Semi empirical mass formula derivation help
The discussion centers on deriving the binding energy of Niobium 93 using the Semi-Empirical Mass Formula (SEMF). The user is experiencing discrepancies between their calculated binding energy and database values, despite using coefficients from a Wikipedia article. The SEMF is designed to approximate nuclear masses and binding energies based on empirical data and physical principles, but it may not account for all complexities in larger nuclei. Participants highlight that the formula provides a general trend rather than precise predictions due to the intricate nature of nuclear interactions. The user seeks assistance in correcting their calculations and understanding the significant differences observed.
artis
None
$$BE = a_{v}A −a_{s}A^{2/3} −a_{c}\frac{Z(Z-1)}{A^{1/3}} −a_{A}\frac{(N-Z)^{2}}{A} + a_{p}\frac{1}{A^{1/2}}$$
Can somebody please derive for me an example of the Binding energy from the Semi Empirical mass formula? I am trying myself but always there is a difference between the database binding energy and my own result. I am calculating the BE of Niobium 93. For the mass formula I used the coefficients found on the table in the Wikipedia article, found here in the link
https://en.wikipedia.org/wiki/Semi-empirical_mass_formula
I used the coefficients in amu from the first graph by Eisberg & Resnick
Also , what is the purpose of the semi empirical mass formula, because once we know the masses of proton and neutron and the mass of each atom we can then use a simple adding and subtraction to find the binding energy of a particular nucleus which manifests itself as the mass defect.
Was it made to approximate the masses before we had the technical means to observe them empirically?
PS. This is not a typical homework , just me going through some relevant maths. I apologize for not being able to present the equation in LaTex , I tried but I failed.
How can we help ?
(There's a good tutorial on LaTeX here.)
Enclose in double dollar signs to get displayed math:
$$ BE = avA −asA2/3 −acZ(Z −1)/A1/3 −aa(N −Z)/2A + ap1A/1/2 $$ gives
$$ BE = avA −asA2/3 −acZ(Z −1)/A1/3 −aa(N −Z)/2A + ap1A/1/2 $$ which is completely confusing when compared to the WIki picture
for which the input could be
$$ E_B = a_V A - a_S A^{2/3} - a_C { Z(Z-1)\over Z^{1/3} } - a_Z { (N-Z)^2 \over A } + \delta (N,Z) $$
which gives
Ok, I tried the online latex editor and copied my result now using the dollar signs and it seems to work
thanks @BvU , but as I try to copy the same formula back in my OP under category "relevant equations" it doesn't display a nice formula anyway.
$$BE = a_{v}A −a_{s}A^{2/3} −a_{c}\frac{Z(Z-1)}{A^{1/3}} −a_{A}\frac{(N-Z)^{2}}{A} + a_{p}\frac{1}{A^{1/2}}$$Still I hope someone can show me a good derivation of this using what I explained in my OP #1 post
How big a difference? 50%? 0.5%?
As I understand it, the semi-empirical binding energy formula basically fits a "smooth" curve based on physical principles, to empirical data. Or, to put it another way, it tries to make some sense of observed measurements of nuclear masses, in terms of those physical principles. But it can only explain general trends.
Nuclei are complex systems, especially the larger ones. They're dominated by the "strong force" between fundamental particles, which is more complicated than the electromagnetic interaction. Some aspects are still not completely understood from first princples, out to umpteen decimal places, as far as I know.
@jtbell well the difference was too large , don't remember exactly but since I calculated for Niobium 93 which is not one of those weird "off the charts" nuclei then I believe I got something wrong. I will try once more anyway.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
