SpaceGuy50
- 25
Will we ever be able to actually send a probe to the Earth's core?
A bit off topic, butOAQfirst said:http://en.wikipedia.org/wiki/Travel_to_the_Earth's_core
Take these articles with a grain of salt for they are publicly edited, but for general information-digging they can be fun.
D H said:A bit off topic, but
People wonder why some disallow use of wikipedia as a source at any education level. The cited entry is prima facie evidence of why this is so.
Travel to the Earth's center, though not currently considered scientifically possible, is a popular theme in science fiction. Some subterranean fiction involves travel to the Earth's center, either finding a Hollow Earth or the Earth's molten core.
Though no scientists have seriously proposed travel to the Earth's center, planetary scientist David J. Stevenson suggested sending a probe to the core as a thought experiment.[1][2] So far, the deepest humans have drilled is just over 12 kilometers, (7.62 miles), in the Kola Superdeep Borehole.[3]
Depends on how you look at it.D H said:A bit off topic, but
RonL said:If you consider the energy return in trying to keep a drill bit cool, you might get a free cost to drill. (other than the cost of materials)
Energy related there might be great rewards. What might be the risk of blowout holes??
I think the affect of energy withdrawl from the total heat of the Earth would be miniscule.
Travel ? totally out of reason.
jamesb-uk said:Theoretically, but that would have to be in the far future, as we couldn't possibly make an alloy which could surve such temperatures. We can get energy from heat via hot rocks in places with volcanic activity- in Iceland in particular, they use geothermal energy, where they pump water down to the rocks about 4km down, and it comes back up as steam. It would have to be deeper than that in non-volcanic areas, but in order to get a lot of energy from it, we wouldn't have to enter the mantle, let alone the inner core.
RonL said:If I'm not mistaken, there is no alloy at present that will not melt at the internal temperature of a jet engine, it is all in how you hold the heat away from the metals.
I don't think it is possible to reach the core, but only for other reasons.
jamesb-uk said:The temperature of the inner core is about 5500K. The melting point of tungsten, with one of the highest melting points is about 3500K. The temperature of the hottest part of a jet engine is very roughly, depending on the type etc, 3000K. So it is possible, although I don't think tungsten is used.
How do you think we could cool the probe? We couldn't use air as the mantle is too viscous, and then we'd have the problem of piping it down there. If we used anything with a melting point of much less than 5500K, if it is in contact with the magma, it would melt very quickly. It would be impossible to convect heat away quickly enough, partly because of the viscosity of the magma, and partly because of the distance the substance would have to travel before it reached the cool surface. The only reason a jet engine is cooled is because it has a ready supply of very cold air coming in at very fast rates.
I'm not saying the temperature is the only problem here, but that it is a major one.
You don't think much of Nature as a reliable publication then? An unusual viewpoint, but to each his own.D H said:People wonder why some disallow use of wikipedia as a source at any education level. The cited entry is prima facie evidence of why this is so.
SpaceGuy50 said:Will we ever be able to actually send a probe to the Earth's core?
I thought that the subducted crust simply becomes part of the mantle- the mantle is, after all, very hot rock, magma. I didn't think there was a debate about it.diogenesNY said:There has been sonic (sonar-like I think) probing and seizmic data modeling that purports to explore and expose the inner core of the earth. Some of this data is currently fueling the debate over what happens to subducted crustal slabs (where do they go? do they drop to the core or keep fluttering around the upper mantle? contrversial/inconclusive).
But what can they learn from this? That plate tectonics is correct? What more is there to learn?Indirect probing, however, is possible and going on now. Still controversy as to what the data gathered so far means and even how to interpret it. Still other things about the core are inferred from observed effects. We can probe the core lots... getting there is the difficult part.
Uh, isn't that like asking "we know weather/volcanism/evolution/any-other-science occurs, what more is there to learn?"jamesb-uk said:But what can we learn from this? That plate tectonics is correct? What more is there to learn?
DaveC426913 said:Uh, isn't that like asking "we know weather/volcanism/evolution/any-other-science occurs, what more is there to learn?"
It would be to learn all we can so we can refine our theories. We don't know that much about what goes on.jamesb-uk said:Perhaps it was badly phrased. I just wanted to ask what the researchers' aims for this research were, which I assumed were to confirm our theories.
There is no debate about it because your statement is flawed. Magma is molten rock. The mantle is not molten. There are thought to be small portions of it where partial melting occurs. This is unlikely to exceed 10% by volume of these portions. The only continuously molten part of the interior is the outer core.jamesb-uk said:I thought that the subducted crust simply becomes part of the mantle- the mantle is, after all, very hot rock, magma. I didn't think there was a debate about it.
jarednjames said:Sorry to bring up an old thread, but I've always wondered, if we've never been there, how do we know the core is 5500K? What do we actually know about the core that we can be fairly certain about?
The Earth's core is approximately 3,000 kilometers (1,864 miles) beneath the Earth's surface.
The temperature at the Earth's core can reach up to 5,400 degrees Celsius (9,800 degrees Fahrenheit).
Sending a probe to the Earth's core would allow us to gather valuable information about the composition and structure of our planet, helping us better understand its formation and evolution.
A probe sent to the Earth's core would need to be made of extremely durable and heat-resistant materials, and would need to be equipped with advanced cooling systems to withstand the high temperatures.
Currently, the technology for sending a probe to the Earth's core is still in development. Some proposed methods include using high-pressure drilling equipment, using a laser beam to melt through the Earth's crust, or using a specially designed capsule that would be able to withstand the extreme conditions.
