Separability of Hilbert Spaces
In summary, the separability of Hilbert spaces in Quantum Mechanics is required because any actual observation is from a finite dimensional space, but sometimes of a large but unknown dimension. This is handled by taking a limit and using Rigged Hilbert spaces, which are separable. The Stone-von Neumann theorem also supports the use of separable Hilbert spaces in non-relativistic QM.
Andre' Quanta
34
Why we require the separability of Hilbert spaces in Quantum Mechanics?
In reality any actual observation is from a finite dimensional space - but sometimes of a large but unknown dimension. To handle that a limit is taken and you end up with Rigged Hilbert spaces which are separable.
To be specific the space is of vectors of finite dimension but of any size. Mathematically we take the dual which is the Rigged Hilbert space of this space. It is separable - but convergent only under a very weak topology. Such a large space isn't actually required in practice and part of the art of using Rigged Hilbert spaces is figuring out exactly what subset is needed:
http://arxiv.org/abs/quant-ph/0502053Thanks
Bill
Because of results like the Stone-von Neumann theorem. In non-relativistic QM, this theorem asserts that any irreducible unitary realization of the (integrated form of the) canonical commutation relations on a complex Hilbert space ##H## (in principle, not necessarily separable) is unitarily equivalent to the standard realization in the separable space ##L^{2}(R^{3})##, i.e., only in a separable space you can get one such irreducible unitary realizations. Similar results hold for the representation theory of the Poincaré group in relativistic QM.
Likes dextercioby
Related to Separability of Hilbert Spaces
1. What is the definition of separability of Hilbert Spaces?
The separability of Hilbert Spaces refers to the property of a Hilbert Space being able to be spanned by a countable set of vectors. In other words, it means that the space contains a countable dense subset.
2. How is separability related to the completeness of Hilbert Spaces?
The completeness of a Hilbert Space is a necessary condition for separability. A Hilbert Space must be complete in order to have a countable dense subset, which is a defining feature of separability. However, not all complete Hilbert Spaces are separable.
3. Can you provide an example of a separable Hilbert Space?
Yes, one example of a separable Hilbert Space is the space of square-integrable functions on the interval [0,1] with the inner product defined as the integral of the product of two functions. This space is separable because it can be spanned by the set of polynomials with rational coefficients, which is a countable set.
4. Why is the concept of separability important in functional analysis?
The concept of separability is important in functional analysis because it allows for the study and analysis of infinite-dimensional spaces using tools and techniques from finite-dimensional linear algebra. It also has applications in various fields such as physics, engineering, and statistics.
5. Is every subspace of a separable Hilbert Space also separable?
No, not every subspace of a separable Hilbert Space is necessarily separable. A subspace can only be separable if it contains a countable dense subset. If the subspace is not dense, then it cannot be separable. However, if the subspace is also complete, then it must be separable.
