potential the Same for Inner and Outer Semi-Circles?
Why is the electric potential the same for inner and outer semi-circles?
The electric potential is the same for inner and outer semi-circles because they are equidistant from the point charge or the source of the electric field. The electric potential at any point in space depends only on the distance from the source charge, not on the path taken to reach that point.
What role does symmetry play in the electric potential of semi-circles?
Symmetry plays a crucial role in ensuring that the electric potential is the same for inner and outer semi-circles. Due to the symmetrical arrangement, each point on the inner semi-circle has a corresponding point on the outer semi-circle that is at the same distance from the source charge, leading to equal electric potentials.
Does the shape of the semi-circles affect the electric potential?
No, the shape of the semi-circles does not affect the electric potential as long as the distance from the source charge remains constant. Electric potential is a scalar quantity and depends solely on the radial distance from the source charge, not on the specific shape or path.
How does the concept of equipotential surfaces relate to semi-circles?
Equipotential surfaces are surfaces where the electric potential is constant. Both inner and outer semi-circles can be considered as part of equipotential surfaces if they lie at the same distance from the source charge. This means that any point on these semi-circles will have the same electric potential.
What mathematical principles explain the equal electric potential in semi-circles?
The equal electric potential in semi-circles can be explained using the principle of superposition and the formula for electric potential, V = kQ/r, where V is the electric potential, k is Coulomb's constant, Q is the charge, and r is the distance from the charge. Since the distance (r) is the same for points on both semi-circles, the electric potential (V) remains equal.
