Sending a cryptographic key faster than the speed of light
In summary, quantum entanglement does not imply that you can send information faster than the speed of light since you cannot manipulate what your sending. You don't know what you have until you have measured it.
Lars278
TL;DR Summary
Bell's theorem, EPR and quantum entanglement
Quantum entanglement does not imply that you can send information faster than the speed of light since you cannot manipulate what your sending. You don't know what you have until you have measured it. But you do know that you have the corresponding photon at the other location in space no matter if that place is 4 inches away or 1 billion light years away. If your satisfied with what you get as long as you know that you have the corresponding particle at the other end; this means that you can send a cryptographic key faster than the speed of light. So you are able to send a cryptographic key into a black hole, though you can't use it for communication. (cryptographic keys come in corresponding pairs)
No, yu can't send a cryptographic key faster than light. Nobody is sending anyone anything. You can have two people receive a key at the speed of light, but nothing in that requires entanglement or even QM. You could put up a poster saying "The secret word is 'crackpot'" and accomplish the same thing.
  • Haha
Likes Klystron and PeroK
Googling for "quantum key distribution" will find much information on the various ways that entanglement can be used to create and share cryptographic keys.
All practical techniques require a classical channel as well, so there's no way of exchanging keys at faster than the light speed. Even if it were possible, there's little value in doing so because any message encrypted with the key must travel at less than the speed of light.
You're oversimplifying! There's a difference between traveling 1 billion light years, then writing "crackpot" and traveling 1 billion light years, then writing the complement of a sequence you do not know until you get there.
You should also be aware that there is no sense in which your "key" is traveling in any particular direction. From here to the black hole, or from the black hole to here, there is no way to distinguish these scenarios. Note that time is not a factor at all, i.e. first measurement vs. second measurement is simply an arbitrary label in QM when you are considering an entangled system.
But not a useful distinction. Either you and your counterpart carried the entangled particles on your outbound journeys and only looked at them when you arrive, in which case you might just well have carried the shared key along instead; or (as in all practical implementations) the particles are transmitted to both you and your counterpart after the fact, in which case there's no FTL possibility.
Quantum key distribution is a powerful and useful technique, but the value doesn't come from any FTL possibilities; it comes from the cryptographic randomness (required to maintain the unbreakability of one-time-pad methods) and its resilience to third parties covertly acquiring the keys.
To make a convincing counterargument, you would have to describe your proposed protocol in detail, similarly to the way that the currently accepted quantum key distribution protocols have been described.
Related to Sending a cryptographic key faster than the speed of light
What is a cryptographic key?
A cryptographic key is a piece of information used to encrypt or decrypt data. It is a string of characters that is used to scramble plain text into unreadable cipher text, and vice versa.
How is a cryptographic key sent?
A cryptographic key can be sent through various methods such as email, physical delivery, or through a secure network. However, the key itself is not sent, but rather a representation of the key is transmitted.
Why is the speed of light important in sending a cryptographic key?
The speed of light is important because it is the fastest speed at which information can travel. In order to ensure the security of the key, it must be transmitted as quickly as possible to prevent interception by a third party.
Is it possible to send a cryptographic key faster than the speed of light?
No, it is not possible to send a cryptographic key faster than the speed of light. This is due to the laws of physics and the limitations of our current technology.
What are the potential consequences of sending a cryptographic key faster than the speed of light?
If it were possible to send a cryptographic key faster than the speed of light, it could potentially compromise the security of the key and the data it is meant to protect. It could also lead to a violation of the laws of physics and disrupt the normal functioning of communication systems.
  • Quantum Physics
9K
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
